ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      04-14-2016, 12:15 PM   #45
M-terkait
M-terkait's Avatar
Kuwait
211
Drives: F30 335i 3/13
isn't 305 R888 are just too much traction ?
i used to have 245/40/18 on my F30 R888 and it was amazing i never thought it could use more traction.
Docrace 6266
      04-14-2016, 12:17 PM   #46
Mandi90TT
Drives: BSM 6MT M4 F82
The F8x has....just a little bit more torque/hp than the F3x
2015 Black Sapphire Metallic 6MT M4
      04-14-2016, 01:09 PM   #47
wkndracr
wkndracr's Avatar
Drives: '10 135i
Originally Posted by ///Machiavelli View Post
How come you put weights in the rim?
Is that a thing? I've had r-comps used strictly for autocross and didn't bother balancing, but I would think at higher speeds on track you would want the wheels balanced to prevent excess vibration. My track tires are NT-05s that I plan to use to drive to the track so I would want them balanced anyway, but curious about any advantages of leaving the weights off.
      04-14-2016, 01:32 PM   #48
Drive4Fun
Drive4Fun's Avatar
Drives: MW BMW M4
Originally Posted by FLOSS M
Has anyone tried a full slick R7 etc.... sizes ?
I ran these last time out
      04-14-2016, 06:49 PM   #49
nicknaz
nicknaz's Avatar
3189
Drives: C6Z
how did you get the 295 to fit in front? I thought 275 was max? lowered + static neg camber?
      04-14-2016, 07:02 PM   #50
Drive4Fun
Drive4Fun's Avatar
Drives: MW BMW M4
5mm spacer to clear spring perch on the JRZ's. -3.7 camber but you could run less and still be ok. I'm not super low tho. Could probably go another 1/2" lower before any rubbing starts.
      04-14-2016, 07:03 PM   #51
CanAutM3
CanAutM3's Avatar
21132
Drives: 2021 911 turbo
295/30R18
Small aspect ratio on an 18" wheel will yield a rather small overall diameter.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      04-14-2016, 07:19 PM   #52
Drive4Fun
Drive4Fun's Avatar
Drives: MW BMW M4
Strut to wheel clearance on driver side was 3mm less than the passenger. I found that a little weird. Yeah the 18's are not as tall and allow you to fit a wider wheel. Btw I only have 4mm clearance without any rubbing. I set the pressure to 35 cold and found a nice even temp across the tire with -3.7camber and 45lbs hot. Tomorrow I'm shooting for 46 front and 45 back tho. Outside of the tire was a little more worn and camber is maxed. Hoping that small bump helps.
      04-14-2016, 11:43 PM   #53
///Machiavelli
Big Mac
///Machiavelli's Avatar
121
Drives: MY16 F80
Just easier to deal with and a luxury of a dedicated track wheel/tire.
I had a dual use setup on a previous car and during a Watkins Glen event I lost the weights in 3 of 4 wheels as the heat generated from braking melted the adhesive. I subsequently put foil tape over the weights but its not very aesthetically pleasing for the street (+1 RICE mod cred?) and its a bitch to get off when you need to rebalance a new tire.
After a couple sessions on track my wheel wells would begin to fill with marbles/melted rubber, so no longer properly balanced anyhow.
      04-15-2016, 08:40 PM   #54
CanAutM3
CanAutM3's Avatar
21132
Simply cost savings and avoiding having weights flying around.
My track tires wear down so fast and pick up so much junk that balancing them is pretty much useless.
I am assuming that is why ///Machiavelli was nagging me, because I said that I don't bother balancing my track wheels in another thread, and he spotted the weights on my wheels in this thread.
      04-18-2016, 06:59 PM   #55
lifebimmer
9
Drives: M4 2015
So 18x11 rear, what wheels did you put in front? Read the previous posts, does not seem to be mentionned.
Thanks!
