TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > CIC/NBT FSC Generator - Windows/Linux/OSX
      04-07-2018, 05:32 PM   #23
akela1979
Drives: F10 (2010)
Originally Posted by Jagaer View Post
If you would like to help out, and have pulled your FSC file, please send me a copy. I will not include or publish any car-specific information, but will add the FSC file date and RSA key to the RSAKeys.txt file. Hopefully if enough are gathered, some people will be able to create an FSC for their car, without having to pull any files.
Tnks for the key gen
A like help the komunity
How kann a send you a b1 file? from F10 (2010)
      04-07-2018, 05:32 PM   #24
Jagaer
430
Drives: 2011 E91 328xi 6MT
Links updated
      04-07-2018, 05:42 PM   #25
akela1979
Drives: F10 (2010)
I have sent you one pm message
      05-04-2018, 05:12 AM   #26
AstroZ
Drives: E93
generator issue
hi there
after extract the 1b file using the USB copie_scr.sh method I have the following error message with this generator:
"Incorrect RSA Key Header/Footer
File Likely Corrupted"
can you help me solve this?
my FSC.hex is:
Code:
0101 001b 0001 2020 3939 3939 3939 0220
3939 3939 3939 3930 2020 2020 0141 3438
3532 3435 0100 0000 0000 0000 0000 0402
3230 3130 3033 3233 3030 3032 5a00 810c
80de bf80 3cf7 6526 b566 4915 99bb 910a
dcbf f453 2282 9347 3309 8ad7 9cfb fb4c
cfa4 b3b5 8ea7 7f8d a009 d7f4 fd63 818f
ecba 6a17 3f84 ee2b 3799 b954 2f8a 43f5
9b56 d43b e5c4 8326 c1a2 10c1 3f67 2d49
7159 d142 c466 dc52 7dc6 20ed 6ed3 e59e
d248 f731 5137 cd0c 0109 e14f 3ff3 cdee
d0cd dc08 87f5 1769 467c 7f52 600a a228
de00 d929 cca2 490d 1e9c 3420 a8f5 9f1c
a4fc f7c7 72fd 5c9e 6051 36f0 3e4f 6a77
6cc6 9300 78dd 9e89 ef8a 366d 4df2 d5f7
294b 14c6 7ce4 7b7b 6cb2 318e 3c51 7185
c7fc 37e2 ebb1 3b74 f732 371a af1a 546b
1b2f 526b a106 9f40 0828 8bd7 78e2 035b
d94b 8502 acb9 9897 fc61 2ff0 e6ec c764
17bb 3852 b902 cec4 27ae 21b1 9cd9 1f
Code:
AQEAGwABICA5OTk5OTkCIDk5OTk5OTkwICAgIAFBNDg1MjQ1AQAAAAAAAAAAAAQCMjAxMDAzMjMwMDAyWgCBDIDev4A892UmtWZJFZm7kQrcv/RTIoKTRzMJitec+/tMz6SztY6nf42gCdf0/WOBj+y6ahc/hO4rN5m5VC+KQ/WbVtQ75cSDJsGiEME/Zy1JcVnRQsRm3FJ9xiDtbtPlntJI9zFRN80MAQnhTz/zze7QzdwIh/UXaUZ8f1JgCqIo3gDZKcyiSQ0enDQgqPWfHKT898dy/VyeYFE28D5PandsxpMAeN2eie+KNm1N8tX3KUsUxnzke3tssjGOPFFxhcf8N+LrsTt09zI3Gq8aVGsbL1JroQafQAgoi9d44gNb2UuFAqy5mJf8YS/w5uzHZBe7OFK5As7EJ64hsZzZHw==
my previous fsc that worked was:
Code:
AQEAGwABICA3NzM0ODcBIDI4NzM4NjMAZQFBMTcwMzA3AQAAAAAAAAAAAAQCMjAwOTA5MTQxNzU2WgCBDIBkLeLqyFDLoud0AWuZEJfZUXID9jqfjGNKTHt3pezeziEsmbhurCmabg1JR+oqt6iPnoy7KojsGut1ngS9y+QdqiL1buw5AZTxDNjsBIStf5YlKqrLo+5+k5SNHd4PgrobK2ovcpgkLB/TaXubRf3pN1aFbEiUtGkNocvU5GqIHwCTCY9nAEe0o+bVOnUTmTq9nd/AWACGnqlbg0u8iIh29+0eqUuDfwLbPIF/vCufFkHKd2mN0LzhRryym/a9Nmr+lyzb6oA+uV0wvdFmbcRR42FiyJGNNsgjykWcHTIcN4BXSVp9b5asg7OP0vTb8X9C2Fh8lWNQDG1SDAUoKBdqSg==
      05-04-2018, 06:40 AM   #27
Jagaer
430
The FSC.hex file doesn't appear to have been pulled correctly.
