05-17-2022, 07:57 AM | #485 | |
1052
Rep 2,371
Drives: E63 645Ci
05-17-2022, 09:59 AM | #486 | |
Rep 47
If so. my unit did not react on that at all. The reason why I am tring to update. Is the hope that issues with google location services maybe resolved in never version. Unfoirtunately so far I was not able upgrade or even downgrade. Getting "update failed " no matter what I do. |
05-17-2022, 10:18 AM | #487 | |
1052
Rep 2,371
Drives: E63 645Ci
05-17-2022, 11:42 AM | #488 |
Rep 47
05-17-2022, 01:36 PM | #489 | |
Rep 12
If the LVDS connector has 6 pin it is a NBT. Also, CIC was on F30 until 2012, from 2013 to 2016 was NBT. If you buy a CIC model aftermarket HU you will receive a 4 pin LVDS cable and will not work on your unit. The 2 additional pin on NBT is for Power…so i believe it will not power on your unit. Good luck! |
05-17-2022, 04:45 PM | #490 |
Rep 11
Hi everyone. I have a 2015 RHD F36 with NBTEVO pro nav. I'm looking to replace my screen with an android version. Can anyone recommend a seller in EU/UK or reputable from AliExpress etc. I'm looking for an android 11 6/128 or 8/256 with a 10.25" screen, I think the 12.3" may be too big, but I would like higher resolution i.e. 1920*720. I've looked on xtrons website but they only have the 1280*480 version.
Any recommendations would be appreciated. Thanks |
05-18-2022, 02:04 AM | #491 | |
Rep 31
05-18-2022, 08:21 AM | #492 |
Rep 31
Hi, I am also having the issue of "Update Fail!", just like some other contributors here. I am also running the KSW overlay. How exactly did you solve this? What do system recovery and initialization entail?
05-18-2022, 09:24 AM | #493 | |
Rep 19
It is, however, the RHD version (I had to specify that explicitly) though and I bought the 12.3 inch top of the line 8/256 GB Android 11 version, total price was comparable (or better than) other suppliers that I had seen on there. They did respond to my messages, but more to placate me than accelerate delivery. It is your call whether you use them, message them about delivery and costs before hand if you do. I found this forum a few days ago and have since managed to upgrade the firmware to 2.0.9 (the latest), thus fixing a Zlink version related bug I had, I have also got KswOverlay working, with my own car picture. I also have Android Auto working wirelessly. I still have a bit of an issue with incoming phone calls that I noticed today, but that could be config related. I am going to try and fix that now. It's not bad right now. I posted some screenshots yesterday if you want to take a look. I've attached one here with my own car picture and template from RedEric (thanks). Last edited by tj320dgt; 05-18-2022 at 09:36 AM.. Reason: Typos and picture |
Kri1083.50 |
05-18-2022, 12:40 PM | #494 |
Rep 47
05-19-2022, 04:02 AM | #496 | |
Rep 31
05-19-2022, 05:26 AM | #497 |
Rep 19
Hi, no I did not have KswOverlay installed when I did the updates. I installed it afterwards. I can see that you can disabled KswOverlay - I guess you may have tried that already? Good luck! I am still trying to get someting that I am happy with. Phone calls, particularly incoming, seem a bit hit and miss.
05-19-2022, 05:46 AM | #498 |
1052
Rep 2,371
Drives: E63 645Ci
tj320dgt Granrey KswOverlay doesn't affect the update process. It's just a system app and it gets erased during update.
05-19-2022, 07:00 AM | #500 |
Rep 31
Alright, so it seems that KSW Overlay is not related to the "Update Fail" issue...
I am asking Navifly for help, but so far they just keep repeating the steps of the standard update procedure. It's always so hard to make them understand my issues. Seems they don't carefully read any of my comments |
05-19-2022, 09:27 AM | #501 |
47
Rep 81
05-19-2022, 10:32 AM | #502 |
Rep 31
Just to share with those who have the "Update Fail!" issue, Nobuno sent me the below instructions. I will try in a couple of days and report back.
There seems to be no problem with the update. In my experience, the ksw overlay seems to get in the way of the update. First of all, please follow this procedure to make it Shipment status. (Current apps will disappear. Please install again.) 1. Select "System Recovery" on the system version screen. (Be sure to select System Recovery from System Info. Be sure not to reset from the factory settings that require a password.) 2. After that, the system screen will be set up to the factory default automatically. 3. After the automatic setup is complete, try updating to the new firmware. This procedure should complete the update without any issues. |
05-19-2022, 02:24 PM | #503 | |
Rep 10
Would you guys not recommend the android 10 unit or the 11? |
05-19-2022, 03:10 PM | #504 | |
1052
Rep 2,371
Drives: E63 645Ci
However if you have NBT EVO with touchscreen, you will lose that OEM touchscreen functionality, significantly reduce the quality of your screen, potentially experience audio issues, if you were hoping to have any of Android info shown on the HUD you will be greatly disappointed, and you will experience dozens of inconveniences - some very small, some big. Every EVO unit can have CarPlay retrofitted and even have a very limited Android Auto functionality via 3rd party app. There are groups, forums, people who will be more than happy to help you what that retrofit, and they won't charge you 500$+ for that... which happens to be the cost of a decent Android unit. |
05-19-2022, 03:47 PM | #505 | |
Rep 19
On the tickering front, I just tried this, which I know you are aware of. It looks pretty good: https://idrive.ibus-app.de/index_en.html It was going well, until I realised you probably need to buy the IBUS APP to fully populate it, but then again do you need to? It's probably overkill, but then again where do you draw the line. |
05-19-2022, 03:47 PM | #506 | |
Rep 47
