08-03-2014, 06:14 PM | #23 | |
Rep 25
On the other hand, you get the benefit of being able to re-enable HBA... which I'll take any day for having to offset the camera! =) |
08-04-2014, 12:21 AM | #24 | |
845
Rep 2,386
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
08-06-2014, 04:08 PM | #25 | |
Rep 25
Quite pleased with how it turned out and thanks again to the OP for posting the detailed info on the wiring which made this install a breeze! Here's the view from the driver's seat: Offset to the right due to the HBA camera assembly blocking the mounting area that was chosen by the OP: View from outside: |
10-22-2014, 12:40 PM | #26 |
Dejan
1755
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
Great write up thanks for sharing and putting up all the links.
FBO-PS1 and stuff
12-11-2014, 12:10 PM | #27 |
38
Rep 348
Hey great write up and pics Op and others!
I got the parts to install this yesterday. I just wanted to get some additional insights into removing the plastic cover. Are there just some clasps of some sort connecting the 2 halves? ie, when I stick a credit card in the middle (from the bottom of the assembly), I'll figure it out? Any tips here would be appreciated! Thanks, Praz
2018 Audi A4 6mt + Sport Plus (retired)
2015 228i M Sport 6mt + Track Handling Package (retired) 2012 328i Sport 6mt (retired) |
12-11-2014, 03:13 PM | #28 | |
845
Rep 2,386
Follow my builds:
12-11-2014, 04:04 PM | #29 |
38
Rep 348
Okay thanks! Just wanted to make sure before I started messing with it
12-11-2014, 07:49 PM | #30 |
127
Rep 765
Yes, the clips are not very thick or snap together, they just sort of slide into position. It pops apart very easily.
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
12-11-2014, 09:46 PM | #31 |
38
Rep 348
...And done! Thanks again abirmaher for the DIY instructions. Managed to install the Blend Mount without too much trouble
12-11-2014, 09:46 PM | #32 |
845
Rep 2,386
Perfect.
Follow my builds:
12-11-2014, 10:17 PM | #33 |
38
Rep 348
You're right - the left one popped out first and then the right one came out with a little jiggling.
01-26-2015, 10:13 PM | #35 |
55
Rep 162
Quick stupid question - On the blendmount website, there are a lot of them under M235, one is actually on a waiting list! Which is the correct one for a US Spec 2015 M235? also On amazon, I see a Blendmount too, is that the right one?
02-04-2015, 09:39 PM | #36 |
55
Rep 162
Thank you!!!
Just installed everything.... Passport 9500ix hanging from my mirror like the car came with it!!!!
Absolutely amazing, I used to get really annoyed by the up and down motion of the detector on suction cups in earlier cars but this is phenomenally stable! Thank you so much for the DIY! Really dont know how I would have figured out (without burning something up first) where to plug in the Mirrortap. |
02-04-2015, 10:45 PM | #37 | |
845
Rep 2,386
Follow my builds:
03-29-2015, 07:01 PM | #38 |
348
Rep 530
I just installed the MirrorTap in my M235i Convertible. It was as easy as described with one exception. I pulled the socket up where I could more easily unplug the harness, and it took quiet a bit of fiddling to line the socket up to nest back where it came from. If I did it again*, I might not even unplug the connector.
I haven't done a blend mount, because I'm afraid my fairly chunky V1 will block my view of cross traffic at intersections. (I already find the rear view mirror in most imported cars to sit too low for my liking.) [*] ... which I plan to, for my wife's 2012 328i. Should I expect it to be wired the same as the 2er? |
03-29-2015, 07:02 PM | #39 | |
845
Rep 2,386
Follow my builds:
05-20-2015, 10:16 PM | #41 | |
845
Rep 2,386
Follow my builds:
08-01-2015, 09:03 PM | #43 |
42
Rep 146
I'm having an issue wi my install. First, I didn't get that breaded looking wire. I just got the rj11 wire with an inline fuse. Hooked everything up to my V1 and it was working. Then hooked up my concealed display via a splitter and it worked for a bit then lost power. Probably blew the fuse but
Won't know til I can check for sure (it got dark out). Has anybody come across this issue? Think I can use a higher amp fuse to get all the accessories working? Any thoughts? |
