06-02-2009, 12:23 AM | #23 |
260
Rep 5,012
Apparently true. My tint guy told me this afternoon he hasn't had any problems with E92s, but he recommended 3M ($125) rather than sun tek ($95), which I have on my other cars. It's more scratch resistant, so might be a good idea to pay extra for the piece of mind. Take care.
06-02-2009, 01:20 AM | #24 |
71
Rep 733
I disagree, I've owned two 335i's and now the M3. All of them E92 and they've all made scratch marks on the window. Neither of the 335i's had the tint permanently scratch due to good tint, however the scratch marks are annoying. I've also ordered the moleskin stuff.
06-02-2009, 03:02 AM | #25 |
102
Rep 1,035
I'm not sure that it's real scratching because I seem to be able to wipe it off. It's some kind of residue being left on the glass IMO. Still, it's annoying as heck...
06-02-2009, 06:15 AM | #26 |
Just call me J.J. McClure
156
Rep 2,834
Sooo, if what I'm reading is correct, then us e92 guys don't have this issue?
MODS: Meisterschaft GT Racing Exhaust / BMC Air Filter / UUC SSK & DSSR (Modded)/ RPI Scoops / Passport SRX Hardwired / Custom Wrap 3M Clearbra / 20% Tint / 50% Windshield Tint / Key Hole Delete / Matted Out Accessories / VRS Type II Diffuser / Smoked Reflectors / Euphoria 6K LED Interior Lights / Rear Fog Light Mod / 6000K HID's / 6500K LUX H8 Angel Eyes / RDash License Plate LED Kit / LED Xenon Reverse Lights
"M3 drivers have no friends" |
06-02-2009, 08:02 AM | #28 | |
Rep 115
06-02-2009, 03:40 PM | #29 |
102
Rep 1,035
What you are reading is correct but the way you are reading is incorrect. e92s do have this issue but maybe to a lesser extent.
06-02-2009, 05:26 PM | #30 |
8
Rep 426
Drives: '09 E90 M-DCT M3
I specifically asked my F1 Pinnacle dealer about this today before my install. He assured me that the Pinnacle (allegedly scratch resistant) will not have a problem given the style of gaskets on the E90. I guess if this problem shows up he'll get to fix it.
AiB LEDs///MS Filter///Hardwired V1///VentureShield///F1 Pinnacle 35%///IND Reflectors///BMW Performance Grills
06-02-2009, 05:49 PM | #31 |
27
Rep 549
I had problems with the Huper ceramic scratching on my e90 m3. My tinter (a really small company) was really nervous about installing felt on my lower seals. He was nervous about pulling the door panels so I did it. I got the instrutions to pull off the panels from somewhere on this site. While he re-tinted the scratched windows, I pulled the panels and put felt strips on the lower seals. No problems since.
06-02-2009, 09:13 PM | #32 |
Two Wheels or Four?
95
Rep 655
I'm not convinced it's the seals that are trapping dirt and causing the scratching. I speculate that it may be something inside the window, like the guides for the window regulators...
Current: '18 AW Performance Edition m240i Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci |
06-02-2009, 09:15 PM | #33 |
46
Rep 891
Not true. I have F1 Pinnacle and have scratching. Taking it back to the tint shop to have them look at it.
06-04-2009, 04:49 AM | #34 |
27
Rep 549
Ok then ,why have my windows been perfect ever since applying felt to the seals?
06-04-2009, 11:57 AM | #35 |
19
Rep 286
It's the hard plastic weather seals that cause the tint to streak. If just one piece of sand gets in between the weather strip and the tint it will start to make a grove in the tint.
Tint Protector has a forum members special $5 off their kit. http://www.tintprotector.com/forummembers/ |
06-04-2009, 05:56 PM | #36 |
15
Rep 474
just got my windows tinted. my installer told me that the felt can eventually come off and that its best to just cut the portion of the window gasket that does not have felt on it. so we pulled out the gasket and showed it to me and cut the lower rubber/plastic gasket. we will see if this works. anyone else have this done? any problems?
06-04-2009, 10:16 PM | #37 |
19
Rep 286
I have two friends who did just that. They cut the weather strip out and after a month one of them noticed a weird smell coming from the door panel. It turned out water was getting in from the rain and there was mold growing inside his door panel. Yuuuuck!
