09-11-2017, 02:59 PM | #45 |
461
Rep 2,093
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
can you tell me if those codes came up and stayed up? or did they go away and come back? I have similar codes...and similar symptoms....$200 seems a lot better to me that throwing $$$$$ at random fixes/repairs
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021 |
09-11-2017, 03:19 PM | #46 | |
3487
Rep 3,722
Should also mention I just went on an 800 mile road trip and had no issues
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
05-01-2018, 01:47 PM | #47 |
461
Rep 2,093
F me I just got same symptoms and code 2eof f my life.
Surging Boost seems to be leaky My boost gauge is showing boost when the turbo isn't even spooling
05-01-2018, 04:19 PM | #48 |
461
Rep 2,093
Your thread seems to be the death of ME as my car is following in your footsteps here...FML!
Just picked up car from body shop, assuming they disconnected the battery as always, initially had 10 faults...cleared them, ended up with 1 that came back. it is: bmw 2E0F valvetronic system deactivated excessive adjustment error hoping this is just a DME update to fix? any advice? i dont wanna f around with more $$ in repairs, im about to crash this car into a telephone pole its taken years off my life
Speedytech71.00 |
05-15-2018, 07:38 PM | #49 | |
3487
Rep 3,722
05-21-2018, 06:12 PM | #50 | ||
461
Rep 2,093
05-21-2018, 06:58 PM | #51 |
3487
Rep 3,722
Glad to hear it!!
03-06-2019, 10:16 AM | #53 | |
3487
Rep 3,722
https://www.tsbsearch.com/BMW/SI-B12-36-15 You should be able to talk to your SA and give them the details you have and they can look up the TSB. They can't fudge anything if you have the facts.
CivicDuty51.00 |
03-11-2019, 03:58 PM | #54 |
20
Rep 83
CivicDuty - I'm having the same 2E0F code on my 2012, along with a couple other Valvetronic codes that seem to come back intermittently:
2DCE - Valvetronic system: No adjustment possible 2DD0 - Valvetronic system: Control deivation warning threshold exceeded 2E10 - Valvetronic system: deactivated, warning threshold, control deviation exceeded too frequently 2E11 - Valvetronic system: bottom limit position learned My symptoms include rough idle for ~20 seconds on cold starts (engine would crank normally and rev up to ~1600 rpm, start to settle toward idle, then rev back up again, repeating this process a few times before finally idling normally) and occasionally would even stall on cold starts. Have you experienced anything similar? Also noticed you're a fellow Ontarian so please do let us know how the dealer visit goes! |
03-12-2019, 06:44 AM | #55 |
51
Rep 55
@OneWhite35 I haven't had any of those other codes. I did have a code relating to Valvetronic Sluggish Movement but after clearing that it has been replaced with the 2E0F.
I was getting a stumble on cold start at about the 20-30 second mark but that has pretty much gone away. I must say that I was also having some other faults like the radio defaulting back down to 88.9 in the morning and on 2 occasions I had the car on lift symbol with excessive discharge noted. I replaced the battery and those problems went away along with the stumble on cold start albeit it has occurred once since the battery change. I'm really torn as to whether I should go to the dealer. I actually have an appointment for tomorrow. It's $179 for a diagnostic ugh. Of course, to confuse things further, the car has been running like a champ lately. I don't know if 2E0F is a code that stays active or just an indication of the valvetronic being disabled at some point but returning to operation if it can. I'm considering canceling my appointment and monitoring for a while longer. |
03-12-2019, 07:39 AM | #56 | ||
3487
Rep 3,722
Additionally you could try cleaning out the VANOS solenoids, it's actually not difficult at all they're right up front and can be cleaned easily.
CivicDuty51.00 |
03-12-2019, 08:10 AM | #57 |
51
Rep 55
@Matticus91 I've had the car for about 1.5 years. Don't know if it's been flashed. Never been to the dealer since I've had it.
I suspect it has PPK1, how do I make sure I don't lose that if they flash it? If I take it for the diagnostic wouldn't the reflash be covered by that TSB? Thanks for you suggestions!! |
03-12-2019, 08:21 AM | #58 | |
3487
Rep 3,722
CivicDuty51.00 |
03-12-2019, 12:57 PM | #59 |
20
Rep 83
Matticus91 What did you specifically ask for when you went to the dealer to get the car re-flashed? My car had a full dealer re-flash last summer (when I replaced my fried FRM module under warranty) and also an ECU tune from MHD. I'm thinking re-flashing my ECU with MHD to see if that "resets" it.
CivicDuty In regards to other strange behaviour, there was one instance where my blinker settings defaulted back to one blink instead of three... but I don't think it's related to 2E0F. |
03-12-2019, 01:54 PM | #60 |
Loves me some MHD!
1866
Rep 1,726
CivicDuty are you N54 or N55?
I ask because the N54 PPK's were dealer only, where some N55's can have the PPK done just using the standard set of BMW software we all have...
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
03-12-2019, 03:48 PM | #61 |
51
Rep 55
03-18-2019, 05:02 PM | #63 |
Loves me some MHD!
1866
Rep 1,726
me too me too
So what happened?
1and1
03-18-2019, 05:13 PM | #64 |
51
Rep 55
Hey Guys, sorry. I cancelled my appointment as I had a work thing come up. Maybe that happened for a reason.
Anyway, still have the occasional rough idle after about 20 seconds on a cold start. Will keep you posted if something definitive happens. |
03-19-2019, 09:32 AM | #65 |
20
Rep 83
Interestingly, my issues with cold starts (stalling, rough idle) seem to have went away last weekend. I got an oil change, put in some BMW fuel system cleaner (essentially rebranded Techron), and reset all my adaptations through the MHD app. It's been a week and a half with no issues.
When was your last oil change? What fuel do you use (I use Ontario Esso 93)? Perhaps it may have been some buildup in the fuel lines mixed with the cold weather. |
03-19-2019, 02:02 PM | #66 | |
51
Rep 55
