08-04-2022, 11:33 AM | #45 |
8319
Rep 16,200
I've driven through 6 to 8 inches of unplowed snow no problem, but I wouldn't try it with a foot, not so much being concerned with how my car will handle it than how every other vehicle won't. Even when we get four inches the roadsides are littered with SUVs whose drivers think that AWD will handle anything. It won't.
08-04-2022, 12:13 PM | #46 | |
31
Rep 46
P.S. Thanks for answering my various questions across the forum this morning! |
08-04-2022, 04:29 PM | #47 | |
115
Rep 141
xDrive uses a transfer case that is electronically controlled to route power to the front wheels, I believe it has 40/60 torque split normally, and will lock at 50/50 for traction limited environments, and be 0/100 under higher cruising speeds. I've noticed it feeling more RWD at this point and wish there was a way to monitor the lock up percentage of the transfer case in real time.
2014 328i xDrive M-Sport EBII--M-Performance BBK/LSD/Aero--AA Signature Exhaust--Bilstein B6 DampTronic + Eibach Springs + H&R Swaybars + Millway Street Camber Plates + M3 Bump Stops + Dinan Shockware--Apex ARC-8 18x9.5et35+12mm Front Spacers w/Kumho Ecsta V730 275/35--FL-5/EC-7 18x8.5et35 w/Pilot Alpin PA4/Hakkapeliitta 10 Studded 245/45--BavSound Stage 1+Ghost Subs
CincyBearcats30.50 |
08-04-2022, 10:42 PM | #48 | ||
4553
Rep 5,413
Drives: 2015 BMW 335i x-Drive Auto
Second place is probably the 1983 (first year in US) VW GTI 5-speed that I modded and flogged around the streets. Not the power of the BMW, but still a very high fun quotient. The aftermarket M Performance LSD was built primarily for RWD guys who tracked their cars. Discounted they cost $2,300 plus about $600 for installation. In 2019 BMW suddenly held a worldwide fire sale for $600 on the MP LSD for the F30 335i/ix Automatic Transmission model. So there are many of those models on the road with MP LSD's. The stock F30 uses an electronic system that measures slippage at each rear wheel. If it senses >30% slippage at a wheel it has the ability to apply the brake at that wheel. I believe it can even cut throttle if rear wheel slippage is too high. Note: Cars that experience greater than normal rear wheel slippage can result in extra rear brake wear. The M Performance LSD is a mechanical system. It kicks in at 1% slippage at a rear wheel and disengages at 19%. When it senses slippage at one rear wheel it transfers power to the other wheel than has traction. It's a quite ingenious system. The standard electronic system and the mechanical LSD work seamlessly together without either of them "knowing" about the other's existence. There is no overlap. So the MP LSD is installed and no programming or coding is needed at all. I noticed the MP LSD immediately the first time that I entered a curve. The car just locked in and I was able to quickly power into and through the turn. Apparently with the stock differential, there must be a certain amount of slippage at the rear wheels, up to 30% when the electronic system would kick in. That all goes away with the MP LSD. It feels like I have more power into curves because the LSD is putting more power down to the rear tire that has the most traction. There was an incident where I really appreciated the MP LSD. I entered a long circular curving on-ramp onto an interstate highway. I was going normal speed when a Camaro flew up onto my rear bumper. I nailed the gas and blew way ahead of him in the first half of the curve, but as I accelerated into the final part of the curve, my outside tires hit a heavy patch of gravel that had accumulated. Rather than slide off the road, I could actually feel power go to my inside rear tire, so I was able to just power out of it onto the highway straightaway. The Camaro must have been impressed. When he caught up later he rolled down his window and gave me a first pump. |
08-04-2022, 11:17 PM | #49 |
31
Rep 46
Thanks for the very detailed responses! I have much to learn. It sounds like I need to keep an eye out for an M Performance LSD. $600 is an amazing deal if they can still be found at that price point.
08-05-2022, 01:37 AM | #50 | |
4553
Rep 5,413
https://www.getbmwparts.com/c-differentials-92 |
08-06-2022, 12:31 AM | #51 | |
115
Rep 141
What the differences between the two are I could not tell you. Maybe FaRKle! would know? You will most likely have to go the Diffsonline route as well if you really want to get a rear LSD for your car.
