Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 2E68 knock sensor 1 and low boost 3100 codes
      06-30-2018, 02:12 PM   #23
Bimmer_Engineer
Bimmer_Engineer's Avatar
1044
Drives: 2007 335i
For me this started with an “engine malfunction - reduced power” warning. Which went away after I turned the car off and turned it back on. I read the codes later that afternoon and plugged the flap in and I’m clear since then. I did a couple of WOT pulls last night to try and test it out...
      06-30-2018, 06:50 PM   #24
Julian2485
110
Drives: Black lci e90 335 xdrive
One day mine will keep going into limp mode then another day it won't. So i finally changed the sensor was good for 3 day's then back to limp mode every time i drive
      07-06-2018, 10:48 PM   #25
Bimmer_Engineer
1044
Drives: 2007 335i
Any updates on this? I finally put mine back together after installing a new intercooler and after about 5 minutes it threw the knock sensor and boost codes again...
      07-06-2018, 10:52 PM   #26
Julian2485
110
No idea bro i heard of one or two guys getting a dme update and it helped one but not the other guy though smh
      07-06-2018, 11:01 PM   #27
Bimmer_Engineer
1044
Drives: 2007 335i
Are you still getting codes?
      07-06-2018, 11:03 PM   #28
Julian2485
110
Yes i am and my clutch is slipping real bad. I'm fbo stock turbos with motiv twin disk clutch. Hadnt had clutch for 2 years yet
      07-12-2018, 09:14 AM   #29
Bimmer_Engineer
1044
Drives: 2007 335i
Just to close this out for now...I cleaned the VANOS and the codes are clear...will update again if they come back...
      07-12-2018, 11:26 AM   #30
Julian2485
110
Yes please keep us posted
      07-16-2018, 06:23 PM   #31
Julian2485
110
What's the status
      07-16-2018, 07:37 PM   #32
Bimmer_Engineer
1044
Drives: 2007 335i
Still good here...it’s going to the dealer tomorrow for a few days to fix the body damage they did during the blower motor recall...
      07-17-2018, 02:10 AM   #33
Julian2485
110
Ill try cleaning my vanos solenoids like you did then
      07-22-2018, 05:22 PM   #34
kenni243
kenni243's Avatar
8
Drives: 335I Sedan - Black/Black
Any update guys? I’m getting the same codes Randomly around 2-3k RPM Engine malfuntion light come on. Scan for codes and got the following.
2AAF
2E69
3100
What I did so far...Cleaned Vanos, replaced plugs, replaced LPFP sensor, All vaccume lines, Walnut blast.
      07-22-2018, 07:11 PM   #35
Bimmer_Engineer
1044
Drives: 2007 335i
My car has been at the dealer for a week rechecking the blower motor recall and fixing the body damage they caused the last time it was there but as of last week I’d gone about 500 miles with no codes.
      07-22-2018, 08:35 PM   #36
Julian2485
110
2AAF
2E69
3100
Still struggling for a fix too change sensor and still getting code and a few other people having this same issue. I wonder if the wiring going to the dme could be messed up
      07-23-2018, 08:30 AM   #37
feuer
feuer's Avatar
Drives: wife crazy!
There is a fix for blower motor?
      07-23-2018, 09:00 AM   #38
Julian2485
110
Yea a recall for it they change the wire for it
feuer4277.00
      08-01-2018, 04:54 PM   #39
///Motivated
49
Drives: 335i, i3
Hello all. Please update when you can. I'm having the same problem. I have found many reference to the problem in various threads but not that contain the definitive fix.
      08-01-2018, 07:39 PM   #40
Bimmer_Engineer
1044
Drives: 2007 335i
I cleaned my vanos and I’ve been good for almost a month and about 500 miles...
      08-20-2018, 10:01 AM   #41
qubansailor
qubansailor's Avatar
Drives: 2007 335i
I have the same issue here. Replaced knock sensor and cleared codes. Ran good for a few days then it came back. Dealer found TSB which requires DME update. Performed all updates then a week later, knock sensor code returned. I'm lost at this point.
Codes 2E68 and 3100
Anyone find a solution?
(SOLD) E92 335i
Engine: RB//SPEC 2+ SMFW//PTF tune//AA FMIC//AP DP//BMS DCI//BMS CDV Mod//AA BOV//AE Exhaust//
Body: MTEC body w/ M3 side skirts/M3 style CF hood/LCI tails/CSL trunk lid/OSS AE/M3 F/R control arms/Stoptech Cross drilled rotors & steel braided brake lines
      08-20-2018, 12:02 PM   #42
Bimmer_Engineer
1044
Drives: 2007 335i
I’m stil good after a vanos cleaning...been about 1.5 months and 1k miles...
      08-20-2018, 04:30 PM   #43
Julian2485
110
Codes 2E68 and 3100
Had a friend that changed literally everything and did dme update no luck.
      09-07-2018, 12:50 PM   #44
Chrisred
Chrisred's Avatar
63
Drives: BMW 335xi coupe
I still get these codes once a month. Then just goes away. Changed sensors about 2yrs ago. Maybe JB4 software related....
JB4 Trebila tuned cp-e IC AMS exhaust BMS DCI AR DP's METH RB TURBO
19" VMR VB3 Stoptech BBK TC KLINE VORSHLAG SPEC STG 3 OSS design
