12-15-2016, 10:01 PM | #23 |
2925
Rep 1,303
Drives: 2021 C8 Corvette 1LT
Adding the burger CAI actually make my exhaust louder as well. Made the overrun more noticeable as well with some slight turbo spool. With the JB4 the overrun is much more apparent even in comfort mode and turbo spool now comes with a slight bov sound. Other option would be a catless DP if you want a louder exhaust. There is a catted DP out for the 340, but every time I checked it said out of stock. Not sure if it was discontinued.
12-17-2016, 01:18 PM | #26 |
1788
Rep 4,529
BCS midpipe
Another video Taken from this thread http://www.babybmw.net/forum/viewtopic.php?f=74&t=93506
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
AlexM240i103.00 |
01-01-2017, 08:32 AM | #27 |
175
Rep 247
Has anyone tried removing BOTH resonators? Also, as one person said, the first "resonator" may be a secondary cat after the oxygen sensor, so I'm wondering if removing it would actually be beneficial from a performance standpoint while not throwing a code.
01-01-2017, 09:34 AM | #28 | |
Rep 19
01-01-2017, 12:44 PM | #29 | |
2925
Rep 1,303
Sure, removing any resonator/secondary cat would provide better performance, not not a huge difference. If you're asking about leaving stock downpipe (with primary cat) and removing the mid pipe if you wouldn't get a code, then I would think yes only because both sensors that would trigger a code are in the downpipe, there's no sensors to trip after that. If you mean going catless downpipe and straightpiping the midsection then yes, you will most definitely get an error code. |
01-01-2017, 03:14 PM | #30 | |
103
Rep 303
I'd like to know more about this modification. This midpipe connects to the stock downpipe or to the first resonator (the squared one) ?? I mean, does it remove the squared and the cylindrical resonators before the axleback or muffler or just the new cylindrical one (not present in M235i) ??? I'd like to improve the exhaust sound but preserving the stock downpipe (specially because of the warranty). This midpipe is attached to the stock clamps in the chassis ? Last edited by AlexM240i; 01-01-2017 at 04:45 PM.. |
01-01-2017, 04:15 PM | #31 | |
2925
Rep 1,303
It's great of you want to do the work yourself or a local exhaust/mechanic shop will charge you more than a couple hundred bucks to weld in/custom fit a new straight pipe in. I know there's a shop near me that will do a full straightpipe with new tips starting at the downpipe for $300. Don't see why an exhaust shop wouldn't charge less just for just a midpipe. |
AlexM240i103.00 |
01-01-2017, 04:38 PM | #32 | |
103
Rep 303
I think this is a very good choice to improve sound and preserve the stock downpipe. So with this setup i won't get any CEL with the MPE ??? |
01-01-2017, 06:37 PM | #34 |
2925
Rep 1,303
I will mention if you have an exhaust shop make you a midpipe, make sure they make a bracket at the front for support. This midpipe you can see the bracket at the front end of the pipe. It provides support so the weight of the exhaust isn't on the back hangers and the downpipe support brackets. Also provides regidity in the exhaust in case you get rear ended. Without it, it could break the exhaust manifold and turbo housing from rear impact on the exhaust tips.
AlexM240i103.00 |
01-05-2017, 03:59 AM | #35 |
1788
Rep 4,529
Some YT clips - this time M140i with stock DP and rear muffler but with BCS midpipe installed....
To my ears, this sounds superb - probably add their BCS sport cat DP and JB4 - LOL quick and sweet sounding w/o breaking the bank....happy dayz BP
AlexM240i103.00 |
02-06-2017, 09:46 PM | #36 |
175
Rep 247
Based on those videos, it seems like a midpipe deleting both resonators increases the sound quite a bit more than deleting just the rear resonator (like OP did). Anyone else deleted both? I'm debating deleting both resonators or doing a muffler delete.
12-31-2021, 06:10 PM | #37 |
Rep 9
I would like to chime in on this post to offer my experience with dual resonator delete on the M240i. I can echo the general consensus from others on this - 10-15% louder inside the car, very close to stock sound levels in Comfort mode, Sport mode and up there are many enjoyable pops and crackles accompanied by a more pronounced exhaust tone. No drone whatsoever, I am extremely picky with tone and volume as this is my daily driven vehicle.
