      08-12-2017, 10:52 AM   #23
Gangplank
Gangplank's Avatar
Drives: 2011 e82 135i n55 Sport w/ DCT
2011 135i  [0.00]
Thanx. Needed this today after doing some coding. Worked like a charm.
      05-15-2018, 07:57 AM   #24
rvnlive
England
Drives: 116i E87 5dr hatchback
Window error codes - waiting for solution
Hey Guys,
Given an E87, and I've fault in both side front windows.
I've checked the error codes, they are Time Windows disturbed 009CC7 and 009CC8
Anyone of You can give me a hint how to solve this problem please?
Thank You. I appreciate it!
      07-19-2018, 10:50 AM   #25
brunp
11
Drives: 2013 BMW X3, 1997 BMW M3
Originally Posted by AndyM View Post
Thanks to Imz4n on ZPost for this one.
If you disconnect the battery and lose one touch up/down and or the positive seal function, you need to reset the windows.
This procedure will reset the windows limits so that when you open the door the window will drop the 1/4 inch.
- Sit in the car, and put the key in position 1, so you have power to the windows.
- Push and hold down the window switch, and keep it held down for 5 seconds after the window is all the way down. This re-sets the memory, telling the motor, in effect, “Remember where we are now? ”
- Roll window back up, and release switch.
- Open door. Marvel at the downward motion of the window. Repeat on other side, if needed.
Would this procedure work in the following scenario where the window won't close, but open's about half-way after reaching the top? It is like it doesn't know where the top position is. You can slowly inch the window back up again, but if you do it too quickly, it will retract to the bottom again.
Paul
      05-28-2020, 11:52 AM   #26
VERTIGOtcv
VERTIGOtcv's Avatar
Drives: 2012 335i msport
- Push and hold down the window switch, and keep it held down for 5 seconds after the window is all the way down. This re-sets the memory, telling the motor, in effect, "Remember where we are now? "
Totally worked, awesome thank you for the post. Got really sad when I first noticed the problem in so happy there is a easy fix.
      01-31-2021, 01:19 AM   #27
j7jrt
10
Drives: E88 m sport
Trying to get my roof to open so this will be my first step thanks
      03-25-2021, 01:50 PM   #28
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
Amazing!
Thank you for this post! I freaked when my windows didn't do this anymore after disconnecting the battery. Now it's all good.
      12-22-2021, 11:08 PM   #29
MajorBob
18
Drives: 2012 e88 135i, 2008 e60 M5
Ive tried reseting the limits but it wont take. My issue may be different though, my windows will only go up and down about an inch at a time. Rear windows work fine but both front windows do exactly the same thing and will only move in 1 inch increments.
Any ideas?
      09-30-2022, 01:32 PM   #30
uzone02
Drives: BMW E82 135i
thxxx for that mate !
Hopes it can reset by sometimes it won't goes all the way up...
      11-15-2022, 11:11 AM   #31
turbo v6
Drives: 135i N55, 230i
Issue:
Window will not go up all the way up after opening it all the way down
Solution:
"- Sit in the car, and put the key in position 1, so you have power to the windows."
"- Push, extra click down hold in my case, and hold down the window switch, and keep it held down for 5 seconds after the window is all the way down. This re-sets the memory, telling the motor, in effect, “Remember where we are now? ”
"- Roll window back up, and release switch."
THANK YOU!!
      05-04-2023, 05:03 PM   #32
Jimbochap
Drives: 135i
I know this is an old thread, but I'm having issue too with a 135i Windows.
Driver side, replaced regulator, after taking off motor wire was hanging out of the spool.
Now the window master control switch, works the mirror fine but windows both Drivers side and Passengers side is an issue. Passenger side window only goes up an down at an inch or 2 at a time.
Drivers side Window works the same way when it works, sometimes though when hitting the toggle switch up or down it doesn't do anything? Like I said before switch works the mirrors fine?
So is my issue the motor on that window getting ready to go or is it a failing master control window switch on the drivers side?
This is a 2008 135i. Coupe
Any help will be appreciated.
      05-06-2023, 09:08 AM   #33
Jimbochap
Drives: 135i
No one else has every had this issue?
      05-13-2023, 02:16 AM   #34
eicasg
Drives: BMW 320, BMW 123
It's for people with disabilities, for easier IN/OUT.
Originally Posted by kb135 View Post
Hi Yes I have. I notice it happens only when I double-click the open button on my remote then open the door - it rolls down most, but not all, of the way. not sure what that function is for... It goes all the way up once i close the door though.
      05-13-2023, 02:22 AM   #35
eicasg
I have almost the same issue... I have changed window lifting motor and harness, and after job, window does not go down 1/4 inch. It looks like it tries to go down, cuz window moves a little, but not 1/4 inch... And i have lost seal on this window as well, when i drive about 70mph, lots of air noise comes inside the cabin...
I have reseted window position as mentioned in this topic, did not help.
Any ideas ?
