04-30-2014, 02:38 AM | #23 |
46
Rep 331
Drives: M140i F20 LCI-2
Steptronic Transmission
While there was nothing wrong with my transmission, I just had all fluids replaced by SouthernBM at 50,000 km. It feels like new.
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016. Sold: Alpine White 123d e82, 2010, 150kW/204hp. |
04-30-2014, 04:33 AM | #24 |
European Editor
10633
Rep 22,992
That is more to warm UP the trans fluid and not to cool it down.
03-12-2015, 09:51 AM | #25 |
12
Rep 51
Drives: F25 X3 xDrive 20i
Hi mate,
Regarding purchasing from the CTSC, they do not ship internationally, especially oil because it is hazardous. I really dont know how you did it with the CTSC. Can you advise? |
03-12-2015, 05:17 PM | #26 | |||
171
Rep 2,682
03-12-2015, 06:53 PM | #27 |
12
Rep 51
03-27-2015, 12:47 AM | #28 |
30
Rep 134
Doesn't the 135 have a DCT not Steptronic?? Just curious per the title of the DIY post. 128 is Steptronic GM (Made in France) transmission and 135 is DCT ZF (Made in Germany). Not sure, that's just what I always read/heard. I will admit, despite my 128 having the GM transmission, I've had NO issues whatsoever so I'm thinking they do much better work in Europe than the US.
03-27-2015, 02:13 PM | #29 |
10
Rep 96
2008-2010 auto 135i's had a ZF 6HP?? unit. It wasnt until 2011 that a DCT trans was available.
Also, word of caution to anyone doing this. Remove the fill plug first before draining anything. I almost stripped my old one out trying to remove it. You cannot get any sort of socket/extension combo up in there without lowering the transmission, so it is best to make sure you can remove it before you start removing fluids and such. To remove I used an 8mm allen key, 8mm short socket and a 1/4" extension that added another 2-3" onto the length and banged on it with a rubber mallet a couple times and it cracked loose. |
03-28-2015, 02:48 AM | #30 | |
30
Rep 134
//'18 X4 M40i Carbon Black//
02-18-2016, 12:59 PM | #31 |
108
Rep 213
Thanks for the write up. I was thinking about doing this on jack stands. How stable was it for you on the stands? You feel better about doing it on jack stands afterwards? Thanks.
02-18-2016, 08:13 PM | #32 | |
171
Rep 2,682
Should be fine on jack stands. Just for extra safety, put some ramps and/or wheels under the raised wheels. It's very safe with jack stands but extra safety measures will make it feel a lot more comfortable.
03-24-2016, 01:31 PM | #33 |
13
Rep 71
Hey froop-
Did you install the Sealing Sleeve that comes with the package. I noticed that ECS doesnt contain that in theirs- wondering if its needed. Also- did you need to use any of the additional hex bolts on your install (5 are provided by CTSC)- again wondering since not provided by ECS. Only asking since I'm trying to save on shipping For the actions of moving the gear selections 1-6, Ill be on a Ranger Quickjack which I can just let the wheels rotate. Is it better to actually let the transmission rotate the driveline to get the fluids moving or is just the actions of moving the gear selector while brakes are applied enough? Thanks in advance Sasha
2017 Alpine White M2 DCT- Stock ... for now
2010 135i Sport with flipper paddles. Cobb Pro tuned by Kozmic Motorsports- "slightly modified" |
03-24-2016, 05:17 PM | #34 | |
171
Rep 2,682
I didn't get any sealing sleeve or additional hex bolts with my kit that I remember. As for the transmission shifting, I think it's better to let it free spin.
03-29-2016, 02:12 PM | #35 |
13
Rep 71
Thanks froop- Tackling this hopefully this weekend with a coolant flush as well.
04-02-2016, 07:01 PM | #36 |
13
Rep 71
Froop- Great write up- helped a bunch as I just completed my coolant flush and Transmission service this morning. Wanted to point out two corrections to your write up
The dust shield bracket is held on by an 8mm nut/washer The drain plug is most definitely a 10mm and not 3/8 (that was very loose). Other than those two things- spot on! A couple of pictures. Im shocked BMW states Lifetime when the look of the fluid was horrible at 60K on my wife's car and the filter would continue to weep out oil to the point I emptied the pan 4 times from the filter alone. It was very clogged for sure For those wondering- I use a 5000XL Ranger QuickJack from Bend Pak. Its a portable lift that gets me about 23" of clearance and works great. Was able to have my friend work the gears and get almost 6 liters in the transmission case. Awesome lift system and they make it 12V too for true portability for race tracks. Where the magic happens Magnets were coated in metal sludge. This should be done at 40K and everyone should get this done. It likely saved my transmission. Drive afterwards confirmed the shifting was vastly improved. Ran a 60 mph 3rd gear romp to 130 and it was silky smooth and free of hesitation. In automatic mode (regular)- the 70 mph drop from 6th to 5th to overtake was fast and had zero lag. Huge improvement over yesterdays drive. All the gears seemed to be shifting much smoother and without any jerkiness. If you haven't done this- DO IT! Froop- Thanks again! Forgot to add- took we with a twin coolant flush- about 3 hours to complete taking my time.
