05-09-2024, 02:17 PM | #23 | |
165
Rep 442
Drives: 2021 X3 M40i (times 2)
Not arguing when an engine came out - that doesn't matter, it's not when it goes into all vehicles. The actual years I posted should still be accurate, but model/build year do sometimes mix parts when it's a change like the 2019-2020 MY. A 10/2019 build has the possibility to be considered a 2020 MY with how late it was made.
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake Sold - 2009 328i - Stock, 195,000 running strong. |
05-09-2024, 02:32 PM | #24 | |
51
Rep 184
05-09-2024, 03:19 PM | #25 |
Rep 18
It depends on what you consider a mild hybrid. the 48V system wasn't implemented until MY2022. 2021 and earlier with coast mode and alternator regen aren't actual hybrid.
05-09-2024, 09:30 PM | #26 |
51
Rep 184
Ok so maybe on some markets there were 380 hp m40i without 48V additional boost, i just never came across such data. As seen from officoal brochure a few posts up the TU had only some 320 or 340 hp when introduced, and was later tuned to 360 (and not detuned - as the guy above stated).
05-10-2024, 10:00 AM | #27 | |
165
Rep 442
Assuming yours is a B58TU, then my loose usage of detuned would be correct; if standard HP of the B58B30O1 (High output, in the 2020+ MY of the X3 M40i) is 382, but if only making 360 due to emissions then that is an adjustment to the tune of the engine.... it doesn't need to be controversial, it is what it is. The article referenced earlier shows output for the B58B30M1 (Medium output, 335HP), which wasn't used in the X3 and invalidates your argument. Actually from the M1 to O1 (TU mid --> high output), the main difference is indeed tuning of the engine... to get less power from the O1, you would have to adjust/detune, or whatever verbiage you want to use that's pretty much the same thing. The 48V mild hybrid was added to the 2022 MY X3 M40i, also in an effort to placate emissions. It neither decreased nor increased power output numbers, but ironically is rated at 1 MPG less on the highway (26 instead of 27 US MPG). 2020-2021 were the only non-bastardized TU model years on the X3 M40i (personal opinion lol). The TU2 was never used in an X3 though. This thread is becoming asinine and pointless, beating a dead horse. Official/unofficial engine cover that says what engine you have.
05-10-2024, 11:43 PM | #28 |
51
Rep 184
Ok, thank you for all the info. Please just tell me one more thing: so there are actually 2019 models with 380 hp in the US? And they are without reverse alternator (adding some 30 hp) or other changes to TU described in the introductory brouchure?
And i dont agree this theme is kicking a horse, there is much confusion regarding this and users order wrong parts etc. Also the finest spare parts vendors have misleading search tools...so i ended up ordering wrong spark plugs (despite entering VIN in the search bar....).... |
