03-08-2017, 10:04 PM | #45 | |
1581
Rep 8,077
Drives: 11 E90 M3 Individual
Redline 75w-90NS/140NS has no FM in it. NS is short for no slip. If it doesn't have NS after the viscosity...you're good to go.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
12-17-2017, 08:04 PM | #47 |
124
Rep 137
Been sidetracked with the GT3, so haven't got back around to it yet. Still on the list though!
'18 GT3 - 6MT
'13 E92 M3 - street/track '07 Cayman S - track car '15 FRS - Sprint racecar '00 Miata - Enduro racecar |
///Mobbin1478.00 |
12-31-2017, 09:59 AM | #49 |
124
Rep 137
True dat. That said, I've used the "factory" Giken setting on both my miata and Cayman and have no complaints.
'18 GT3 - 6MT
12-31-2017, 03:04 PM | #50 |
72
Rep 341
I’m hearing a low speed groaning on tight left and right turns. I had the diff fluid changed about 4-5k miles ago with the fm boosted OEM stuff. I thought maybe the non fm was put in but according to my receipt it has fm.
Other thought was it could be wheel bearings but Both sides at the same time seems a stretch and the car was just a daily driver for 8-9 years, no track/Autox. Do bearings go bad with normal driving? Other ideas? The car has 97k miles. EDIT: now that I think about it, I would hear the wheel bearings at all speeds, not just low speeds. Back to diff I guess.
Current: E90 M3
Previous: 15' M235i, 12' E92 M3, 03' E46 M3, 98' E36 M3 4 dr, 95' E36 M3 2 dr All the above, missed and wish I kept them all. |
01-02-2018, 03:26 PM | #51 |
469
Rep 280
Drives: M2 F87, M3 E92 & E46, C63, 911
Garage List 2018 BMW M2 F87 [0.00]
2008 BMW M3 E92 [0.00] 2003 BMW M3 E46 [0.00] 2012 BMW M3 E92 [0.00] 2011 Merc C63 AMG [9.00] |
if the fm does not improve things the lsd core is shot! you will need to replace it to really solve this problem! or live with it... it will not damage anything else and will not completely fall apart anytime soon.
01-03-2018, 11:43 PM | #52 |
24
Rep 57
Drives: 2017 C7 Z06 Z07 7MT
Could be wheel bearings. I did all four on my old track car. It’s a safety issue, so worth a look.
01-04-2018, 12:13 PM | #53 |
1478
Rep 2,672
I've decided I want to move ahead with upgrading my LSD to a track focused clutch type unit and have reached out to driftflo for his recommendation. I am still a few months out on the purchase and installation but thought I would share the process.
One thing I wanted to ask folks is how comfortable would you be installing a differential core yourself? I've done a number of installs in the past including brakes, suspension, and rod bearings, so I'm not a stranger to car work but there seems to be a good amount of nuance to getting a diff install right. Below is an example video I found on YouTube that takes you through some of the process. I am still researching shimming, backlash, and ring-gear/pinion contact adjustment so any good resources or how-to's there would be helpful.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
SYT_Shadow11517.00 |
01-04-2018, 12:49 PM | #54 |
2435
Rep 11,669
Definitely interested in the feedback you get from driftflo.
Like you I do a LOT of my own work. ......I'll be doing my own rod bearings this spring. However, Setting up a dif properly is not something I would be comfortable with. I had to stop watching that vid..... There are sooooo many things that are wrong with his methods it isn't funny. .....starting with working on the garage floor
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 01-04-2018 at 05:38 PM.. |
01-04-2018, 04:13 PM | #55 | |
469
Rep 280
this guy has no idea what he is doing there... installing a lsd (or even worse, a new gearset or pinion bearings) is no easy DIY! besides a lot of knowledge and experience you also need a number of special tools AND some sets of shims (and/or a surface grinding machine) to adjust bearing preload and backlash. here are picture documentations of some lsd insallations i did (in german language... but the pics may help anyway): http://www.limitedslip.de/service/einbau.html (click on the accoring picture to see the full installation of this unit) these are no step by step tutorials but you may get a little insight of how it is done. i did over 1.000 installations during the last 7 years and i had a lot of diffs here to fix the issues caused by diy-installers or workshops that also underestimated the task. i always suggest to have the work done at a shop that does a lot of the type of axles that you want to have modified. if someone has the knowledge and tools to set nissan diffs he will fail in setting a lsd rear axle as tools and shims to set the bmw axle will be missing. and when buying a lsd or differential parts ask the dealer if he will provide the necessary information like bolt torque values, backlash, friction torques... if not, don't buy it there... he will not be able to help and guide you during installation and afterwards. @mobbin: got your email and try to answer as soon as i find time. at least i already read the whole email from top to bottom ;-) Last edited by driftflo; 01-04-2018 at 04:21 PM.. |
buddalun683.00 |
01-09-2018, 10:21 PM | #56 |
1478
Rep 2,672
Thought I would share a few pieces of information regarding the OE GKN Visco Lok differentials that came in our cars.
GKN Visco Lok Tech Sheet, LINK. Apparently 2008-2010 Dodge Vipers also used a GKN Visco Lok differential and this link has some interesting information regarding the recommended fluid for the Viper version, LINK. You guessed it, Castrol Syntrax Limited Slip 75W-140, pre-configured with the right amount of fm additive for a GKN Visco Lok diff! I emailed GKN Driveline to see if they would recommend this same fluid for our cars but haven't heard anything back yet. Since I plan to visit COTA a few more times before I trade out my diff, I may as well try the Castrol Syntrax fluid out first (my car currently has the BMW SAF-XJ fluid with FM Booster). Will report back. And thanks driftflo for recommending this stuff in the first place.
CSBM52756.00 |
03-01-2021, 09:22 PM | #59 | |
2646
Rep 2,145
Drives: 2011 E92 M3
Perhaps some day I will adjust the carrier to have a 4 clutch setup with 50/65 ramps. In no rush. Regardless, it is a fun journey. Cheers,
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
Move Over1261.00 |
