05-23-2014, 03:53 PM | #24 |
///MD
1380
Rep 3,998
Interesting enough
I had an x5 that every 2-3k used to require a quart.. And babied it during Break In Whike this M5 I didn't hurt it while In Break In but certainly didn't baby it and was in 5k RPM so often and it was delivered to my hoise after 400 miles of Highway driving ! And now at 8k I drive it very hard whike not warmed up even red line it because my commutes are shirt and if I wait till warm I won't be able to drive it the way I want once a week !! Noted that Oil Level Was exactly between Max and Minimum and didn't ask for oil. Now almost 1k mikes after 7k service (Yes as went early for screen replacement and they did service 2k miles before due- Goooood Now still at Max and 1k miles after service and I drive it very hard (MPG 15.2 and no traffic - and I use it as DD too ! I believe it is the luck of the draw! No consistent reports and seems anecdotal to me how you break it in, how you baby it, how you drive it !! It is M5 meant to be driven like a sports car!! Because it is a sports sedan!! |
05-23-2014, 04:36 PM | #25 |
20
Rep 105
I had the 3000km service and then I had the oil changed at 7 or 8k I believe, but not one drop of oil has been put in the car by me. At 15,000 km right now.
I made sure to follow the post here somewhere about seating the rings properly right off the lot (well, out of Welt ). The oil containers I bought in anticipation have dust on them.
2019 BMW F36 440i w/MPerformance things
2021 BMW X3 M40i - For Sale 2003 BMW E46 M3 - Track toy 2016 Ford F250 Diesel - Carries things 2019 BMW F90 M5C - Sold and I regret it |
07-11-2014, 06:08 PM | #26 |
53
Rep 664
17,000 current miles.
Installed BMS tune and GT Haus full catless exhaust system from day 1. Car is driven hard ALL of the time. I have never had to add engine oil EVER. Oil level is always full and car performs amazing. |
07-11-2014, 06:10 PM | #27 |
10
Rep 67
Out of curiosity what is the best and average MPG you see out of the car?
07-17-2014, 07:14 PM | #28 |
38
Rep 305
07-31-2014, 02:55 PM | #29 |
182
Rep 326
Drives: 2021 X5M
Just got back from the dealer and they had to put in another quart. Got the service message to add a quart asap. Car has 3,000 miles. Break in was 1200. Added a quart around 2000. Now this one was at 3,000. I hope the car still just breaking in and that it doesn't keep burning a quart every thousand miles.
08-01-2014, 07:37 AM | #30 | |
124
Rep 1,840
Drives: '14 M5 CP Dinan Stage 2
05-27-2017, 09:48 PM | #31 |
Rep 3
BMW F10 M5 Oil Consumption
I was having to add oil every other fill up. Took my M5 to the dealer just before it went out of warranty with the smell of oil and what sounded like an air leak. The discovered that part of the air filter had been sucked into the engine (vehicle had extended service so only serviced at dealer). After talking to BMW/NA hey replaced both turbos and the catalytic converters. No oil use since with about 2k miles and the oil level remains the same.
06-05-2017, 01:38 AM | #33 |
688
Rep 1,125
08-13-2017, 07:39 PM | #34 | |
24
Rep 222
08-16-2017, 07:01 PM | #35 |
11
Rep 38
Accurate oil capacity of a US spec S63TU B44 engine
If you want to be precisely accurate the complete engine, including the oil in the engine pipes and engine oil cooler is 9,70 liters. However, and for purposes of knowing how much oil can be changed, short of disassembly of the engine, according to BMW (https://wbeista.bmw.com) and how much oil can be added at an oil change, the answer I provided is the same as BMW states--oil quantity in sump:8,00 liters, oil in filter element: 0,50 liters, total: 8,50 liters.
08-17-2017, 01:47 PM | #36 |
24
Rep 222
I done oil change every 7000-10000km. in BMW service. I use redline racing 5w40 oil. And every time they put 9,5l oil. Im doing test every kind of way.
Electronic dipstic show full mark add 9,5l. If you put 9,8l dipstic show overfill. When dipstics drops 1 scale and we drain oils out engine oil is 8.0l. And when idrive shows add. 1l liter you had only 7,2l oil. if you add 1l dipstic show full mark. My car dipstic drops 1 scale about 7000km-8000km and every time i add 1l. (last interval is 8200km and dipstic show max. And BMW dealer drain out 8,3l) in USA you drive low engine oli every time if use only 8,5l And yes dipstic show max 8,5l but it shows max 9,5l overfilled 9,8l Thats why many cars (M5 f10) in USA have this oil consuption problem. Oil pressure is to low since day 1 when first oil change is 1200ml and Europe 2000km. Sorry my very bad english |
09-12-2017, 03:04 PM | #37 |
Rep 13
Since I bought my f10 I wrote down how many km I could drive after adding 1 liter oil.
1. (80300 km) 1 Liter added. 2. (82778 km) 1 Liter added. 3. (84141 km) 1 Liter added. 4. (85581 km) 1 Liter added. 5. (88750 km) 1 Liter added. From 4-5 I did about 3,000 kilometers before needing another liter of oil, however, those kilometers were made on long highway driving. The other observations (when driving only in the city) seems to do about 1500 km before needing another liter of oil. |
10-04-2017, 02:35 AM | #38 | |
752
Rep 1,857
11-07-2017, 04:10 AM | #39 |
162
Rep 687
Our n63 x5 used about 1l per 2000
Engine got rebuilt and now drops from high to low mark at around 15000 which is when i service it anyway My m5 f10 with 95000km on it seems to use a litre every 2000-3000km My m5 e60 uses about a litre each 1000km |