      04-18-2016, 10:56 PM   #56
FLOSS M
///M3
FLOSS M's Avatar
387
Drives: 22 M3 X-Drive
18x10 et 25 ec-7
      04-19-2016, 12:31 AM   #57
lifebimmer
9
Drives: M4 2015
Would the 315/30/18 fit the 18x11 +44 Apex EC-7 (rear)?
305/35/18 or 315/30/18 Nitto NT01?
      04-19-2016, 05:25 AM   #58
CanAutM3
CanAutM3's Avatar
21132
Thanks!
Same here 18x10ET25 EC-7.
      04-19-2016, 05:26 AM   #59
CanAutM3
CanAutM3's Avatar
21132
Apex successfully trial fitted both sizes for the R888.
      04-19-2016, 10:32 AM   #60
lifebimmer
9
Drives: M4 2015
Thanks for the info
      04-21-2016, 03:10 PM   #61
xander85
Drives: 2015 F80 White, 6MT
It seems most are going for the 305/35/18 tire choice on the ec-7 11" wheels. I just ordered these wheels and am trying to decide what size NT01's to go with. What are the benefits of going with 305/35/18 over the 315/30/18? Thanks.
      04-21-2016, 03:37 PM   #62
adc
Drives: 2018 F80 M3 ED
I can tell you why I've chosen 305/35 with 275/40. They have similar diameters so the car's electronics won't throw hissy fits , and they maintain a reasonable level of stagger between front and rear.
My car is stock power-wise, and I didn't want too much tire at the rear compared to the front. With NT01, I believe the next size "down" from 305 or 315 is 275, and I thought 275/315 would have too much grip at the rear compared to the front.
It's nice though that they make the 275 in both 35 and 40 profile, meaning you can put a 275 front with either 305 or 315 rear. (There is almost 1" difference in diameters between 305 and 315 so you have to match the front diameter as well).
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      04-21-2016, 03:38 PM   #63
CanAutM3
CanAutM3's Avatar
21132
A better balance of rolling diameters. A 275-305/35R18 combo keeps things relatively closer to stock
      04-21-2016, 03:46 PM   #64
CanAutM3
CanAutM3's Avatar
21132
As I posted above, it is the 275/35-305/35 combo that keeps things the closest to stock. With a 275/40 in front, you are reversing the diameter stagger with a larger tire in front. The 315/30 is just too small IMO. For reference, tire diameters for 18" wheels:
255/40 PSS 26.0"
275/40 PSS 26.7"
275/35 NT01 25.6"
275/40 NT01 26.7"
305/35 NT01 26.4"
315/30 NT01 25.4"
      04-22-2016, 10:27 PM   #65
tchiers
63
Drives: 2016 F80 M3
Originally Posted by FLOSS M View Post
I tried out the 18x11 et44 with 305/35 R888 this past Sunday. Very stable and good grip. Very slight rub on passenger fender liner, drivers side no rubbing. My car isn't lowered and has factory EDC, non comp package - I ran with sport plus for suspension setting.
I'm running the same setup, and I, too, liked the R888s the first weekend out.
The 2nd weekend, not so much. The fronts were already heat cycled out, and I battled horrific understeer all weekend. I was down 4s/lap by Sunday afternoon, and 3 of the 4 were corded at that point, anyway.
I'll admit I probably made it worse by driving to & from the event on the R888s, but I've done that before with those tires on my dedicated track car with no issues. I guess the stock setup on the F80 just works the fronts so hard, that heat cycling is a much bigger issue.
Still, that's $1K+ for a set of tires that gave me one good weekend and one lousy one. I will try something else next. (NT01, I guess. Not much to choose from if I want to stay in the ballpark of 305/35 in the back)
      04-22-2016, 10:38 PM   #66
CanAutM3
CanAutM3's Avatar
21132
I love the NT01 because they are practically immune to heat cycling. They might not be as grippy as fresh R888, but at least they maintain their grip throughout their life. In fact, I managed to do many of my "fastest laps" with cord showing on my NT01s .
f80post
