03-15-2023, 10:09 AM | #25 |
137
Rep 499
03-15-2023, 11:17 AM | #27 |
88
Rep 210
I received replacement turbo inlets from Dinan late last week. Dinan is standing behind their product. I haven't had a chance to even open the box yet but plan to look them over and install them this weekend. I will be following some of the advice provided "pbonsalb" in this thread. Thanks again.
Revan113.50 |
03-16-2023, 06:58 AM | #29 |
610
Rep 749
I purchased and installed mine in January. So far so good I guess. If I’m not getting a CEL should I assume everything is functioning correctly?
SatinblkF90136.00 |
03-24-2023, 01:33 AM | #30 |
136
Rep 254
So, I went through 2 sets of Dinan inlets, got them back in 2021 when they first came out. Cel I got was a crankcase pressure too low code, using ISTA bmw scanner tool.
Literally tried everything to figure it out, must of reinstalled them 10+ times and never got the cel to go away. Everything was installed right, everything tight. Even did a smoke test and saw no leaks or anything. Got my tuner to just “code out” the CEL and have been driving ever since without any issues. I will check to see if by now they are lose by the crankcase connection as per the video above, and if they are I am just going back to OEM and being done with these once and for all, enough is enough with poor garbage quality control on these inlets. Last edited by SatinblkF90; 03-24-2023 at 01:48 AM.. |
03-24-2023, 04:39 AM | #31 |
5293
Rep 10,686
Since the crankcase vent recirculation connects to the inlet tube ports, I agree a leak there is likely. I noticed thin carbon or gaps there and added epoxy to seal.
SatinblkF90136.00 |
03-24-2023, 09:07 AM | #32 | |
136
Rep 254
I even took them off and installed same inlets on my friends m5, left them on for a few days. He drove it 500 miles+ and no cel came on his then as soon as I put them back on mine, I get CEL. Seems like some cars it’s more sensitive to trigger a sensor than others, very weird. I figured in that case then it’s not a real problem I have to worry about, but if it’s loose after some time by crankcase connection like the video above, it’s not even worth fixing anymore as overtime more issues may come up, over a mod that literally is only for sound and no power- at that point it makes a lot more sense I just go back to stock inlets and be done with it. The joys of aftermarket sh!t when it comes to engine bolt ons… Last edited by SatinblkF90; 03-24-2023 at 09:13 AM.. |
03-24-2023, 09:56 AM | #33 |
5293
Rep 10,686
Dinan did dyno testing that showed power gains of as much as 22 rwhp in the rpm range with peak gains of 11 rwhp. On a modded car with raised boost, the gains could be greater. I bought them for that reason, not the sound though they do add to the induction sounds. Great mod along with secondary or both downpipes for both power and sound. I can hear the turbos whistle now as they spool. Probably there is no consequence from the crankcase leak, but the suction from the inlets does help pull the crankcase gas out and it is well known that too much crankcase pressure can cause oil leaks. There is also the risk that a little in filter air is being sucked into the turbos through the leak. Still, I would guess the CEL is more emissions related since the PCV system is part of emissions, than a real problem. But if it was my car, I would fix them myself or send them back to Dinan for replacement.
SatinblkF90136.00 |
03-24-2023, 10:53 AM | #34 | |
136
Rep 254
A replacement was already done and made no difference. Both times, for both sets we tried the same inlets on 2 different f90s and in both cases only mine triggered the CEL while the other one did not. I am going to say then it’s definitely just emissions related which is not a real problem, and my car for some reason was just being more “sensitive” about it, it seems. The mechanic also came to the same conclusion, I just hope it won’t result in any actual issue. Already driven over 10k with cel coded out and it’s not caused any leaks or issues of any kind. The dyno is nice and all, but I tested the 100-200kph times on and off on stage 2 with 23-24psi on 93 so quite aggressive of a tune (over 700whp) and they did not improve the times by even 0.1s difference, overall average on all runs were identical times as stock inlets. Maybe they do add 11whp but it’s not enough difference to actually be measurable by a dragy or anything? Might just be too small to see. Based off the times it seems they don’t. They are a good sound mod, plus I also noticed the throttle response/turbo spools a bit faster so they do also add faster response time, and likely some low end torque. Still good, and hope to not have to switch them out for stock but if they are getting looser over time and building up more issues (I still have yet to check this) it’s not worth it for such a marginal improvement in how it drives/sounds. Last edited by SatinblkF90; 03-24-2023 at 11:00 AM.. |
03-24-2023, 10:56 AM | #35 | |
137
Rep 499
SatinblkF90136.00 |
03-24-2023, 11:15 AM | #36 |
5293
Rep 10,686
I don’t read Dinan’s description that way. Rather, to me, it appears the intake does not add measurable horsepower at stock power levels, while the inlets do add power. But I also agree 11 rwhp peak added to roughly 570 rwhp peak will not show up in testing. The biggest bang for the buck is a tune. Inlets and downpipes add less but do add power. At some point it becomes noticeable in acceleration times and as the boost goes up, reducing restrictions helps more and more.
SatinblkF90136.00 |
03-24-2023, 11:45 AM | #37 |
136
Rep 254
Yes I remember reading directly from dinan themselves that it starts to make a “measurable” difference only from 1000hp+ builds, but before that it’s negligible. So, even on stage 2 they basically just add sound and increased throttle response. Still not bad for the price, as long as they actually work without all the BS.
03-24-2023, 12:34 PM | #38 | |
137
Rep 499
SatinblkF90136.00 |
03-24-2023, 12:38 PM | #39 |
136
Rep 254
Yup, not a measurable difference but can feel and hear that quicker turbo spool/sound which most CAI don’t do as well, that’s why I got them in the first place. Combined with BMC high flow air filters the car has instant throttle response in sport+ mode and the turbos kick in sooner and harder on power delivery.
03-28-2023, 12:58 PM | #41 |
136
Rep 254
03-28-2023, 05:19 PM | #42 |
76
Rep 724
I am not sure as the BMW dealership did not share the specific codes with me. I have a request into Dinan to get replacement turbo inlets under warranty. Hopefully that goes through smoothly and I get my defective ones replaced. Only problem is that Dinan is telling me that labor is not covered which is disappointing since the labor costs almost as much as the inlets themselves. I am also concerned that I will have the same issue with the replacements since this seems to be a common manufacturing defect.
SatinblkF90136.00 Jimmy K123.00 |
03-28-2023, 05:57 PM | #43 | |
136
Rep 254
No issues since, and I believe it’s just emissions related that some cars are sensitive and trigger it, but not a “real” problem with the car. |
03-28-2023, 06:00 PM | #44 | |
76
Rep 724
