03-15-2012, 07:57 PM | #23 | |
194
Rep 1,457
03-16-2012, 02:40 AM | #24 |
European Editor
10640
Rep 22,992
03-16-2012, 12:41 PM | #25 |
194
Rep 1,457
NA engines should be 100k miles interval. I have 128i.
03-17-2012, 12:12 PM | #26 |
European Editor
10640
Rep 22,992
Ohh yes, your correct. Your plugs should be good for 100K miles. But still... if your a sporty driver... spark plugs are so easy to replace and offer such a good bang for the buck($). It will really change the way the engine runs. |
03-17-2012, 06:28 PM | #27 |
194
Rep 1,457
I will take a look at it. thanks.
03-27-2012, 11:48 AM | #28 |
13
Rep 84
Drives: 2012 128I BMW
Is there Any way to reset the tire pressure warning light if so how
03-27-2012, 12:28 PM | #29 | |
European Editor
10640
Rep 22,992
Yes, there is a way... its in your owners manual. IF your TPMS light is on (yellow). First check the tire pressure to verify all is good. Then with the engine running (BUT NOT MOVING) scroll thru the BC menu until you get to the TPMS menu, then press and hold the button on the end of the turn signal stalk. The menu will then say something like resetting... then DRIVE a short distance. This now tells the TPMS the new "target" tire pressures and resets the TPMS system. Every few tanks of fuel when ypu check your tire pressures... you should reset the TPMS system this way. Dack |
04-10-2012, 06:48 AM | #30 |
59
Rep 741
Drives: E87 130i
I have reset my brake fluid and brake service indicators, the brake fluid date did not change, and the brake indicator simply displays: ------- [no change, was "----" before]
I still have the "lift car" indicator, but I didn't reset that independent of the others. -R |
04-10-2012, 09:04 AM | #31 | |
European Editor
10640
Rep 22,992
Did you just replace your brake rotors or pads too? Like did the wear light come on, then you tried to reset the pad wear sensor light/lamp? Bc if thats true sometimes only the dealer can reset the brake pad wear sensors IF you wait too long to reset the light. Ofcourse you would also need to replace the pad sensors. I guess I need more info. ??? |
04-10-2012, 11:47 PM | #32 | ||
59
Rep 741
Drives: E87 130i
04-11-2012, 09:14 AM | #33 |
European Editor
10640
Rep 22,992
Ok, but how did you drive the car after replacing the pad sensors before you tried my service light reset procedure? I have heard that if you drive too long with new sensors on that axle... it will take a "hard reset to turn the pad light off. Only a shop with a GT1(like at the dealer) can reset it then. |
04-11-2012, 06:54 PM | #34 | |
59
Rep 741
Drives: E87 130i
04-12-2012, 09:36 AM | #35 | |
European Editor
10640
Rep 22,992
Try my DIY one more time... if it doesn't reset the light... then a dealer visit is in your future. |
04-13-2012, 01:18 AM | #36 | |
59
Rep 741
Drives: E87 130i
Does it record when things were serviced in the ECU, or only distance remaining? Might just ignore it if its the latter, as there are only two local dealerships, both the same owner, and both as unhelpful as each other! |
04-14-2012, 01:28 AM | #37 | ||
44
Rep 1,883
Thanks for the insight though Dack. So this definitely can't be reset except by dealer? |
04-14-2012, 01:20 PM | #38 | |
European Editor
10640
Rep 22,992
I don't know for sure. But that is what I have been told by my dealership. Maybe someone else can chime in. ? I think you need a shop that has a GT1 (scan tool) to reset that light. |
04-15-2012, 08:09 PM | #39 | |
117
Rep 1,998
To the OP. Maybe this will help.. First its possible that the sensor you got is bad... rare but possible.. recheck you connection also. Second, it is possible that it needs to be reset with a GT1 or ISID meaning dealer visit.. it has happened in the past.. not that often but it does happen.. make sure that you followed Dack instuctions to the tee.. with no pauses or re-pressing of the button.. also make sure that the door is closed when resetting.. respond back.. ill know more on Monday ( tomorrow) Regards, Alex !!
X1, R58 JCW, M2 in my future if planets align
04-16-2012, 04:20 AM | #40 | ||
59
Rep 741
Drives: E87 130i
Thanks guys. |
04-16-2012, 04:52 AM | #42 |
44
Rep 1,883
Still doesn't work for me. Holding reset will reset other other functions - oil service due etc, but not my (front?) brake & hoist light warning.
04-16-2012, 05:02 AM | #43 | |
European Editor
10640
Rep 22,992
Humm... So you did replace your pad sesnor with a new one right>? Do what DriveHard said: check to make sure the sensor is plugged in correctly and/or maybe you got a bad new sesnor? IF you still have one of your old sesnors - and don't want the safety of pad wear sesnors... just cut the sensor off and solder the wires together. Then use that as your "sensor" and reset the light. IF all else fails... a dealer visit is in order. Bring some of your tech's favorite refreshments in your trunk! Dack |
04-16-2012, 05:32 AM | #44 |
44
Rep 1,883
Sadly, I didn't put the new discs & pads in myself
The workshop who put in my DPs the week before last noticed my performance discs were cracked though all the drill holes. Pads were ~2/3s worn & car's done 23,000km (about 14,000 miles for the imperialists). As they already had the car in bits I've gave them the original discs I removed when the car was new & a new set of OEM pads to install. They put these in but I didn't ask them specifically about the sensors. Maybe they stuffed up here? Alarm didn't come up until a week later so I presume the sensor was at least working when they handed the car back to me. I'll check the sensor myself. Just one on each axle isn't there? Which side on the front?
Driving - Manual E90 M3 (Melbourne Red/Black).
Riding - BMW R1200RS Sport. |