It looks like there are bytes inserted into the header between positions 0x17 and the start of the VIN at 0x1D. (VIN should start at 0x1A)
I've removed 3xBytes to align the VIN, and RSA keys within the file. (Rename AstroZ.pdf to AstroZ.hex)
***This file will generate a key, but they code may not work as "File Likely Corrupted"***
File Type: pdf AstroZ.pdf (319 Bytes, 1152 views)
      05-04-2018, 11:43 AM   #28
AstroZ
Drives: E93
the file was pulled using the glovebox usb method and 319 bytes long so not sure why the extra bytes were inserted (not my CIC)
But it could have been any of script activated or emulator (100% has a emulator) or self signed certificates or perhaps my USB stick (32GB sdcard with adaptor)
yep i noticed the 00s inserted at the end
it worked though updating the maps to 2018-1 via the same 32GB SD card using the generated lifetime code. thanks for this
EDIT: finished updating
Last edited by AstroZ; 05-04-2018 at 12:02 PM.. Reason: EDIT: finished updating :)
      05-06-2018, 08:28 AM   #29
Minde18
Drives: BMW E91 318D 2010
Hello, maybe someone can help me to get FSC code? I have 1b file from my car, but then I add it on "BMW_CIC_FSC_Generator" I can't select region and maps.
      05-06-2018, 10:30 AM   #30
Jagaer
430
Two possible reasons
1. The generator defaults to premium, but requires you to set the map type first. Click on "Premium" and a dropdown will appear. Select the type of map you need
2. You don't have internet connectivity. An error message should have popped up telling you that it couldn't download support files.
      05-06-2018, 11:20 AM   #31
6ixSpd
Save the manuals!
6ixSpd's Avatar
6035
Drives: '16 M3, '23 718 Spyder
Whenever I launch the FSC_generator.EXE it just opens a MS DOS window which shuts itself down in one second. Any idea what is wrong here?
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      05-06-2018, 12:54 PM   #32
Minde18
Maybe you can generate if I send you my 1b file?
      05-16-2018, 06:09 AM   #33
ExiizZ
Drives: E92
Hello maybe somebody can help me.
I am driving a E92 with CIC Navigation (Navi Prof).
I successfully got my 1B File.
I am trying to update my MAPS to Europe Premium West 2018.1 with (1x USB)
I generated about 5 different FSC (with and without lifetime) and so on.
I plug in the USB some seconds later the Navi Prof recognize the USBUpdate and want the FSC. But it altways says invalid FSC...
I tried the method with jaegers generator and the other one with changing the FSC.Bat to 0x28 0x10
Smb may know where the Problem is?
      05-16-2018, 06:28 AM   #34
Jagaer
430
ExiizZ
Is your CIC set up with Europe Premium West? If your CIC came with a different map type or region, you will need to add that FSC to your CIC before you can update the maps. ( https://cartechnology.co.uk/showthread.php?tid=23198 )
If you have a retrofit CIC, the 1B file retrieved may not match what the CIC is expecting. (Emulator, Script Activation...)
      05-16-2018, 07:46 AM   #35
ExiizZ
Drives: E92
ExiizZ
In my Nav Version there is only Road Map Europe PREMIUM 2010
Without any West or East.
Can this be the failure?
The NAVI Prof was standard no retrofit
      05-16-2018, 08:49 AM   #36
Jagaer
430
0x28 0x10 doesn't appear to be valid for any set of maps - Europe Premium 2014-2 is 0x28 0x08 and Europe West Premium 2015-2 is 0x28 0x0A
The GUI Generator will automatically grab the correct values out of the Lookup.xml file, but if you want to use the DOS version, the values should be 0x28 0x2D
Code:
<SgbmId id="NAVD_000004CE_255_004_194" SWID_FscShort="0028002D" name="Road Map Europe West PREMIUM 2018-1" supplier="NTQ" sop="01.09.2017"
Are you certain your USB is EUROPE WEST 2018-1? Map 2018-2 is out, and would require a different FSC code.
ExiizZ1.50
      05-16-2018, 09:44 AM   #37
ExiizZ
Drives: E92
Code:
Well actually I also often used the GUI Generator but it is still a invalid code. Yes it its 100% 2018-1 I double checked the thread where I got the files and the zip file names are also 2018-1
      05-19-2018, 07:37 AM   #38
Jagaer
430
Linux Console version added
      05-26-2018, 05:47 AM   #39
BimmerSLO
Drives: e46
Hi Jagaer,
please contact me via PM. I have files that could help you.
      05-30-2018, 03:41 AM   #40
Arual
Drives: Bmw 320d E92
Good Work
      06-02-2018, 04:52 AM   #41
Aaronexx
Aaronexx's Avatar
United Kingdom
Drives: E92 335d
damn I was too late by less than a month! does anyone have an updated version? or can this still work?
Previous: E90 320D
      06-02-2018, 06:07 AM   #42
Jagaer
430
@Aaronexx - Both the links and the generator are working. (It's really easy, if you use portalseo's USB stick method to get the 1B file)
      06-10-2018, 05:41 AM   #43
br_318_d
Drives: X1 xDrive18 DA
help
can anybody help me please.
My FSC generator give me a codes but they dont work.
I have 2010 CIC with europe premium 2009-2 and I like to update to europe east premium 2018-1.
Can someone find me a fsc code that works. MY VIN is: VJ95858
      06-11-2018, 01:37 PM   #44
timofey
Drives: Bmw E90
Unhappy FSC File Error
Hello!
I need help!
I brought the file from CIC via usb, but an error when generating the code. In the file I can not detect what is wrong.
Thank you in advance!!
