F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > 8HP70 Transmission Swap Writeup
proTUNING Freaks
      07-20-2021, 11:28 AM   #23
Dr.Wotk
Azerbaijan
Drives: BMW 340i F30
Originally Posted by SC_B5X View Post
Can confirm. Issue is now fixed!
Hi. I also think about HP70 swap on my 340i rwd. Just have 2 questions.
1) I don't understand exactly, which transmission support bracket have to use for correct installation, 330D F30 one ? Or 328i f30 one ?
2) can use HP70 from 535D rwd, 640d rwd n57z ? Or only 330D/430D/530D/730D ?
I ask Because 535D and 640D gearbox (8hp70) different part numbers from 30D ones, and bmwcats shown that its not interchangeable.
      07-22-2021, 02:39 AM   #24
DuaneDibbley
Drives: m140i
Great writeup, thanks
What's the shift quality/speed like between the 50 and the 70?
      07-23-2021, 07:00 AM   #25
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
They are the same
      08-04-2021, 03:34 AM   #26
Romanychev
Drives: Bmw F30 340
Originally Posted by RBT-Tuning View Post
The "Stuck-in-Comfort" mode issue should be now fixed for all cars. We uploaded the update 10 minutes ago!
Are you planning to add software for the 8HP75 as well?
      08-04-2021, 03:40 AM   #27
RBT-Tuning
RBT-Tuning's Avatar
Austria
713
Drives: A lot of BMWs...
No, no plans for that.
      08-04-2021, 04:19 AM   #28
GA/\/\/\/\A_CT
228
Drives: ‘20 m340ix
OP you are a saint for writing this up like you did, thank you!
As a 6MT guy, I’ve got 2 questions:
1. Is it much more difficult to swap from a 6mt to an HP70? I imagine the electronics would be the issue...not sure
2. If the 330d has a beefier auto than a 340, maybe they also spec’d a beefier 6mt? Something that I’m guessing @Kern417 and others will soon chime in on.
      08-12-2021, 09:32 AM   #29
feelingCherry
Drives: BMW F30 xDrive 2015
My F30 has the 6MT at around 630~ whp at this point. I am currently wanting to swap over to this auto transmission for better drivability as LA traffic is really starting to kick my ass driving around with a twin disk clutch.
I am guessing to run this I will need some additional stuff -
1. Auto trans harness
2. Delete the master cylinder
3. Add Transmission cooler + Cooler lines
4. driveshaft swap possibly?
I checked on real oem and seems the front drive shaft is the same on both the auto and manual. The rear driveshaft however is different with the manual using 26108676285, and the auto using either 26108676284, or 26107600194. If this is the case will I need to buy a new pumpkin too? Or are the splines at the end of the driveshafts the same and the only difference is length?
      11-04-2021, 02:02 PM   #30
Romanychev
Drives: Bmw F30 340
Hello. Today you have released the software for the M550i, with which I have an automatic transmission. Can I adapt it for b58?
      02-20-2022, 05:19 PM   #31
Glemm1970
Glemm1970's Avatar
Russia
316
Drives: BMW M140IX.
I put HP70. Transfer case kit from Real Performance. 2500$.
https://www.realperformance.ru/untitled-cx7k
The whole job took one working day. There are no installation difficulties. The hardest part is the software to run the HP70. None of us could do this before. And I had to buy a new full license and Xhp firmware. An important clarification, the HP70 itself is needed from the F 35-40D. There's a better trance itself (bagel).
M140IX. Turbo Pure 800 Cast.
Appreciate 3
      03-11-2022, 03:01 PM   #32
BmwM140i
Drives: M140i
Hi need some help have had the hp70 swap done on my car have xhp installed but the shift logic is all
Off from comfort to sports plus in D mode shift patterns don’t change no hard shifts at all and have to apply well over half a throttle to get car to downshift. Feels really lazy like it’s kept the diesel characteristics.
S mode feels like it works as it should.
Is this normal ?
      03-11-2022, 03:23 PM   #33
BMWILUVU
814
Drives: 340ix
Any upgrade requiring an engine drop is not for me but this is awesome that this swap works out.
      03-11-2022, 06:46 PM   #34
Glemm1970
Glemm1970's Avatar
Russia
316
Drives: BMW M140IX.
Is this normal ?
Comfort and D, all shifts and the pedal itself is sluggish. The Sport S will drive fine.
      03-12-2022, 06:50 AM   #35
BmwM140i
Drives: M140i
Thanks for reply
Damn was hoping it was an issue feels like I lost half my transmission modes
Thing is comfort to sport plus is slow and lazy now
S mode is no good for motorways hangs in the wrong gears
Sport plus D was a perfect all rounder.
Wish I knew this before the upgrade would have just stick with the hp50 and gone with a pure build further down the line
      03-12-2022, 02:38 PM   #36
blacksapphire440i
Novice
blacksapphire440i's Avatar
316
Drives: 2018 440i Gran Coupe
Thanks for reply
How is manual mode? Is there no work away around this?
      03-12-2022, 06:37 PM   #37
BmwM140i
Drives: M140i
Manual is just manual mode won’t change gear unless u use the paddles of lever
Astonished nobody mentioned you lose sport and sport plus D mode and get left with just S.
Even more confused as to why xhp has not updated the one map available for the hp70 to fix this.
Would I do it now I know … definitely not
Top it off only thing that I could have fixed it was the shift map editor but doesn’t even work on the hp70 xhp lol
Sum it up I’ve got slow lazy horrible shifting witch won’t literally downshift until over half throttle is applied but upshifts like crazy in all three modes comfort sport and sport + witch is a horrible mix or S that actually does something but is crap for the motorway
Anyone know any custom transmission tuners that I could pay to fix it ?
      03-12-2022, 08:52 PM   #38
Glemm1970
Glemm1970's Avatar
Russia
316
Drives: BMW M140IX.
Yes. It saddens me too. Press the pedal 50% sad!
      03-13-2022, 06:47 AM   #39
BmwM140i
Drives: M140i
Does it not bother you that it loses half transmission modes. It’s literally all or nothing no In between. Lost the ability for fast road driving and motorway driving in one mode.
Either pulling away like a snail or driving like a mad man
      03-13-2022, 08:33 AM   #40
Mr. 340
68
Drives: 2016 BMW 340i
Since your HP50 is out, send it to Pure Drivetrain Solutions to get it built. Then once you get it back just sell the HP70.
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger
PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust
PJ ACN91 + Meth tune| XHP Stage 3
      03-13-2022, 10:30 AM   #41
BmwM140i
Drives: M140i
Was thinking that probably my only option.
Thought xhp for the hp70 was going to be the same as the hp50.
Or try find a custom tcu tuner.
Speaking to a couple at the moment
      03-13-2022, 01:05 PM   #42
blacksapphire440i
Novice
316
You cannot tune the HP70 to act like the HP50?
      03-13-2022, 02:06 PM   #43
BmwM140i
Drives: M140i
How comes ?
xhp do stage 1 2 and 3 for the transmission on the cars they actually come out of.
Can’t see why you couldn’t alter the shift points to feel like the hp50
And it feels like the hp50 in S mode. So more than likely be possible
      03-13-2022, 04:23 PM   #44
Mr. 340
68
Yeah try that first. Let us know how it goes. Good luck!
f30post
