BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    F90 Thermostat
      06-23-2020, 10:51 PM   #23
Mcc420
Mcc420's Avatar
484
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
I've done it. It's about a 1.5hrs Max. And that's taking your time. I did it from up top. But I think it can be faster from the bottom but I didn't want coolant running down my arms lol.
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53
F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml.
Ig @mcc420
Appreciate 2
ss_m577.00
FSociety3872.00
      06-24-2020, 12:16 AM   #24
BMWDriverX
Drives: G12 750i X-Drive
What about the vacuum and all that so the cooling system works correctly after the thermostat install?
      06-24-2020, 04:33 AM   #25
Sophisticated Redneck
1449
Drives: 2012 BMW X5 50i
1.5 hours start to finish taking your time? That would be an impressive sight to see this amount of work done & filling and bleeding both cooling circuits that quickly.
Here is a link to the full instructions for all that are interested:
https://www.newtis.info/tisv2/a/en/f...nes/1VncI3daZd
      06-24-2020, 08:44 AM   #26
Mcc420
Mcc420's Avatar
484
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
No need to vacuum the system. And you're only emptying the rad coolant not the ic's. Remove the front cowl , remove rad fan and it's right there.
Ig @mcc420
FSociety3872.00
      06-24-2020, 11:12 AM   #27
bm5bullit
bm5bullit's Avatar
Drives: 2021 BMW M340i
What is your experience with the claims about improved cooling and do you think it was worth it?
2021 M340i
2020 X3 M40i - her car
2019 M5, AW, DP's, MSR CAI, BM3, SOLD
2020 Chev. ZR2 Bison truck, Daily Driver
      06-24-2020, 11:24 AM   #28
1449
Ok I can see how you could do it that quickly now, the official BMW instructions has you remove the passenger Intercooler.
BMW puts the fear of God in you though to drain and vacuum system or the engine will go boom and I have to agree, I think it's an important step and insurance that there will be no air trapped in the system, especially on such an expensive engine but to each their own on doing it or not.
      06-24-2020, 11:25 AM   #29
Used2be
Perennial PFC
Used2be's Avatar
351
Drives: 2019 F90 M5 DG/Aragon
Both of you, Redneck and Mcc420, have more experience with this part of the car than I, but I still have some questions. Mcc, after removing the radiator fan, is there adequate space to remove the thermostat from the top without the removal of anything else? I can’t see the thermostat in your upper photo, but perfectly in the middle photo. Is the middle photo also taken from the same position as the upper? Looking down into the engine bay from the top? Or, is your slim phone lowered to the level of the thermostat with one hand, a perspective that can’t be had while you’re working? It seems it would be very difficult to get a socket on all three of the thermostat bolts with only the radiator fan removed. Any special contortions or tools needed to do that?
By removing the thermostat you introduce air into the cooling circuit, even if it isn’t into the intercoolers. Isn’t the purpose of bleeding the air out of the system to eliminate any bubbles that might obstruct water circulation inside the tight water passages in the engine or create hotspots? Wouldn’t it be prudent to do the recommended vacuum procedure?
I’m not clear how a lower opening temp for the thermostat keeps the engine cooler when it’s being driven hard. Both thermostats open fully and allow the same full flow when needed, don’t they? Under high demand, say for half an hour on track, wouldn’t the system provide the same cooling with either thermostat? A thermostat is used to bring, and maintain, the engine at the operating temperature BMW wants in a shorter amount of time. Otherwise, why have a thermostat at all? Does BMW perhaps use the higher temp thermostat for emission reasons? I certainly don’t think the 90c thermostat would hurt the engine, but it seems the benefit derived isn’t worth the effort needed to replace.
Good question from bm5bullit. I’m interested in your answer also.
      06-24-2020, 11:43 AM   #30
1449
Your right when being driven hard the computer opens the thermostat, what the 90c thermostat really makes a difference is in the daily driving commutes, stop and go traffic, part throttle performance around town, and preventing engine temps from hitting 225+. If your M doesn't see alot of stop and go traffic/daily driving, then benefits will be limited compared to someone who does. BMW runs them hot for emissions compliance only. 10-20 degrees may not seem like alot but it will give a mild performance bump, reduce intake temps, but mainly extend the life of the engine seals over the course of the life of the engine.
The original N63 and S63 were notorious for fried engine and valve guide seals popping up around 60-80k. Next gen TU & TU2 had improved cooling but you are starting to see this pop up again on engines that are getting up there in Mileage.
Used2be351.00
      06-24-2020, 01:14 PM   #31
Mcc420
Mcc420's Avatar
484
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
No special tools needed. All pictures were from the top. I did this within owning the car for a month so no before data. If anything this thermostat will open to the full position quicker since it's designed to open at 90. As for bleeding it almost self bleeds like any other car. Fill up until no more bubbles let run for about fifteen minutes with the cap off and just keep topping it up. Drive for a day or two check again top up if necessary. I also added two bottles of redline to the rad and one bottle for the ic's. If you remove the bottom skid plate you can save some of you coolant.
