Billet front diff housing with stronger gears
05-30-2017, 12:53 PM | #45 | |
110
Rep 1,340
05-30-2017, 10:52 PM | #47 |
9
Rep 75
I agree if our front end can hold 750-800 is a start
RIP10' A/W M-Sport-JB4-E85/93,50/50-BMS DCI-AR DP'S-Balck Kidney Grills-muffler delete-mm6 mesh18x8.5/9.5-Conti DWS 235/40 18, 265/35 18.
10'e90 a/w SportPackage-mhd e40 map- a/r dp's-vrsf charge pipe and tial blow off valve 95 civic-k24 block-k20 head-12.5:1 c/r pistons-drag cartel stg4 cams-ported rbc mani-q45 90mm tb-ssr headers- 3" exhaust, 300+whp, 2000 lbs. |
06-12-2017, 01:02 PM | #50 |
167
Rep 1,415
03-23-2018, 01:27 PM | #53 |
4277
Rep 9,209
03-23-2018, 01:32 PM | #54 |
167
Rep 1,415
Is the awd tranny the same as the rwd one? I thought I read somewhere they are different.
2007 335XI SEDAN // JB4 G5 // BMS METH KIT // VRSF DOWNPIPES // AFE DCI // ER CP W/ TIAL BOV // MMP SILICONE INLETS // XHP STAGE 3 AT FLASH // TREBILA BEF // BMS OCC // VRSF EXHAUST // FUEL-IT STAGE 2 LPFP // VRSF FMIC // PRECISION RACEWORKS IGNITION SYSTEM // CATUNED COILOVERS // CIC AND COMBOX RETROFIT //
03-23-2018, 01:37 PM | #55 |
4277
Rep 9,209
03-23-2018, 01:38 PM | #56 |
167
Rep 1,415
Man.....this is going to be an expensive conversion might as well go manual..... or maybe dct????
feuer4277.00 |
03-23-2018, 02:38 PM | #58 | |
4277
Rep 9,209
03-23-2018, 02:47 PM | #59 | |
167
Rep 1,415
03-23-2018, 03:35 PM | #60 |
79
Rep 538
03-23-2018, 03:36 PM | #61 |
79
Rep 538
I am currently running my AT rear diff with my MT trans swap. Works perfectly fine. However I do plan on changing it over to the M3 diff soon when I get time. 1st gear is a bit useless with the AT diff though.
03-23-2018, 03:54 PM | #62 |
4277
Rep 9,209
188mm diff from AT will not last long pared up to 6MT and tuned n54. That is the reason why 6MT came with 215mm diff. Maybe you have larger diff that was found only in early 335i AT
03-27-2018, 03:05 PM | #63 |
167
Rep 1,415
I have an 07 how much did you guys spend on the swap? Easy? I have a lift and tools.
03-27-2018, 03:06 PM | #64 |
167
Rep 1,415
03-28-2018, 09:53 AM | #65 |
79
Rep 538
I picked up my low mileage 6mt trans/pedals and lines/shifter assembly and the manual transmission wiring harness all for $1000 CAD. Then had a fun long search for the pilot bearing for the flywheel.. - Im using the Motiv twin disk clutch with the full face clutch discs. - Then you have to do some simple coding and reset/adaptation to some modules and loop some wires for the CANBUS and wire in the brake pedal switch. You will also need an MT accelerator pedal.
03-28-2018, 09:56 AM | #66 |
79
Rep 538