I noticed wind noise was louder at speed. Seemed like wind was getting in since the seal wasn't tight anymore. I would rather spend $30 for the moleskin above then cut the weather strip seals out of my 50k car. JMHO |
06-06-2009, 11:46 AM | #38 | |
15
Rep 474
you are right. DO NOT CUT THE GASKET! i have increased wind noise and its pissing me off. i have already went and ordered new seals to replace them which is costing around $120 for all four doors. luckily the shop that did my tint is paying for the seals and putting them in for me. stand up guy who owns the shop. he said hes done this on other bmw's without any problems though. now im debating weather to get the tint protector stuff and put it on the new seals or just put the new seals in a see what happens. |
06-06-2009, 08:49 PM | #39 |
102
Rep 1,035
This afternoon I decided to document the moleskin installation on my E92 M3. The instructions that came with the kit were pretty good. This is what you get...
I started off with my GF taking pictures of me removing the door panel. After I removed the doorpanel, I removed the strip. It wasn't easy because of this rubber seal that runs along the top side of the door. You kinda have to figure this part out. Basically, the rubber part on the side pops out and you lift on that side of strip to get it out of the door. The outer strip will have to come up part of the way to make room for this strip to come out. Here's a picture... The instructions indicate that I would find a hard plastic piece on the strip. You're supposed to sand it down and then stick the moleskin on it. Well, guess what? There is no hard plastic part, it's all soft felt lined and nowhere to stick the moleskin. So all of this was a waste of time. The moleskin kit I did order specifically for an E92. Turns out at least that my 2008 M3 doesn't need it. Here's a picture of the felt lined strip... I'm still not convinced that my tint is being scratched but I do know that it's leaving what looks like scratch marks on the tint but I can wipe them off. It's leaving some kind of a residue. Anyhow, hope that helps. Anyone in SoCal area need a moleskin kit for an E92???
06-06-2009, 10:13 PM | #40 |
260
Rep 5,012
Somebody previously mentioned that only E90s have hard rubber. Seems to be true. It doesn't get any better than your molding, so at least for '08 owners, we can put that issue to rest. However, if you had grease/rubber marks, something is touching the window inside the door. Now that you have the panels off, can you take a look and let us know what you found? Thanks for the heads up man.
06-06-2009, 11:28 PM | #41 | |
102
Rep 1,035
Whatever it is in there putting whatever residue it is on the tint, I'm not going to mess with it. As long as it isn't scratching my tint and it isn't a simple fix like the moleskin, I'm more than happy to clean the marks off when they appear. Funny thing was today I had the windows down and no marks appeared. I don't think it's a grease either because it doesn't smear around like I would expect it to.
06-09-2009, 04:44 PM | #42 |
46
Rep 891
Ok, So I visited my tint shop and they pulled the strips. On the E90s or maybe I will say my 09 E90 M3, the strip has two parts. A top and bottom strip. The top is felt covered the bottom is hard plastic/harder rubber. The hard plastic/rubber is the problem. Does anyone has access to the BMW ETK and can look up wether the weather strip has changed and maybe a retrofit can be done from an E46 or something that has felt on both parts.
06-09-2009, 05:27 PM | #43 |
7
Rep 162
I recently went to a Tint shop and was told this for the first time as well. I thought it was all BS until I read this thread.
I hear that it is pretty random on whether the molding on the inside is rubber or vinyl. Lady at the tint shop told me she did an E90 and 2 doors had rubber and 2 doors had vinyl. WTF??....I didn't believe her at all. Then she said, to "prepare" the moldings was an extra $50 which she was going to throw in for free. But who knows...."prepare" could mean cutting the molding which doesn't seem like the right way to go. My appt to get my tint on my E92 is Thurs at another shop. I'll see if I can get a look at what kind of molding it has. When I mentioned it to the owner of the shop, he said they haven't seen any scratches due to this. Guess we'll see.
2009 E92 M3 6MT Jet Black Mods: MS Air Filter | MS spacers (bulldog stance) | BMW Performance Steering Wheel | Matte Black Kidney Grills and Gills | BMW Performance Pedals | EAS Aftermarket Alarm System| AiB Headlights | Tint |
06-09-2009, 08:47 PM | #44 |
46
Rep 891
I ordered the Tint protector moleskin tonight. I am going to see what can be done to get some strips from BMW that have felt on both parts. If not, then I am going to go with the felt to see if that solves the problem.