Ig @mcc420
      06-24-2020, 01:41 PM   #32
Used2be
Perennial PFC
Used2be's Avatar
351
I suppose you're right. BMW wanted the same procedure done for their liquid cooled motorcycles too, and all the shops I knew of didn't bother. Let it run, watch the bubbles, and add as needed.
Different subject. How do you like the F90 as opposed to your very fast modified F10? More potential?
      06-24-2020, 02:49 PM   #33
Mcc420
Mcc420's Avatar
484
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
Yes definitely more power. I've broken all my old records already lol with stg2 ots e30. The best thing to say about the f90 is useable power all the time 👍🏾. If you're addicted to torque like I am then awd is the way to go. It's my first awd powerful car. It's almost comparable of going from the e60 to the f10 lol. Almost.
Ig @mcc420
FSociety3872.00
      06-24-2020, 02:54 PM   #34
Mcc420
Mcc420's Avatar
484
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
I did more for peace of mind. And also I didn't have to pay anyone to do it. I'm also running redline 5w50.
Ig @mcc420
      06-24-2020, 03:27 PM   #35
bm5bullit
bm5bullit's Avatar
Yeah. I would be doing it for the same reasons and because I have not finished my other mods on the car.
2021 M340i
      06-24-2020, 05:11 PM   #36
Used2be
Perennial PFC
Used2be's Avatar
351
Mine also and I love it. Peace of mind for me. There were a couple of situations on the street where I forgot myself with the 2wd of the F10 in first or second gear and the fishtailing was more than I'd bargained for. My F90 is still stock engine wise, but I feel even with a tune it'd be more well mannered.
Congratulations on the F90 times! AWD sure helps the et, doesn't it? But now you're lusting after the 9s! Good luck with it.
Mcc420483.50
      06-26-2020, 12:06 AM   #37
Mrbig
115
Drives: 15 M3
What coolant are u guys adding to the car ?
      06-26-2020, 11:35 AM   #38
Used2be
Perennial PFC
Used2be's Avatar
351
I used the same stuff I had on hand from the 2013 F10 M5 I'd owned. Never thought to check to see if BMW has changed the formula. 50/50 mix BMW antifreeze/coolant from a one gallon container I bought from the dealer. Not sure if this is a part # or not, 82 14 1 467 704.
Mcc420483.50
      06-30-2020, 02:38 PM   #39
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
Originally Posted by FloridaM5 View Post
Thank you for that; appreciate it. Some conflicting points of view and/or assumptions being made. Not atypical.
Well shit, just checked at 8800 miles and I’m well below min. Wtf.
      11-23-2020, 03:30 AM   #40
SatinblkF90
SatinblkF90's Avatar
138
Drives: 18 F90 M5
Any updates on what to do about this? Literally freaked out reading about this ridiculous coolant issue the f90 has.
      09-22-2021, 09:15 PM   #41
brad65ford
286
Drives: 2022 M3
purchased one of theses today. curious how much of a bitch it is to install. If found it funny how someone lists/states 6-7 hour job and two other guys finished theirs in 1 1/2 lol. We'll see what happens, looks fairly easy....
      09-03-2022, 09:27 PM   #42
pbonsalb
5731
I installed the 90C thermostat today. Definitely took my more than 1.5 hours but it was my first time on this car. One of the thermostat bolts was hard to access. The fan came out slowly. There are about 3 hoses you need to unclip and 1 wire and of course the harness. I massaged the upper radiator hose to get the fan to pass by but disconnecting the hose from the radiator may be better. Also had to move the front connector bar and air box tops and braces.
I’d say I lost about 1.25 gallons of coolant doing the job. Replace with the new green coolant. Not sure about the benefits of the lower temp thermo but some say it is a good idea including one drag racing member who is in this thread and one engine builder. The gauge in the car is oil not coolant. I could plug in a scan tool — probably should so I can see oil and coolant temps.
Maverik2594300.00
      09-10-2022, 09:04 PM   #43
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Lol so many opportunities for someone to document a DIY and yet nothing. Y'all are killing me.
Ok I guess I'll have to do it once I get around to this myself. Ugh.
Glad it seemed at least straight forward. Did this on my AMG back in the day and they was super easy. Didn't have to remove anything but some hoses.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      09-10-2022, 09:38 PM   #44
pbonsalb
5731
It’s a little more work than that. I am not good about taking pictures though I do like to ready a DIY before doing a project when one is available. I have done oil, braided brake lines, brake flushing, Dinan monoballs, competition motor mounts, H&R springs, charcoal filter delete, drop in filters, JB4, water/meth, flash tune, trans tune, downpipes, turbo blankets, coolant tank, coolant thermostat. Next will be front diff, transfer case, rear diff, rear subframe bushing reinforcements, Dinan rear toe link kit, and Dinan turbo inlets.
Maverik2594300.00
