02-22-2024, 07:31 AM | #23 |
3383
Rep 1,833
Drives: 2022 X3 M40i
for those of you who plan to install a new bolt or upgrade, here's how.
02-23-2024, 09:45 PM | #24 |
718
Rep 565
Does anyone know the P/N of this bolt for our cars (the M40i, not X3M)?
Is it 33326775040? I'm kinda thinking of just replacing it as a fatigue measure.
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 |
02-23-2024, 11:56 PM | #25 |
3383
Rep 1,833
Thats what I see. 33326775040
03-06-2024, 06:49 PM | #26 |
192
Rep 94
So I just wanted to touch base because my driveshaft broke awhile back and I upgraded to a carbon driveshaft which was recommended from Joe who I知 sure many people have heard of.
I never noticed anything wrong with bushings at the time of installation or the bolt for that matter. But fast forward 6 months and the two front mounts are broken, rear main bolt is broken as well. Took over two weeks to receive front bushings from Germany and I知 currently waiting to see if the VTT inserts work for fronts because I contacted VTT and they said we池e sure if they would fit and they would have to research it. I also asked if I could help expedite that process and try and they said I could purchase them and try it but would be a restocking fee if I returned them. I also want to get the Einhorn for the rear but since the X3M diff bushings and M40 bushings are different parts numbers I am not sure it will fit I guess I知 waiting to see what anyone else finds out. |
Burr0013383.00 |
03-06-2024, 07:14 PM | #27 | |
192
Rep 94
Burr0013383.00 |
03-06-2024, 07:23 PM | #28 |
Cowboy Astronaut Millionaire
2324
Rep 2,893
Dang. This thread make me sad.
How much is a stock replacement?
03-06-2024, 07:24 PM | #29 |
3383
Rep 1,833
Rhdlife192.00 Pszyk m40i33.00 |
03-06-2024, 07:38 PM | #30 |
192
Rep 94
03-07-2024, 04:30 PM | #31 |
BM3 Tuner
371
Rep 314
Yes x3m bushing will fix as they share the same subframe most BMWs share the same subframe aswell
2019 BMW X3M40I - VRSF Downpipe, XHP Stage 3, Nostrum Stage 1 Injectors, Nostrum Big Bore HPFP, VTT PCV and Oil cap, HnR springs.
Paul Johnson Tunes Shop/Development Car |
03-24-2024, 02:37 AM | #32 |
Rep 11
https://www.fjmotorwerkes.net/produc...fj-motorwerkes
We are aware solid bushings causes vibrations and unwanted sounds from testing. We also offer end bushing for extra piece of mind at only 」59 extra plus bolt collar kit 」199 = 」259. Instagram Fjmotorwerkes All the best |
04-16-2024, 12:38 PM | #34 |
3383
Rep 1,833
I will have it installed this weekend and will update the thread.
04-24-2024, 11:41 AM | #36 |
3383
Rep 1,833
The metal insert does not fit good on our bushing and it is loose all around it. So vtt does not work unfortunately.
04-24-2024, 07:17 PM | #37 | |
489
Rep 278
Drives: 2023 M3 Comp
Got the rear lower and mid installed and it痴 pretty nice! Definitely stiffens up the ride in a good way! |
04-24-2024, 10:53 PM | #38 |
3383
Rep 1,833
Correct only x3m/x4m fitment for VTT diff kit.
04-26-2024, 11:29 AM | #39 |
23
Rep 104
I would assume that the bushing diameter is the same from M40i to M. We could replace ours with the factory M bushing and then add the vargas kit if we wanted.
I thought I read someone else had installed the solid full bushing replacement from the M to the M40i and it fit. Which is why I expect that outer diameter of the bushings are the same. Thanks for trying and letting us know! |
blackops23489.00 |
04-26-2024, 11:33 AM | #40 | |
BM3 Tuner
371
Rep 314
05-10-2024, 05:57 PM | #41 | |
3383
Rep 1,833
The OEM parts numbers for the 3 bushings are different except the actual bolts which share the same number. The 2 front ear bolt is 07119906460 which is a M12x1.5x110 size and the rear OEM bolt is 33326775040 a M14x1.5x148 size. Since the VTT insert didn't fit due to design/shape and not size I may try this route and hopefully the size of the bushing is the same. The bushings are full polyurethane btw. |
speedsnice1209.00 5LEEPR_G01508.00 |
05-10-2024, 06:05 PM | #42 | |
3383
Rep 1,833
05-16-2024, 06:14 PM | #43 |
192
Rep 94
05-17-2024, 06:38 PM | #44 |
BM3 Tuner
371
Rep 314
Will be looking for someone to test a new rear diff bushing in the next couple of weeks. I値l be doing some test first to make sure I知 satisfied with the product before!
abbike18717.50 |
