Aquamist HFS-4 Install DIY (Lots of Pictures)
06-22-2012, 09:08 AM | #45 |
she likes the flavor......
85
Rep 1,622
Thanks Ilma, next is to find a tank.
E92 Montego Blue silfa718 ..::STETT CAI|ADVAN RS|WAGNER FMIC|MS DP|VANGUARD|PROCEDE|FORGE DV|BMS OCC|KWV2|MICHELIN PSS|OOS::.. |
06-22-2012, 10:27 AM | #47 |
85
Rep 1,622
I ment a meth tank.
06-29-2012, 11:10 AM | #48 |
172
Rep 1,247
Does anyone know how to mount the failsafe in the ashtray? Is there a DIY for that because I want to put mine there. Ive bee searching but no luck. I just dont know what needs to come apart to get the wires up behind the ashtry.
2009 E92 BMW M3.
06-29-2012, 11:17 AM | #49 |
46
Rep 1,145
Just take the trim off and all will become clear.
06-29-2012, 11:19 AM | #50 |
172
Rep 1,247
Thanks for your response. Does all the trim just easily pop off then pop back on? Do I need to remove the entire center console or should I easily be able to install th failsafe in the ashtray after I take the trim off?
2009 E92 BMW M3.
07-05-2012, 10:31 PM | #51 |
45
Rep 473
Question where did you get your mounting bracket from I love the way it keeps the box nice and snug. Also have you had this kit running yet I have and the pump is surprisingly loud? The performance shop I went to told me it would be ok to have it running as long as I keep the flow on the low setting.(As I am not tuned for it yet, but will be this following monday)
Cobb JR Tune, HFS-4, DCI, AMS Intercooler, Vishnu CP, Forge DV's, AR DP's, RPI exhaust, AR OCC, BMW STS, Spec stage 3+ clutch, CDV delete, H&R Coil overs, Quaife LSD, DefiV Lock down kit, WOTbox.
-SOLD |
07-06-2012, 12:11 PM | #52 | |
52
Rep 1,497
07-07-2012, 09:05 AM | #53 |
45
Rep 473
Damm! I love that bracket maybe I can find something like it at home depot.
-SOLD |
01-09-2013, 04:03 PM | #54 |
34
Rep 715
Anyone used this tank?
Vargas S2 turbos|VAC S3 Cylinder head|RR DPs|RR MPs|Supersprint X pipe|Remus Quad Sport mufflers|aFe Stage 2 Si with scoops|Forge DVs|ER CP|BMS meth elbow|Aquamist HFS-4|Walbro 450 E85 LPFP|AA FMIC|BMS OCC|MHD|P3 Boost Gauge|Ohlins Road & Track + camberplates|M3 sways F/R+ Ground control endlinks|Vorsteiner v303 19"|Michelin PS2 sport|Quaife LSD|Vorsteiner V35 CF hood|CF CLS trunk|Duke Dynamics quad diffusor
04-23-2013, 03:52 PM | #55 |
34
Rep 715
Well , I bought it and its great !! Pump is fasten under the tank and is flush with it.
A level sensor can easily be drilled and fitted to this tank.
10-12-2013, 11:23 AM | #56 |
DIYER
614
Rep 5,521
Hate yo revive a old thread but need to ask a question. Did you use the headlamp switch for the gauge? If so, where did you tap in at? I was thinking of using the Orange ECU power wire in front for main power to controller but can't figure out how to tap in without hurting wire.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
10-12-2013, 11:24 AM | #57 |
DIYER
614
Rep 5,521
I rather do a turbo install than this again lol!
10-13-2013, 01:11 AM | #59 |
DIYER
614
Rep 5,521
as did I lol!
10-13-2013, 07:32 AM | #60 |
456
Rep 6,478
I still haven't gone through with my HFS install but when I was test fitting a few electrical parts it was clear there wasn't a "good" way to tap for it. PITA defined.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
10-13-2013, 12:51 PM | #61 |
34
Rep 715
Hehehehe , I installed mine this summer , had some talks with support about same issue.
I dont remember right now what we did , just that is worked like a charm after I had finished. Can look into some old mails ... hang in there
10-13-2013, 01:04 PM | #62 |
DIYER
614
Rep 5,521
I got codes....have all failsafe disabled and getting wastegate valve codes.
10-13-2013, 05:18 PM | #63 |
34
Rep 715
I missed one pin one the DME , luckily it was not in use the one I connected to , after fixing that , I had all systems go. I did twist my head a lot before I found the source.
Check all wires , connections , be 100% sure on everyone of those.
10-13-2013, 06:02 PM | #64 |
DIYER
614
Rep 5,521
As embarrassing as this is I will post what I did lol! When I slid in the connector it went into the wind groove causing the connector not to make contact with DME.
10-13-2013, 06:09 PM | #65 |
34
Rep 715
Hehehe , quick fix then , good one ! Feels good to figure it out And everything is working as it should ?
10-13-2013, 07:09 PM | #66 |
82
Rep 725
don't know anyone who has hooked up dimmer . and why would you want it anyway ? I like the Christmas tree effect
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
