12-04-2023, 09:30 AM | #45 | |
2756
Rep 3,361
I'll have plenty of comparisons with the M2C and E90 M3 as they're staying put (planning on a potential M3 auction in the spring though). I ordered the 792M staggered wheels, so 225 and 255 on 8" and 8.5" -- which to me is still stupidly undersized for the car's weight and especially power. 20 years ago when I bought an E46 330i ZHP it came with the same size wheels/tires (although 18" instead of 19") with probably 1/2 the whp and a lot less weight (6MT, slicktop). Heck even our beater E91 328i wagon is running Apex 9x18 with 235/40s. I too am already pondering a set of Apex wheels for the M340i...was looking at 9x19 with 265/35-19 all around. My M3 is running 9.5/10.5x19 with 255/35 and 275/35-19. The M2C is still on stock 9"/10" 245/35 and 265/35-19.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
12-04-2023, 10:42 AM | #46 | |
2277
Rep 1,699
My current project is upgrading the sound system as the stock HK is not great (although the stock M2C HK I found offensively bad). Not sure if you care as much about audio but that's the other clear area outside of tires the car can be easily improved. |
CSBM52756.00 |
04-24-2024, 06:49 PM | #47 |
Rep 6
Coming from 2019 f22 240 to 2020 m340i
I find the newer sport mode idrive options to be a bit gimicky in comparison to the older idrive. Whether the suspension and steering options make any difference I can't say. What I can say is full Sport+ is awesome for hammertime and anytime downshifting. Upshifting during spirited but not hammertime can rev to painful points like "why isn't it upshifting?!" Thanks for shedding some light.. I'm going to set individual sport mode to sport+ engine and sport tranny for spirited daily driving which is anywhere I can get away with massively exceeding speed limits on the way to work! Oh and hammertime for me is either a drag race or track time which I've only done in the 240.
04-24-2024, 11:46 PM | #48 | |
19
Rep 46
Had my 2024 M340i for 2 months now and didn't love the adaptive suspension as it feels under-dampen. Recently switch to much lighter wheels for summer and it's a totally different car now.
The lighter unsprung weight now seems to match the dampers just right, not overwhelming them. Really plush in Comfort mode now, less bouncy than before. Sport mode now feels like sport, stiffer then the M sport suspension from what I recall. Something to consider. Very easy to add M1/M2 buttons to the steering wheel for easy drive mode toggling. Added magnetic paddles and a matte carbon face too while I was at it. Looks real slick now and gets me in the mood every time I get in the car. Makes Sport+/S mode manual shifting so much more fun now. Quote:
04-25-2024, 11:55 AM | #49 | |
102
Rep 155
04-25-2024, 12:12 PM | #50 | |
3008
Rep 6,069
04-25-2024, 01:13 PM | #51 |
19
Rep 46
New wheels are Superspeed RF05RR 19x8.5 / 19X9.5 (19.6 / 20.8 lbs)
Stocks are 792M (28.4 / 30.6 lbs) M1/M2 buttons from here for example: https://infiniteautowerks.com/shop/i...m1-m2-buttons/ I took a chance getting everything from AliExpress and it all worked out. Youtube is your friend for installation. |
04-26-2024, 12:00 AM | #52 |
19
Rep 46
Not sure if it's mentioned but shifts are faster with Sport+ too it feels like, on top of the higher RPM shift points. It still feels slow going into 2nd though, unlike the higher gears.
Looks like the xHP transmission tune will be a good thing as you'll be able get more aggressive shifts and able to reprogram the stock D and S shift points to your liking also for the different modes. Based on what I've read anyway. |
04-27-2024, 09:10 PM | #53 | |
3008
Rep 6,069
04-28-2024, 09:40 PM | #54 | |
102
Rep 155
04-29-2024, 12:06 AM | #55 | |
3946
Rep 4,255
i flashed the software from Xdelete and my car is a different car in sport plus (remains very tame in sport and comfort) |
04-29-2024, 04:08 AM | #56 |
94
Rep 126
Wait, is this really a thing? I scared the hell out of myself the other day in my EU M440i xDrive. It was raining outside and I wanted to show a friend of mine how the artificial Iconic Sounds in Sport Plus sounded, so I hit the throttle and went sideways. Did not expect that at all.
04-29-2024, 04:36 AM | #57 | |
3946
Rep 4,255
then i flashed XDelete (tuner tells me it flashes their "Stock" software onto my car and overwrites mine. guarantees it's a "stock" copy.) well my car was going sideways and trying to launch it was spinning 4 wheels like crazy. sport plus only. i don't know what they flashed but it was worth it. |
04-29-2024, 02:27 PM | #58 |
19
Rep 46
Front 19x8.5 ET25 5x112 CB66.6 (8.4mm poke vs. stock)
Rear 19X9.5 ET42 5X112 CB66.6 (10.7mm poke vs. stock) No spacers. Looks perfect to me as I'm am not a fan of wheels poking out too much. Only downside with these wheels is they come in black only for those sizes. Wheel weights from website. I've seen actual weights somewhere and they're within range. The difference is also really noticeable under acceleration / braking. Last edited by phanamous; 04-29-2024 at 02:35 PM.. |
SevenNine101.50 Motorwerke_man28.50 |
04-29-2024, 03:32 PM | #59 | |
102
Rep 155
You don't have lowering springs, right? This is stock height? Also, when you say "poke vs stock" you mean that the ET of the wheels is like having 8.4mm/10.7mm spacer? I checked the website for info on the wheels and options. I like these wheels, so now I'm debating between those and the stock A90 Supra 19x9/19x10 wheels. They would be cheaper, if bought from Supra owner, but they are around 24-25 lbs. So lighter than the stock 792m, but heavier than your wheels. |
04-29-2024, 05:38 PM | #60 | |
19
Rep 46
Yes. ET is like having 8.4mm/10.7mm spacers.
Black complements nicely the black shadowline bits on this car. Hoping they'll have their Gunmetal soon, to better hide the winter salt/dirt, as I'd like to get another set for winters. Stock height with adaptive suspension. G20's suspension isn't very well tuned as the springs seems very linear making the ride not very compliant. These lighter wheels help to make it a bit more plush. Don't know if it'll do the same for the non-adaptive suspension though. If suspensions are tuned well to the stock wheels weight, switching to lighter wheels tend to make the ride more choppy and worse. Likely will get Dinan springs as they're more progressive based on the feedbacks. Quote:
04-29-2024, 07:22 PM | #61 |
3946
Rep 4,255
Not my experience, I mounted 8kg 18"x9 wheels on mine with mildly stretched 245 40 18 pilot sport 4 and the car turned into a compliant cushioned race car
04-29-2024, 07:58 PM | #62 | |
3008
Rep 6,069
05-04-2024, 09:18 PM | #63 |
Zach
1053
Rep 46
Drives: 2019 330i xDrive
sport+ does keep RPM’s higher compared to normal Sport mode. Sport+ burns way more fuel but you get more pops and bangs. give or take i average around 22 MPG monthly in a stock G20 330i (B46 4 cylinder). Really only drive it in Sport+
05-05-2024, 12:21 AM | #64 |
3008
Rep 6,069
They finally enabled sport plus on the b46 or did you code it?
05-05-2024, 06:51 AM | #65 |
Zach
1053
Rep 46
i coded it using Bimmercode. i reccomend anyone picking it up and coding it on if they have a B46
05-05-2024, 07:02 AM | #66 |
Zach
1053
Rep 46
also, does anyone know why they disabled sport+ for NA G20 330i’s?
