07-03-2022, 07:22 PM | #23 |
130
Rep 216
Dealer on charges $160 including fluid. One of the cheaper maintenance items.
Maverik2594150.50 |
06-19-2023, 12:19 PM | #24 |
554
Rep 551
Per my dealer brake fluid is suppose to changed every 2 years. My 18 M5 notified me it needs to be done. Price quoted is $209 discounter from $269 from my BMW dealer in SOCAL. My BMW work bike also requires the two year brake fluid change.
07-16-2023, 09:28 PM | #25 |
133
Rep 393
Drives: 2021 M5C
So I don’t need a scanner to bleed the brakes? I have the pressure bleeder already.
07-17-2023, 10:13 AM | #27 |
133
Rep 393
Drives: 2021 M5C
07-17-2023, 10:44 AM | #28 |
5288
Rep 10,686
I don’t know since I have not done it. I assume ISTA will. There are also other scan tools that should do it but ask the manufacturer to be sure. Some of those have annual subscription costs. Some don’t.
07-17-2023, 05:54 PM | #29 |
2281
Rep 3,305
I have ISTA. There is no routine that I could find for the US market cars. I watched some videos of this on the European cars. I followed the same ISTA routine and could not find anything to activate the ABS unit.
Mike
07-25-2023, 10:06 AM | #30 |
4151
Rep 7,165
Drives: F90 M5 / F15 50i
You don’t need to activate abs if you’re pressure bleeding.
'07 Yamaha R1 (sold)
07-25-2023, 11:16 AM | #31 |
337
Rep 414
Drives: 23 M5C, 19 X5
You might be thinking you need a scanner because on the latest BMWs with DSCi like the G05 X5 you do. They are designed differently so you need ISTA to open some valves. Fortunately the M5 is the old school way so just a pressure bleeder is all you need.
PDOT133.00 |
07-27-2023, 03:37 PM | #32 | |
2281
Rep 3,305
I did my kids civic twice also, yesterday I did it after placing some brake lines from the master cylinder to the AVS module and my scan tool would not talk to this car. 2013. I got an error message "Access denied, DCT's exist" blah blah blah. Frigen HATE these scanners. LOL. I looked for the BMW setting for the ABS in Ista also. Did not see it. I'll have to look again. Mike
07-27-2023, 03:43 PM | #33 |
337
Rep 414
The M5 doesn't need anything special. In the G05 ISTA download the very first thing is:
The dealer training guide for the X5 talks about DSCi in detail. When I first paid for ISTA I got ALL the technical guides available. I've read all the M5/N63/S63 ones and the G05/B58 ones so far. |
07-27-2023, 03:45 PM | #34 |
337
Rep 414
Oh, and I read the DSCi specific guide, which is where I found:
If the brake fluid is renewed by pressing the brake pedal and without using a bleeder unit, only a very small amount of the old brake fluid is removed from the brake system. Furthermore, instead of replacement, the brake fluids are subject to a high degree of mixing. And: The routine for brake fluid renewal serves to activate the linear actuator to evacuate the brake fluid volume of the expansion tank and to change the old brake fluid in the pressure chamber. The main reason for DSCi was to remove the need for vacuum...which you no longer get for free on an electric car. So to make a new brake system for for ICE and electric they are moving to DSCi. I would assume the G60/G90 will get it too. |
08-13-2023, 05:38 PM | #35 | |
1839
Rep 1,328
The noise is EPIC. I've never known about it on the F90. No idea why the DSC on the F3x is different. But I know different kinds of cars recommend it. Despite the units almost always coming from Bosch. Shawn |
09-12-2023, 07:27 AM | #36 |
Rep 5
I have 19 M5C with carbon ceramic. Could anyone suggest the brake fluid type? I searched here and internet for answer but having trouble finding.
09-12-2023, 04:14 PM | #37 |
1543
Rep 2,022
09-12-2023, 06:30 PM | #38 |
337
Rep 414
I think we need a DOT 4 Low Viscosity fluid. ISTA is a little confusing because it says if you have a DSC pre-charge pump you don't but then doesn't list any non-low viscosity fluids. I forgot to download the ABS/DSC overview but I'm pretty sure our DSC does not have the pre-charge pump.
09-13-2023, 04:26 PM | #39 | |
1839
Rep 1,328
https://www.ecstuning.com/b-genuine-...l/81220142156/ Which is just fine as a DOT low vis fluid. High quality DOT 4 of any kind will do, just try to use a high quality brand. This will be just fine. Shawn |
