12-28-2023, 07:05 PM | #23 | |
314
Rep 445
https://www.hkptuning.com/products/m...35i-1m-n54-n55 |
changster37.50 |
12-28-2023, 11:14 PM | #24 | |
Self Proclaimed Roundel Junkie
630
Rep 1,595
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy 2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i |
12-29-2023, 06:24 AM | #25 | |
314
Rep 445
12-29-2023, 02:07 PM | #26 |
630
Rep 1,595
Yeah, and seeing it with the bumper off, you quickly see that there's no real easy way to just relocate it. The M3 hoses aren't that easy to move around. There is a company that makes -AN adapters for the oil cooler lines so I can then run custom lines/hoses to any cooler I want. Eventually I'll go this route.
01-02-2024, 09:31 AM | #27 | |
505
Rep 650
https://www.m3post.com/forums/showpo...ostcount=23386 |
01-02-2024, 08:39 PM | #28 | |
630
Rep 1,595
https://www.rogueengineering.com/Rog...ngs_p_324.html
01-03-2024, 02:15 AM | #29 |
Rep 22
Slight tangent, but when using your Quick Jack do you use jack pad adaptors, or do the rubber lifting blocks spread the weight across evenly enough you don't need them?
01-03-2024, 07:57 AM | #30 | |
505
Rep 650
I ended up with a generic CSF core that I made a bracket for that seals off most of the flow in the lower opening, and then ducts down and out the bottom like the stock M3 air path. Works mint. |
01-03-2024, 11:26 AM | #31 | |
630
Rep 1,595
01-03-2024, 11:28 AM | #32 |
630
Rep 1,595
I use the square rubber blocks that came with the QJ setup, and then the 4 factory blocks that plug into the underside of the car. I don't use any sort of adapters. I figure two square blocks on top of each other is pretty stable. The QJ blocks are quite a bit larger than the factory jack pads, so they get complete contact. And being lifted evenly at all 4 corners, not sure how much more stable it can get. The QJ setup was honestly some of the best money I've ever spent...
