04-25-2023, 02:59 PM | #23 |
19
Rep 263
Hello, is this application comparable to ISTA? can it erase the fault codes of all the fault codes of each module and can it be used for maintenance procedures (example: replacement of dkg DTC gearbox oil). THANKS
04-25-2023, 03:18 PM | #24 |
7369
Rep 7,543
No it doesn't have all of the ISTA functions. However I believe it can erase those codes without issue. You can email bimmergeeks (maker of protool) to confirm this.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
04-25-2023, 06:30 PM | #25 |
7369
Rep 7,543
I just wanted to let you guys know I just recieved my BM3 wifi adapter in today and tested it with protool, and it works perfectly! So if you were looking to buy a wifi adapter I would highly recommend the BM3 wifi version over the currently available models (review coming soon which will explain exactly why).
Smiler1.50 |
04-26-2023, 03:16 PM | #26 |
19
Rep 263
do you know if we know how to modify the coding to avoid the cold start as well as to remove the burbules? is it possible to put the application in French?
04-26-2023, 04:12 PM | #27 | |
7369
Rep 7,543
I'm not sure if it supports french, you could download the app and play around with it if you'd like, it's free to do so. You only pay when you need to code.
04-26-2023, 04:33 PM | #28 |
19
Rep 263
ok thanks for the info. In my opinion I will just take the license for diagnosis because I already have BIMMERCODE, but I must be sure that PROTOOL can erase all the fault codes (DME and others) before buying it.
04-26-2023, 04:36 PM | #29 |
7369
Rep 7,543
No problem.
04-26-2023, 05:01 PM | #31 |
7369
Rep 7,543
It'll take them a bit to reply. What do you mean information for the family codes? I don't understand.
04-26-2023, 05:35 PM | #33 |
7369
Rep 7,543
It should be able to do that, because it'll be able to read all fault codes the car has and clear them. Fault codes will come back if there truly is an error, just like on ISTA.
04-27-2023, 02:03 AM | #35 |
7369
Rep 7,543
No problem
04-27-2023, 04:35 PM | #36 | |
Rep 7
M2 LCI DCT
04-27-2023, 04:55 PM | #37 |
7369
Rep 7,543
No problem at all, glad I could help.
Yes this is the V3 adapter (has the sleep mode), the V2A is the cheaper version without the sleep mode.
Smiler1.50 |
05-02-2023, 07:37 PM | #38 |
Remove Before Flight
6945
Rep 1,616
Ok-- for someone mostly coding illiterate (I've only used BimmerCode)-- what does this do that Bimmercode won't?
Specifically? And use small, easy to understand words-- coding illiterate, remember? Not talking smack-- honestly curious if this is something I'd use on my M2C-- I'm an Apple guy, so I'd have to pick up an old Android. TIA-- R.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
05-02-2023, 10:13 PM | #39 | |
7369
Rep 7,543
05-03-2023, 09:18 AM | #40 | |
6945
Rep 1,616
i.e. What are people coding *that can't be coded with Bimmercode* on an M2C? TIA. R.
05-05-2023, 10:32 AM | #42 |
7369
Rep 7,543
Again that's a hard question to answer because there's so many things that one would/could code - in particular with VO coding. But again things like the eps, ghas, egs, dsc etc are not available on bimmercode but available on protool.
05-05-2023, 02:35 PM | #43 | |
787
Rep 507
Drives: 2018 M2 6MT
05-05-2023, 10:07 PM | #44 | |
7393
Rep 7,344
1. The anti-dazzle may or may not be safe to enable due to hardware differences between EU and NA hardware (many threads on it). 2. 98% sure the M2C already comes coded to F87CS for diff and DSC. 3. Steering is already set to F87CS, though it's possible you could try the F82 settings but seems like it's probably worse. Definitely makes sense if you have an OG M2. |
