05-13-2019, 08:07 AM | #23 |
60
Rep 195
11-23-2022, 08:05 AM | #24 |
Rep 4
01-20-2024, 11:50 PM | #26 |
541
Rep 717
My M is a track car, all the AC components are removed amd the runs at all times. It is kind of annoying…wonder if this can be coded to bypass the AC and run as temp rises.
02-11-2024, 12:38 PM | #27 |
591
Rep 469
I’ve been trying to figure out why my fan has been running non stop after I deleted my AC. Did you find a solution to this? The one thing I noticed is that the fan only runs when the HVAC is turned on, in my case 84 degrees on lowest fan speed for coolant bleeding.
02-13-2024, 02:28 PM | #28 | |
541
Rep 717
Have not found a solution, deleting the AC caused this, mine pretty much runs at all times. Have thought about replacing the fan, factory fan is very heavy.
2015 M3 - GT4 replica Ongoing build thread https://f80.bimmerpost.com/forums/sh....php?t=1802471 For Pics / Video's visit Instagram https://www.instagram.com/ninekrpm1/ |
02-13-2024, 02:33 PM | #29 |
591
Rep 469
I did find the cause. The fan is running because it thinks the AC pressure is high. I'm sure there's a way to trick the system by running .5V to the signal pin.
02-13-2024, 02:55 PM | #30 | |
541
Rep 717
Very nice, totally makes sense…wonder if this can be coded.
02-13-2024, 04:18 PM | #31 |
591
Rep 469
Problem solved. For some reason I thought that pressure reading was coming from the compressor but it is from a screw in pressure sensor on one of the lines I removed. I pulled that sensor out and plugged it back into the car and everything works fine now. No fan spinning and I am able to bleed the charge coolant system again. I’m not sure what else changes with the sensor missing but I would recommend doing what I did.
02-13-2024, 04:40 PM | #32 | |
541
Rep 717
OMG! You rock… Which lines? Can you share a pic of the line / screw? And what do you mean, bleed the charge cooling system?
02-13-2024, 04:53 PM | #33 |
591
Rep 469
Ignition on, parking brake set, headlights on, heat on max hot with fan at lowest speed, press throttle for 6-8 seconds and the car starts a self bleed mode for the low temp side. Set a timer and the car doesn’t do anything for 6 minutes then the pump cycles on and off. Works good.
02-13-2024, 05:14 PM | #35 |
541
Rep 717
Well…I don’t have any of the AC equipment/compressor/blower/etc. or the control panel.
Not going to work me
02-13-2024, 10:45 PM | #37 |
541
Rep 717
Let me make sure the wiring is still there
02-14-2024, 03:36 PM | #39 |
541
Rep 717
In a similar vein, do you know or how would I determine what triggers the charge air radiator water pump?
Is it a temp sensor, if so, what’s the temp? Is it on at all times? If so, how do I confirm? Does it have any correlation / connection to the AC equipment? I ask, as I sometimes feel that the pump is not running. I am trying to figure out its operations and what triggers it.
02-14-2024, 04:03 PM | #40 | |
591
Rep 469
The following values are used for the activation: Ambient temperature Difference between charge air temperature and ambient temperature The coolant pump receives the setpoint value specification via local interconnect network bus from the engine control. The following pump values are reported back: Current engine speed Power consumption Voltage Temperature of evaluation electronics Fault status Characteristic curve and setpoint values The coolant pump works in the engine speed range of 24 to 6000 rpm. The permissible coolant temperature is between -40 °C and 128 °C. |
02-14-2024, 08:34 PM | #41 | |
541
Rep 717
very insightful, so basically...it will never run when the car is just running/on standing still regarding the engine fan, I am tempted to replace it with a spal or similar with a temp sensor/switch. the oem fan is over 30 #'s...so reducing that weight is a motivation
