07-01-2016, 09:38 AM | #45 |
Sameet
740
Rep 2,541
Drives: AY/B M4 '15
Getting my set from Alex@ACM next week.. I can't wait.
07-03-2016, 10:40 PM | #46 |
237
Rep 258
07-03-2016, 11:54 PM | #47 |
Supreme Allied Commander
3890
Rep 54,589
Drives: F80 M3
07-03-2016, 11:57 PM | #48 |
226
Rep 482
07-04-2016, 05:55 PM | #49 |
3890
Rep 54,589
Drives: F80 M3
07-07-2016, 10:11 AM | #51 |
300
Rep 507
07-07-2016, 07:44 PM | #52 |
739
Rep 1,066
Profile says he drives a 335i, does he have an f8X?
Formerly - "That Guy" in the purple BMW
07-07-2016, 09:05 PM | #53 |
544
Rep 1,338
Drives: Round n' Round
I believe if you are going to run the 1300 lb rear springs on the track then you had better ditch the 500lb front springs and step up to around 900lb fronts to get this system in balance. Otherwise drop the rear spring rate down to 800-900lb range and you'll be good for both the street & Track.
07-07-2016, 09:18 PM | #54 | |
226
Rep 482
Love me some internet forum genius backwater engineer wanna bees. Last edited by slavearm; 07-07-2016 at 09:23 PM.. |
07-08-2016, 03:53 AM | #55 | |
3890
Rep 54,589
Drives: F80 M3
Months of street, track and shaker rig testing derived at the current spring rates. Not from just trial and error or beta testers. I do understand some coilover manufacturers don't have the resources so trial and error, beta tester's feed back is all they can rely on. A couple of F3x reviews. I don't think the F8x reviews will veer off much: http://f30.bimmerpost.com/forums/sho...5&postcount=41 http://f30.bimmerpost.com/forums/sho...0&postcount=46 |
07-08-2016, 11:44 PM | #56 |
226
Rep 482
So... got them on and a few notes...
1. Ride is slighty stiffer in rear than my stock static dampers 2. Car actually seems to ride much better than stock. Smoother. So even though there is a bump, it is not a jolt anymore. 3. Rear end does not wiggle anymore. Not a great description, but when you used to jump on it with traction control off, the back end would wobble as the car sat back on the suspension. Almost non-existent now. 4. Height is awesome. Not too low at all even with my M performance lip. By the way... the team at Supreme is amazing. They had to track down a missing nut (seriously ohlins.... you suck at packaging... but make great suspension setups), deal with the fact that the OR/T sits out further than the stock suspension and was hitting my 275 width from tires on stock rims, deal with the fact that the TCK Camber plates don't seem to work right or fit right with this suspension, and stayed until almost 9PM to get everything back together after the hex tune and what not. I love those guys. Total pros and didn't try to wreck me for the install. |
07-09-2016, 08:55 AM | #57 |
300
Rep 507
I like your review. Thanks for posting it! I assume brake dive is a thing of the past now as well. Is this true?
However.... ...is somewhat alarming. How were they able to fix that? Do you think people with wider tires and rims will be able to run these coilovers? Last edited by Celestion; 07-09-2016 at 10:06 AM.. |
07-09-2016, 06:14 PM | #59 |
21
Rep 52
07-09-2016, 06:20 PM | #60 |
226
Rep 482
Yep. The way I see it, Ohlins owes me for about an extra hour of install costs due to the team having to track down a suitable replacement... and going insane thinking they may have misplaced it.
07-16-2016, 05:18 PM | #62 | |
3890
Rep 54,589
Drives: F80 M3
07-19-2016, 07:06 PM | #64 | |
293
Rep 1,015
Any chance you've played with the adjustments? Curious how these ride on rough roads, which NYC are full of. Thanks! |
