11-05-2023, 12:49 PM | #23 |
17
Rep 203
Drives: f10 M5
Great write up thanks..looking for that sensor video pull
11-05-2023, 03:57 PM | #24 | |
989
Rep 1,807
RockEnterprises18.00 |
11-07-2023, 11:22 AM | #25 |
95
Rep 55
Here’s my install recorded with a diy for the tank and how I got the sensor out.
https://youtu.be/Iy4KB8lq36Q?si=XVNlSZVAmCiPnVuT |
11-07-2023, 11:26 AM | #26 | |
258
Rep 235
Drives: 2022 M5C /// 2023 XDrive40i
Awesome. You didn’t have to butcher the OEM coolant reservoir like I did to remove the sensor, so you could slice it open and harvest the silicate bag and install in the new reservoir.
Reventon Splitter /// Reventon Diffuser /// Addlights M Door LEDs /// Dinan Inlets /// Gentleman's Switch /// Paddleshifterz With Piano Black Steering Wheel Trim /// Charcoal Filter Delete /// Piano Black Side Skirts /// Funk Motorsports Turbo Blankets
11-07-2023, 02:05 PM | #28 |
258
Rep 235
A good amount of information (there’s a 2005 Motor article on the different types of antifreezes - if I can dig it up), but the VW/Audi group, and Mercedes have used these for a long time.
The logic is that the modern glycol based coolants were designed with reduced amounts of silicates, but this had the effect of aluminum corrosion within the cooling system. So the silica bag allows for consistent infusion of silicates - well to the point of protecting aluminum internals even at the 100K mile coolant exchange intervals on many cars.
DarkishM5C311.50 |
11-24-2023, 05:39 AM | #29 |
Rep 15
Drives: BMW M5 F90, Ineos Grenadier
My tank has just arrived and it looks fantastic. Will get it installed soon.
Regarding the O-rings - does have anyone have a part number as mine was shipped without them? |
11-24-2023, 08:17 AM | #30 |
258
Rep 235
The o-rings are already installed internally. You’re good to go.
11-25-2023, 06:00 AM | #31 |
1543
Rep 2,022
11-25-2023, 03:34 PM | #32 |
2280
Rep 3,305
VERY NICELY DONE.
Need matching one for the other tank, for symmetry. Mike
11-30-2023, 12:32 PM | #33 |
95
Rep 55
Raza stated he did not put o ring in the tank. So if you put the sensor in without the prongs, then your tank will definitely leak. Haha I’ve had mine on my car with over 500 miles now and no leaks or issues. Been pretty solid after some spirited runs!
12-02-2023, 01:43 PM | #34 |
258
Rep 235
I met Raza in person when I went to pick up the unit, and he told me these are integrated and to discard original O-rings. No leaks here whatsoever.
12-05-2023, 07:16 PM | #35 | |
17
Rep 203
Drives: f10 M5
12-05-2023, 07:17 PM | #36 | |
17
Rep 203
Drives: f10 M5
rk billet coolant
12-08-2023, 12:47 PM | #37 |
359
Rep 429
I've now had to fill both my main and reserve coolant tanks with coolant twice and I'm at 21,000 miles. Dealer said they didn't find any cracks/leaks after the first time. Second time was just this week, so haven't been in for service yet.
Sounds like I need to seriously consider one of these billet tanks! |
12-10-2023, 05:09 PM | #38 |
17
Rep 203
Drives: f10 M5
12-20-2023, 11:52 PM | #39 |
Rep 18
So…. Mine is leaking.. sure this is 100% user error. The coolant, it pools up in the indentation where the sensor connects I’m thinking it’s because I used O rings cause on the website it said mine didn’t come with them. So just to clarify .. are you guys installing the sensor with or without o rings. Cause I’m thinking the o ring I pre installed is too small and not seated right at this point. When I installed the sensor without o rings the leak was way larger.
Thank you in advance |
01-09-2024, 11:03 AM | #40 | |
357
Rep 435
Just to clarify for everyone, the o-rings for the sensor NEED TO BE REUSED FROM THE ORIGINAL HOUSING. The sensor and the two o-rings are the only items reused. Thanks -R
01-11-2024, 05:23 AM | #41 | |
258
Rep 235
I’ve had zero leaks, not having reused the O-rings, and can only think that the tight fit of sensor connector is containing the coolant. Back to sourcing these O-rings I guess…
