Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      11-12-2015, 03:35 PM   #23
Stryder
54
Drives: Rocketship
Originally Posted by aboulfad View Post
hi, check the diff between your file and mine, not sure how critical "construction stage" is, but yours is set to werte "06", unknown ? for fun, try setting that to my value werte 03 ?
and you could alway VO code the ASD ECU to bring back to stock if there was some coding/firmware update corruption, i think but unsure !
Hmmm, is it actually possible to code the entire module back to original factory spec? I was not aware of such an option. Would you have a link to a tutorial?
Current: '16 F80 AW/SO 6MT, '16 BMW R Nine T
Past: '13 W204 C63 MCT, '12 MKII TT-RS 6MT, '11 E92 335is 6MT, '06 MKV GTI 6MT
      11-12-2015, 03:37 PM   #24
Stryder
54
Drives: Rocketship
Just for the record, I coded mine off since I got my car just trying to help here. Stryder should be equipped by now with diagnostic software and maybe he may discover something or not...
On a lighter note, what are the chances that the engineers got sick and tired of hearing about people complaining about ASD and decided to just fuck it and disable it all with the software update?
      11-12-2015, 03:37 PM   #25
Bluex
Useful Idiot
Bluex's Avatar
Drives: My wife and kids insane.
2015 BMW F80 M3  [10.00]
Wouldn't that just be VO coding the entire module? (especially if you made backups of all your original CAFD files, right?)
2015 M3 Sakhir Orange ED Pickup 5/13/15
My European Delivery Thread
      11-12-2015, 03:39 PM   #26
Stryder
54
Drives: Rocketship
open esys -> connect -> read VO -> activate FA -> read ECU -> select ASD -> right click -> code ?
won't that just basically recode whatever it was the car was currently already running?
      11-12-2015, 03:40 PM   #27
aboulfad
aboulfad's Avatar
1596
Drives: 2015 M4 MG/SO
2015 BMW M4  [10.00]
Very easy, Shawn's instructions:
To VO Code:
Connect => Read FA => Activate FA => Read VCM => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE
But don't VO code anything else without knowing the consequences... I've read some bad stories where people VO coded I think the DME or some other important ECU... I have VO coded the ASD ECU only to date.
      11-12-2015, 03:41 PM   #28
Stryder
54
Drives: Rocketship
I also did a quick run of the diagnostic software before heading to the office. Both ASD and REM had fault codes.
What does REM consist of? Rear Electronics Module right? Would it be the amp and the ASD module? Because the ASD *does* depend on the amp to function.
nevermind answered myself. the REM controls a bunch of things including rear camera.
      11-12-2015, 03:48 PM   #29
aboulfad
aboulfad's Avatar
1596
2015 BMW M4  [10.00]
That's the procedure, but not entirely sure if this is the procedure to VO back to original... From a post that Shawn made:
" You can change your VO, VO Code, and change the VO back to original and VO Code it again."
You could maybe ask him nicely by posting in the coding mega thread? Or ask the procedure to reflash an ECU like ASD if it's possible, then that step would definitely confirm wether there was a firmware corruption during the update or that your ASD is really fried or like you said lightly, BMW engineers got fed up with complaints and disabled it
      11-12-2015, 03:48 PM   #30
Bluex
Useful Idiot
Bluex's Avatar
Isn't that just fdl coding? When you do Read FA(VO)->Activate FA(VO)->Read ECU>Right-Click ASD -> Code I thought that is VO coding and resetting the module back to factory defaults.
dmnc02 would have the answer for this, but I know whenever the LED guys got stuck and needed to reset a module, that's how we did it. Just VO (not fdl) code and it goes back to factory default.
      11-12-2015, 03:50 PM   #31
Stryder
54
Drives: Rocketship
To VO Code:
Alrighty. Worth a try, given that the ASD is not working anyways. Experimentation!
      11-12-2015, 03:52 PM   #32
aboulfad
aboulfad's Avatar
1596
2015 BMW M4  [10.00]
What was the ASD fault? Similar to what I posted above? And where your ASD settings stock or altered by you or some gremlins?
      11-12-2015, 03:54 PM   #33
Stryder
54
Drives: Rocketship
Our only difference is in read SVT vs. read ECU. I thought the two operations are basically the same?
We should start a university to train F80post members to become full-on BMW master techs.
      11-12-2015, 03:54 PM   #34
Bluex
Useful Idiot
Bluex's Avatar
That's the DME module and you can NEVER code this while the engine is running. It will just blow it up. It's the only one you have to worry about.
      11-12-2015, 03:56 PM   #35
Bluex
Useful Idiot
Bluex's Avatar
Yes, both are the same and that's why I edited my post to say ECU as most people know it as this way....but SVT works as well.
lol...Bimmerpost U
      11-12-2015, 03:56 PM   #36
aboulfad
aboulfad's Avatar
1596
2015 BMW M4  [10.00]
I think you are right but wasn't sure anymore. I also remembered that I may have VO coded the DSC ECU to quickly undo the EuroMDM settings. And our friend dmnc02 seems to be incognito
      11-12-2015, 03:56 PM   #37
Stryder
54
Drives: Rocketship
There were two codes (do fault codes from multiple modules get displayed at once? Because that would explain why there was 2, one for ASD, one for REM)
One of the codes was exactly the one you posted before, I'm pretty sure that's just from me messing around with the model range.
The other code I should have jotted down, but I didn't. I'll post it later.
      11-12-2015, 03:57 PM   #38
Stryder
54
Drives: Rocketship
Got it.
Note to self: don't blow up the engine.
      11-12-2015, 04:00 PM   #39
Bluex
Useful Idiot
Bluex's Avatar
Got it.
Lol...technically speaking the engine itself won't blow up (don't want anyone to take me literally)....just will corrupt your CAFD. Which can be corrected if you have good backups of all your CAFD's from when you first started coding.
Shawn has saved more than a few people who have unfortunately made this mistake
      11-12-2015, 04:02 PM   #40
Stryder
54
Drives: Rocketship
Originally Posted by Nachbar View Post
I tried werte 03 and 06 today. No difference. Mine was 03 - and I got the same problem as you guys, since they updated the connected drive module.
I still remember seeing your LCI when you first got it!
It's good to know that I'm not the only one facing this issue, *especially* given that you are in EU.
      11-12-2015, 04:07 PM   #41
aboulfad
aboulfad's Avatar
1596
2015 BMW M4  [10.00]
issue for some, blessing for others
      11-12-2015, 04:11 PM   #42
Stryder
54
Drives: Rocketship
Hahaha I know right? Some will get the update and think "Wow, my car feels so much better!", and then others like me being like "Hey WTF! Gimme back!"
Can't please everyone.
      11-12-2015, 04:14 PM   #43
Nachbar
Nachbar's Avatar
Switzerland
8028
Drives: i8
I'm going to sleep and hope you guys fix it in the meantime.
      11-12-2015, 04:20 PM   #44
Stryder
54
Drives: Rocketship
Next steps:
  1. Save fault codes. Clear them.
  2. Drive around. Cycle car. Reconnect and see if there's any new fault codes being thrown.
  3. If no, VO code ASD.
  4. Drive around and check for codes again.
  5. If still no faults, and still no functioning ASD, then *maybe* it's intentional given that there's no TSB about this? It does mean that I myself won't be able to do much of anything beyond that point, and it's better to just wait for BMW to figure their software out.
f80post
