11-30-2017, 09:49 AM | #45 |
1578
Rep 1,024
11-30-2017, 09:56 AM | #46 |
655
Rep 1,095
That's weird because in front of that is the heat exchanger. Make sure to get a photo
2016 M3 Alpine White / Sakhir Orange BM3 Stage 2 / AWE Exhaust (Non-Res) / VRSF Cat-less Downpipes / CG Precision Valve Control / AFE Drop In Filters / 20% 3M Tint / Blackvue DR650GW-2CH / Escort Redline (Blendmount) |
12-01-2017, 03:41 PM | #47 |
1578
Rep 1,024
Finally got a photo, but the point of view it's taken from doesn't indicate where on the radiator the impact occurred. Getting the piece of debris (looks to be fragment of box cutter razor blade) and damaged unit so I can examine myself.
12-02-2017, 06:34 PM | #48 |
1578
Rep 1,024
Car is back and I have the radiator/debris. Nearest I can tell from the service notes, they pressure tested the system and traced the leak back to the inner central unit. When they pulled it, they found the razor blade fragment in the area with the diagonal impact on the lower left. It did embed itself in the fins and dent the lines, but I don't see a puncture in them. Once they saw the debris, they assumed it to be the cause and went no further.
I'm going to see if I can pressure test it to confirm and see if there's any other compromised areas. They did manage to scratch the shit out of it when they removed it. Last edited by AlpineWhite_SJ; 12-02-2017 at 06:45 PM.. |
12-27-2017, 08:36 PM | #49 |
2056
Rep 1,984
Man my rad got punctured by a screw and it lost all coolant immediately. If I filled it up it drained right out. Sucks but nothing you or anyone else could have done to prevent it. Cost me 1800 to have it replaced on my 2015. I know it's happened to others here as well.
Can't you just plug and hook up a garden hose to to your old rad and see if it leaks? Seems like you want to fault the dealer though??? |
01-10-2018, 02:08 AM | #50 | |
1578
Rep 1,024
I fault the dealer for being untrustworthy, trying to rip me off repeatedly (quoting 2-3x cost of the part, for example), demonstrating a lack of care for the car when in their possession, a failure on their part to diagnose another documented issue with the car, and being generally evasive about answering questions. Based on those factors, I don’t trust their explanation for what caused the leak and whether it occurred when they were driving it. |
03-03-2019, 07:15 PM | #51 |
76
Rep 322
03-03-2019, 07:49 PM | #52 |
BimmerPost Supporting Vendor
8312
Rep 18,880
Drives: BMW
CSF is manufactured in both India and Indonesia.
01-03-2024, 06:19 PM | #53 |
Rep 1
Drives: 2015 Bmw m4
So I’m dealing with the same problem, except only my small coolant expansion tank is empty after a couple drives.
I went to the dealer and they told me usually “Top mounted intercoolers” (TMI) go bad all the time on s55. The “top mounted intercoolers” will usually start internally leaking. In my case my TMI is internally leaking and going into my J charge pipe. I have stopped using my car and now I’m waiting on new TMI to get here Here are pictures of inside of my top mounted intercooler, if you’re wondering how I was able to capture these images. I bought a “borescope camera” and stuck into sensor hole located behind the intercooler and was able to see inside. Hope this can help |