2010 135i Sport with flipper paddles. Cobb Pro tuned by Kozmic Motorsports- "slightly modified" Last edited by Sasha4; 04-02-2016 at 07:03 PM.. Reason: added time to complete |
04-03-2016, 06:45 PM | #38 | |
171
Rep 2,682
Thanks for the nut/bolt/plug sizes. I'll update them in the OP. I have no idea why I would have written 3/8" actually seeing as everything on the car is in metric measurements. Maybe that's all I had at the time haha. Btw, that lift system looks epic... I might have to look at getting something like that if my car isn't too low for it that is. Edit: Had a look at my OP and I did actually write 8mm bolts for the splash/dust shield but had it has "7 8mm". I've changed it to 7 x 8mm. Also, it looks as though I also used an imperial 5/16" allen key for the fill plug. I wonder if that is in fact an 8mm allen key. I'll change it anyway as 5/16" is equivalent to 7.94mm.
04-05-2016, 07:18 PM | #40 | |
13
Rep 71
The lift for my wifes 135i was too low to use the 4" rubber spacer blocks with the billet aluminum hockey puck spacers that have that rectangle to fit in the pocket, so I ran it up with the 2" rubber blocks, placed my Reverse Logic parking ramps under the tires and lowered it back down. That gave me the necessary clearance to use the 4" blocks for extra wiggle room underneath. A suggestion to anyone looking to do this on a budget and be safe, Id suggest Reverse Logics specially designed ESCO jack stands with built in swiveling blocks that fit in the lift pockets. Ive used them to work under my GT-R and they are rock solid, inexpensive and conveniently- work with BMW pockets too. A set of 4, some plywood to gain enough height to get to the center jack pads front and rear and a Harbor Freight 2 Ton Low profile jack (simply an amazing jack that Ive used to lift my heavily modified long travel FJ, GT-R and BMW. Jack stands (they usually run specials on the forums and have great sales all the time) http://www.reverselogic.us/shop.html...tegory=4643108 Jack (take your 20% coupon you get every other month in and snag this jack- you wont be disappointed) http://www.harborfreight.com/2-ton-l...ump-68050.html Hope that helps. Pictures of both items mentioned above while in use on my GT-R- Jack left to act as a safety but never required it.
2010 135i Sport with flipper paddles. Cobb Pro tuned by Kozmic Motorsports- "slightly modified" Last edited by Sasha4; 04-05-2016 at 07:22 PM.. Reason: added photo |
08-27-2016, 04:12 PM | #41 |
Loves me some MHD!
1866
Rep 1,725
Thanks for the great DIY!
I just did the trans fluid, and wow, what an improvement! I'm at 60K miles, and it was shifting harsh in sport mode, especially 2>3 and 3>4. With the fresh fluid the harshness is gone and the trans is once again well behaved. Totally worth it, and if your step is starting to misbehave and you're over 50K miles, do it! I spent some time modifying my jack stands to fit, maybe 30 minutes and something that needed to be done anyway, this was just a great reason to knock that little project out. Aside from that the job was quick and easy, not really any more difficult than changing your oil. Putting the"tree" in shade tree mechanic...
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla . . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg |
10-21-2016, 09:11 PM | #43 | |
European Editor
10633
Rep 22,992
I am not even sure the 135i A/T have a pan plug/screw. Most AT's you simply drop the AT pan. Looking back... I would have a shop do the service. Check around where the closest ZF authorized service center is to you.
10-22-2016, 01:28 PM | #44 | ||
Loves me some MHD!
1866
Rep 1,725
Yes, you can change just the fluid, but considering the age/mileage I'd strongly encourage doing the filter as well if it's not been done before. It's very easy to do, not adding much complexity or cost to the job. And, yes the step trans has both a drain and a fil plug. Both are clearly discussed and shown in pics in the original post of this thread. Also note that as Dackelone mentioned you'll want to do the fluid change two or maybe even three times if not replacing the filter. Due to fluid in the torque converter you may even want to do it more than once even if you replace the filter if you're really wanting to be thorough. I did fluid & filter just recently and will probably do a fluid only change in the spring when I do the diff.
1and1
