08-06-2014, 04:41 PM | #23 |
Rep 4
If found 5.3 Quarts for the 228i engine Online
Many thanks for the reply:
7 Quarts sounds like a lot for a 2L engine: I found the following online for the 228i: 2014 BMW 228i 2.0L 4-cyl Engine Code N20 B20A Turbo LUBRICANTS & FLUIDS: Engine Oil Grade 1......SEO[1] Synthetic 5W-40 European Oil (EFMQT) All TEMPS......5W-30, 5W-40, 0W-30, 0W-40 Manual Transmission,S6-17BG......GLS [2] All TEMPS...... No AMSOIL Product Recommendation Automatic Transmission,GA8HP45Z......SLF [3] Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid (ATL) (ATLQT) OE Fuel-Efficient Synthetic Automatic Transmission Fluid (OTLQT) Standard Differential, Rear 188LW......GLS [4] All TEMPS...... No AMSOIL Product Recommendation Fluids Clutch Fluid......HBH AMSOIL Brake Fluid DOT-4 (BF4SN) [5] Brake Fluid......HBH AMSOIL Brake Fluid DOT-4 (BF4SN) [5] [1] To prevent potential engine damage, use only BMW High Performance Synthetic Oil part No 07 51 0 017 866 or an equivalent meeting BMW Long-Life rating LL-01 or LL-01FE [2] Use MTF-LT-3, BMW P/N 83 22 0 409 878. Ensure correct fluid is used by referring to the label on the transmission. [3] Shell M-L12108, BMW P/N. 83 22 2 152 426 [4] Use BMW P/N 83229407768 (60 Liter). [5] Hydraulic Brake Fluid, DOT 4 TORQUES: Oil Drain Plug.....6 ft/lbs [1] Manual Transmission GS6-17BG [2] Fill Plug 18 ft/lbs Drain Plug 18 ft/lbs [1] Replace oil drain plug. If the new oil drain plug does not latch after tightening to specified torque, the drain plug must be positioned so the latch mechanism is aligned. [2] M12x1.5 thread |
08-06-2014, 04:44 PM | #24 |
Rep 4
Sorry here is the cut and paste on 228i oil amount
CAPACITIES:
Engine, with filter..........5.3 quarts [1] Cooling System, Initial Fill..........5.6 quarts AMSOIL Antifreeze and Engine Coolant Automatic Transmission, GA8HP45Z Initial Fill..........Not Specified [2] Automatic Transmission, Total Fill 8 speed GA8HP45Z..........Not Specified Manual Transmission, S6-17BG..........3 pints Differential, 188LW Rear..........0 pints [3] [1] After refill check oil level. [2] Carry out oil level check in accordance with instructions from a scan tool. [3] Fill to level of fill plug. |
08-06-2014, 04:46 PM | #25 |
What goes here?
454
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
woops.. sorry yeah that was for the M235i
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
