09-23-2023, 06:29 PM | #23 |
497
Rep 459
Sorry to fill up this thread with a bit of my anecdotes, but on a whim I jacked up the right side my car, added 500-700mL of fluid, and 5 miles later, no issues.
Feeling like a bit of an idiot, because I've filled these transmissions going on 6-7 times now, no issues. Still a bit of [pump?] whine in reverse (usually a straight cut gear and not helical so it could be that), but otherwise it seems fine. Not too mad, because the replacement transmission I got is flawless. Barely leaking, 2/2013 production date, so likely right at the end of the run. I was not able to get a mileage reading on it but judging from the interior of the car it was pulled from, very likely it's low mileage. It's barely leaking from the side gasket and sleeve seal. Like Deans said, with a fresh check ball, it's much smoother coming from a stop at a cold start, no more clutch dumping or shock to the drivetrain. My checkball couldn't even form a proper seal from the wear. |
DrFerry6734.50 |
09-23-2023, 06:43 PM | #24 | |
1629
Rep 1,138
Drives: 2009 E92 M3 Dakar Yellow II
02-11-2024, 12:06 PM | #25 |
Rep 14
I'm sorry to hijack this thread but I figure if anyone knows the answer to my question it's the people here: I'm getting a weird intermittent sucking sound from the frontish area of my DCT.
Bought the car used and the DCT pan was pretty wet so I knew it was due for a service ASAP. Only drained about 4L of fluid from the pan. Did both filters, new pan, and gasket. Took ~6.5L of fluid after oil balancing with ISTA. Basically immediately it started making a weird intermittent sucking noise. It sounds like a pump ramping up and down every 4ish seconds. Google led me to this thread and I thought I had my smoking gun. Dropped the pan again and sure enough, the ball in pump had flipped 180 deg. New one in, oil balance again, and the noise persists. Here is a video of the noise. In person it sounds more like fluid sucking past a flapping seal or something rather than metal on metal like it kinda does in the video. I've searched around but couldn't find anyone with an intermittent noise like this. Thank you! |
02-12-2024, 08:44 AM | #26 |
155
Rep 561
Although I don't have the answer, I believe it is missing some fluid; mine took 9 liters at first and another one a few days later. I think 6.5 - 7.0 liters is not enough. Could it be that the pump is sucking air? I would try to add more fluid.
DrFerry6734.50 |
02-14-2024, 10:50 AM | #29 |
138
Rep 193
A bit off topic but anyone try below DCT oil pan? Seems like a carbon copy of the OEM one but made in aluminum and is a bit cheaper, $156 vs $183 for OE.
https://www.fcpeuro.com/products/bmw...ts-28108070791 Ty for the PSA deansbimmer I'm at 40k and will also be changing the suction pump. Will post pics for science. |
Assimilator1597.00 |
02-14-2024, 12:31 PM | #30 |
597
Rep 1,042
Drives: BMW M3 e92 08 & 330d e90 10
That link isn't working for me, anyone else?
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. |
02-17-2024, 08:50 PM | #33 |
597
Rep 1,042
02-20-2024, 08:00 AM | #34 |
Rep 25
Dear All, Just get this thread link from another topic, I'm searching for the reason of this sound what you can hear on the video, the car is an M2 N55 with DCT. Many of the M2's with dct having this sound, but also there is agroup where there is no sound, so it's confusing :/ The issue: The sound comes ONLY in neutral, and loud only after cold start, But its coming exactly 7 times in each minutes after 50 sec silence, 7 noise 50 sec silent and so on, if i change to gear 1 or R, the sounds stops immediatelly, and only comes again if i take it back to N, so its kind like expected/programmed. I have NO leaking on my dct, and there was no leaking before as well but ofc i don't know the oil level currently! Question 1: Cold it be the jet pump? Question 1: Is this unit electrical? Cause i check all the upper uploaded photos but i can't see any wiring/connection, but the name is still a pump, and pumps mostly electircal units i think! Thanks for your help / comments Last edited by Tibi_M2; 02-20-2024 at 08:06 AM.. |
DrFerry6734.50 |
02-20-2024, 12:56 PM | #35 |
597
Rep 1,042
I have no idea for DCT boxes specifically, but plenty of oil pumps are mechanical.
e.g engine oil pumps.
02-20-2024, 01:42 PM | #36 |
1256
Rep 1,504
deansbimmer any references for shops in CA that can do this service as you’ve described? Maybe MRF?
2011.5 E90 M3 DCT ZCP Slicktop
02-20-2024, 03:22 PM | #37 | |
4489
Rep 7,141
02-20-2024, 03:40 PM | #38 | |
Field Marshal
6735
Rep 1,829
Drives: '08 E92 M3
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
02-20-2024, 06:20 PM | #40 |
Field Marshal
6735
Rep 1,829
Drives: '08 E92 M3
Okay. I sit corrected. But what 'drives' such a pump? A belt? A gear? A shaft? Nothing shown on the images. Thanks for keeping me straight.
02-20-2024, 06:25 PM | #42 |
Field Marshal
6735
Rep 1,829
Drives: '08 E92 M3
Interesting. I would never have guessed that. A vacuum 'pump'. No wonder the words "Sucking Jet Pump" are used to describe it. Thanks.
02-21-2024, 01:30 AM | #44 |
597
Rep 1,042
