N52 Rough Idle / Performance Issues
01-29-2016, 08:12 AM | #45 |
714
Rep 2,607
Drives: 06 330i E90, 18 530xe G30
I would have your tech pull the large DISA valve and see if it has failed. When it goes there are no warning lights. Its a simple check and worth looking into especially being that you have checked everything else!
03-20-2016, 08:22 AM | #46 |
41
Rep 210
Drives: F30 320iA M Sport
Well, i get no more errors but the car still has the shakes. Could it be a vacuum leak somewhere?
Bmw e46 320d '04 - Sold
Bmw e46 330ci '01 - Sold Bmw 3-er e90 325i '06 - Sold Bmw 3-er e92 325xi '08 - Sold |
03-22-2016, 09:02 AM | #47 |
19
Rep 595
Do you have diagnostic software? There is a fairly easy method of finding vacuum leaks with it. One thing you are going to notice is your AFR will be affected by a vacuum leak. To take advantage of this, simply spray brake cleaner(carefully!) around your vacuum hoses. If you have a vacuum leak then your 02's will spike rich for a few seconds rather than constantly switching between low and high. Under normal circumstances your 02 sensors will switch constantly. A lazy 02 sensor (one not constantly switching) is a bad one. Even if you don't have diagnostic software I recommend either finding a friend with some or getting some yourself, you can find some budget oriented solutions if you look around.
03-25-2016, 03:11 PM | #48 |
Rep 30
Just started reading this.
I think the camp proposing the o2 sensor(s) may be correct. It was my instinct on the first post when you mentioned it gets erratic AFTER it warms up. Most cars don't reference the o2 sensors for the first couple of minutes because they have to be heated before they can take accurate measurements. This is why, for those that have an AFR gauge, it won't start reading for a couple minutes. After that, the car makes air and fuel choices in part on what the o2 sensors are reporting. If one or more is giving bad values, then your car is not going to run right. I'm a recent 328i owner and most of my experience is working on old porsches. In this case we would unplug the o2 sensor wire to see if the idle evened out. The car does not need an o2 sensor to run - it is for emissions. If it were my BMW, i'd start the car and unplug the o2 sensors one at a time and see if I could find the culprit. No doubt your car will throw codes, but I suspect it would work. Last edited by raleighBahn; 03-25-2016 at 03:18 PM.. |
03-25-2016, 03:48 PM | #49 | |
Rep 30
Why does this matter? Because if you know which sensors are running in Open Loop, and your car runs fine in Open Loop, then all of those sensors are likely good. You can narrow your focus to the sensors that come online in closed loop. And the inverse is true. If your car runs bad as soon as you start it, and the problem is a sensor, you can focus on the small amount of sensors that run in Open Loop. Hope this helps. Last edited by raleighBahn; 03-25-2016 at 04:02 PM.. |
05-17-2016, 08:48 AM | #50 | |
41
Rep 210
Also i'm guessing the post cat o2's are reading the catalyst conversion or is there a separate sensor monitoring the cat?
05-17-2016, 09:03 AM | #51 | |
624
Rep 3,201
Drives: E92 325i MSport Coupe
http://www.pelicanparts.com/BMW/tech...eplacement.htm
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
05-19-2016, 11:24 AM | #52 | |
41
Rep 210
I'm starting to blame the Maf for these issues and i think i changed the injectors for nothing
05-19-2016, 05:48 PM | #53 |
200
Rep 1,834
Drives: '05 E90 330i Manual
Try and see if you can't borrow another MAF before forking out for a new one that may or may not sort this out. I have thrown lots of money at my car's problems and also suspected a MAF issue, replaced with a new one, no difference. At least now I have a spare one, but money wasted in my case.
06-22-2016, 07:37 AM | #54 |
41
Rep 210
To update everyone on the parts changed to fix the issue:
Coils - slight improvement, jerk/shake still there Plugs - no improvement Injectors - Slightly better start-up, minor improvement Solenoids - fixed errors, slightly better in regards to the shake but still present MAF - fixed jerks, misses in acceleration and shifting. Overall i am happy the car is a beast again, thanks to everyone who contributed here.
06-22-2016, 08:37 AM | #55 |
31
Rep 331
Yeah I think I am having the same issue. I tried to clean the Vanos last weekend but its starting again. If it throws another code I might as well just buy them.
2008 Monaco Blue 328i Sedan / Charcoal Delete / K&N Drop In Filter / RM Intake Boot / AA Tune
1993 MR2 |
06-22-2016, 09:55 AM | #56 | |
71
Rep 246
06-24-2016, 09:53 AM | #57 |
77
Rep 330
Same problem??
Idle "dip" and light throttle hesitation http://www.e90post.com/forums/showthread.php?t=1275479 |
06-29-2016, 05:39 PM | #58 |
41
Rep 210
Back to the drawing board, hesitation is still there at low rpms and stumbling/shaky idle when RAINING.
So far replaced: MAF, coils, plugs, injectors, solenoids, air filter all brand new. What could it be? Could it be the cats? ESS?
07-09-2016, 06:41 PM | #59 |
41
Rep 210
Problem still persists even on warm starts it struggles to stay on and the car shakes. O2 sensors are fine, took it to three different mechanics and they are all confused.
One mechanic mentioned some "ambient" sensor as he checked using INPA and it was above 1000? He told me to take the car when it has the "issues". Btw car violently shakes when it rains... this problem is tiring.
07-10-2016, 03:46 AM | #61 |
41
Rep 210
07-10-2016, 04:59 PM | #62 |
41
Rep 210
Update:
My PRE-cat lambda sensors voltage is 2V. Post cats are 0.7. From what i understood it should not exceed 1 in voltage or it's bad, is this true?
07-10-2016, 08:10 PM | #63 |
181
Rep 657
This whole rough idle has got to be caused by some air flow issue. Between all of us we have replaced or repaired all plugs, solenoids, and injectors. I am going to tear down my intake again and see if that helps get my AC off idle above 600.
07-11-2016, 01:03 PM | #64 |
41
Rep 210
Ordered two lambda sensors, if this doesn't fix it i'll probably go nuts and sell the thing.
07-11-2016, 02:30 PM | #65 |
1645
Rep 2,494
I'm in a similar boat and have been trying to chase down the source of 2 specific codes that keep coming back
2A2E 2A2F All these codes tell me is "fuel mixture control, bank 1 & bank 2" respectively. To date I have changed: Air Filter MAF Sensor Oil and Oil Filter (2x) Spark Plugs Ignition Coils VANOS Solenoids Entire PCV system Both DISA valves Intake Manifold gaskets Throttle Body gasket Pre-cat O2 sensors ...all with no resolution. Car smoke tests fine, car drives fine, but this light on the dash persists. Getting desperate here, any suggestions?
07-11-2016, 08:51 PM | #66 | |
181
Rep 657
http://www.pelicanparts.com/BMW/tech..._Replacing.htm |
