02-08-2014, 11:51 PM | #23 |
594
Rep 4,488
Well OP, how was your rain experience???
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
02-09-2014, 10:33 AM | #24 |
313
Rep 3,675
actually i decided to give up my spot stay home and try to work on a issue im having...cooling my brakes...thanks to my boy 1MOREMOD and his thread i setup a brake cooling system until a get a set of brake cooling plates on...
02-09-2014, 12:52 PM | #26 |
663
Rep 1,424
My first three track days started out ~37 degrees and wet. First day a 400 whp STI lifted on the back stretch (slight curve) nosed into the wall, bounced off and hit the outside wall and came back onto the track. I learned a lot that day.
02-09-2014, 01:01 PM | #27 |
663
Rep 1,424
Don't terminate the hose at the fender well. Continue it on, route and zip tie pointing at the back of the rotor. You can buy backing plates if you want but not necessary. The hose will get kinked and worn over time.
02-09-2014, 01:12 PM | #28 |
313
Rep 3,675
thank you for the help!!!!!!!!!!!! already have plates...had them sitting them around...figure i would throw them on...
02-09-2014, 01:26 PM | #30 | |
313
Rep 3,675
thank you for the DIY!!!!!!!!!!!!!!!!:thu msup:
02-09-2014, 01:27 PM | #31 |
313
Rep 3,675
GLAD TO HEAR I WASNT ALONE IN WRECKING MINE ON THE WALL....
02-09-2014, 01:38 PM | #32 | |
11818
Rep 23,187
02-09-2014, 01:45 PM | #33 |
313
Rep 3,675
they are CF so o bending....i have a hand held belt sander but concerned it wont be even if done w/ a smaller hand held...i may have no choice though
02-09-2014, 02:04 PM | #34 | |
663
Rep 1,424
02-09-2014, 02:10 PM | #35 | ||
663
Rep 1,424
02-09-2014, 02:16 PM | #36 | |
313
Rep 3,675
02-09-2014, 02:19 PM | #37 | |
313
Rep 3,675
02-09-2014, 02:38 PM | #38 |
11818
Rep 23,187
That's pretty common. The nt01 splice thread demonstrated it, they kept telling mutiple people exactly that even though we all knew of the problem.
02-09-2014, 04:54 PM | #39 | ||
663
Rep 1,424
02-09-2014, 04:58 PM | #40 |
313
Rep 3,675
well maybe ill wait unil i put on the bbk then
02-09-2014, 06:30 PM | #41 | |
1581
Rep 8,077
Drives: 11 E90 M3 Individual
With that, I'm SURE those backing plates were made for OEM rotors with are 30mm thick. Assuming the same centerline on the rotor, a 380mmx35mm rotor would reduce clearance by 2.5mm. Those backing plates have to be close to the back of the rotor to minimize air leakage. Otherwise you drastically reduce the cooling effect.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
02-09-2014, 06:47 PM | #42 | |
313
Rep 3,675
02-09-2014, 07:17 PM | #43 |
1581
Rep 8,077
I put some extra mm's on there for you...that's why they don't fit
02-09-2014, 07:23 PM | #44 |
313
Rep 3,675
lmao... i knew it i read a few threads that te BW plates have to be shaved....
