04-13-2021, 09:09 PM | #23 | |
32
Rep 160
Drives: 2017 M2 6MT/2017 Hyundai Azera
04-23-2021, 01:45 PM | #25 |
BimmerPost Supporting Vendor
1804
Rep 3,070
Best way is to run ISTA then code out using E-Sys.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
Jamongkad239.00 |
04-28-2021, 05:06 AM | #26 |
32
Rep 160
I made all the coding changes on e-sys and I downloaded tool32 to try and clear the last error code I have which is the "Driver Restraint System Malfunction". I do have the seatbelt receptacle properly plugged into the factory yellow connector but it seems like some people on this thread are still having this issue even after resetting everything with tool32? Hopefully, my warning lights will go away after I try using tool32... *fingers crossed*
04-28-2021, 10:46 AM | #28 | |
1804
Rep 3,070
Your issue is not in clearing codes. Probably in coding or wiring.
04-29-2021, 12:51 AM | #29 | |
32
Rep 160
I also double-checked to see if the connector is plugged in correctly but I can plug it out and plug it back in to see if that helps? LOL I asked some dude who was having the same problem and he told me that I have to use tool32 because "the airbag module has to be reinitialized with the new settings, otherwise the errors get triggered again regardless of coding" If none of these solves the issue, I might just go get it done at a shop for $50 I just wanted to try and solve this issue myself... |
05-14-2021, 08:32 AM | #30 |
Save the manuals!
6035
Rep 6,754
Bumping this.
Did anyone ever get it to work? I've coded out all seat-related airbag and belt codes. ISTA shows no airbag or seat belt faults whatsoever now, just missing seat modules (as expected, but these don't trigger ASCM codes as far as I know). No seat belt or seat airbag contacts are plugged in. Gurtstammer and Gurtkontakt - nicht_aktiv for both seats. SBR for both seats - nicht_aktiv Initwarning - nicht_aktiv CIS_Beifaher - nicht_aktiv Sitzairbag_Thorax_Fahrer & Sitzairbag_Thorax_Beifahrer - nicht_aktiv Sitzpositionsensor_Beifahrer & Sitzpositionsensorserkennung_Sitzmemory_Fahrer - nicht_aktiv I used Tool32 to reset it as well, but the car still shows driver and passenger restraint system faults... The remaining errors are below: Last edited by 6ixSpd; 05-14-2021 at 09:19 AM.. |
01-09-2022, 06:21 PM | #32 | |
1804
Rep 3,070
Can fix if needed