08-15-2022, 11:00 PM | #54 |
Rep 12
08-16-2022, 08:44 AM | #55 |
2264
Rep 2,055
The BMW X drive system is the typical modern slightly wanky pretend 4wd system aimed to put power down on wet roads but it does do a passable job in day to day driving. The rear bias is quite good fun when you want to do that in the snow but when the snow gets proper deep it does lack the strength of a proper permanent 50/50 which has a centre diff. The transfer case is the biggest issue in the BMW system because it doesn't have a diff in it, hence all the blown units.
As long as the snow isn't sticky and wet though then you should be fine in deep snow, just as long as you don't actually beach it. I've got Sottozero's on mine and had it up to 18-24" powder with it pouring over the bonnet and it was fine. The biggest issue was the narrow 10ft wide ribbon of single track tarmac that was twisty and had ditches either side. |
08-16-2022, 09:13 AM | #56 | |
4553
Rep 5,413
I live in NJ/Philadelphia so I have good winter advice for people living here. But my family in Vermont have a much different winter road experience. They also have local regulations about the use of chains and studded tires. |
08-16-2022, 12:02 PM | #57 |
8319
Rep 16,200
I live in New Hampshire, where we get snow from October through April. I drove to my ski shop in the mountains 5 days a week for 25 years, in all weather conditions. I never missed a day, and never had chains. Never had AWD either, I got my xDrive after I retired.
Operator Mo64.50 |
08-25-2022, 03:32 PM | #58 |
Rep 33
I legitimately have more fun driving in the snow than in the dry in my car ( 15' M235XI). I used to live in Michigan and I've taken a ski trip to the mountains in Colarado.
I'm running X ice 3 on 17's and at normal speeds i can barely even tell I'm on snow. In Sport+ or DCS off it's very easy to get the back end to step out, but the car effortlessly levels out if you give it gas. And I don't have the LSD, though that's down the line. |
12-07-2022, 02:12 PM | #60 |
23
Rep 31
In Alaska and coming from a Subaru I can say the Xdrive is very capable. I am having the M Performance LSD installed this month tho. Can't Hurt!
12-07-2022, 07:14 PM | #61 | |
5949
Rep 10,325
12-07-2022, 07:43 PM | #62 | ||
4553
Rep 5,413
cfm56d7b5948.50 Operator Mo64.50 |
02-09-2023, 07:22 PM | #64 | |
Rep 11
wow
wow this is great |
02-11-2023, 10:58 PM | #65 |
5132
Rep 6,337
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
Yes, just to reiterate, xDrive (not to include the FWD based designs) has a default distribution of power front to rear of 40:60 and is capable of sending 100% of the torque to both the front and rear axles in an infinitely variable distribution and doing so instantaneously such that the changes in distribution are imperceptible.
Skyhigh’s posts are so full of incorrect, misinformation they really should be removed from this thread.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
02-12-2023, 02:15 AM | #66 | |
1927
Rep 3,910
Thank you. Except my posts are based on technical data and understanding, yours - on marketing material ignoring absolutely key terms like “virtually” and failing to apply technical interpretation.
Food for thought: In the case of a rear axle spinning, there is “virtually” no torque getting to it as you need traction for torque. The axle remains connected with 50:50 torque distribution mechanically, but this is how xDrive “virtually” achieves 100:0 distribution of the available torque (close to 0 being utilised in the rear axle) for a split second, until traction is reinstated. And this is greatly used by marketing for people with no technical insight or understanding. xDrive as a system however CANNOT selectively send more than 50% to the front. This is mechanically impossible (fully closed transfer case clutch). https://www.carblogindia.com/what-is-bmw-xdrive/ Quote from the above source which is apparently also “full of incorrect” (or simply written by people with basic understand of mechanics) …: Quote:
Prove me wrong with a technical explanation about how 100% torque can be (selectively, not virtually) sent to the front or let’s agree to disagree and you keep dreaming.
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
