RSA Delete?
05-23-2018, 10:11 AM | #23 |
3975
Rep 7,215
actually I'm not sure you have a limp mode at all. There would be codes present. Typically you would get limp mode from this type of tune because the power class doesn't match, but that's the whole point of this file.
It's possible the PBX is messing something up, but it doesn't really do a whole lot anyway so I'm not sure about that. I thought maybe you might have a different chassis or possibly an N51 but looking at your car's data it's just a vanilla N52N. I would try disabling the PBX and resetting adaptations. Is it possible somebody edited your CAS to change the power class? that's the only reason I could think of for you to get a limp mode. |
05-23-2018, 11:11 AM | #24 | |
253
Rep 775
05-23-2018, 11:13 AM | #25 | |
253
Rep 775
05-23-2018, 11:18 AM | #27 |
998
Rep 2,287
Ya, My Z4 is still under warranty and I've been reluctant to install a tune knowing that I would need to remove it before going to the dealer. Long term, and looking at newer platforms, I think you need a CVN defeat as well.
05-23-2018, 11:25 AM | #28 |
3975
Rep 7,215
Do they really check that though? I have a hard time seeing that anyone does. Maybe at a CA emissions check place?
It's been around forever, and I've never heard of anyone getting "caught" with a bad CVN. anyway, I doubt they are calculating the checksum from scratch, they likely just read the value stored in the DME. The easiest way to defeat it would be to just move the location of the checksum, then leave the original "stock" value that matches the CVN. |
05-23-2018, 11:38 AM | #29 | |
253
Rep 775
I think some of the stricter emissions places check CVN, but Florida definitely isn't in that category. BMW doesn't seem to check for a tune either. |
05-23-2018, 12:10 PM | #31 |
253
Rep 775
Yeah but the routines are pretty messy, and our RSA delete is dependent on the program being mostly untouched. It really isn't that hard to force a CRC, especially when you're able to edit the initial value to your liking. I just have to wrap my head around the math a little bit.
05-23-2018, 01:14 PM | #32 |
3975
Rep 7,215
if we were to do that, I think it would be best to come up with an algorithm that automatically calculates the required initial value - assuming that's possible.
05-23-2018, 01:15 PM | #33 |
20
Rep 52
Okay I’m gonna put the pbx on map 0, and go into inpa and reset adaptations. I know the disas are good, the 3IM came off of my wife’s x3, and she got my old one.
05-23-2018, 03:43 PM | #34 |
20
Rep 52
05-23-2018, 03:57 PM | #35 |
3975
Rep 7,215
the PBX doesn't add any power, so I'm not sure how that's possible.
Are you sure there are no error codes? There are literally like 80 people running the same tune on the same car, so I think there's a problem somewhere else. |
05-23-2018, 03:59 PM | #36 |
20
Rep 52
That’s true, but the pbx adjusts the throttle response. I guess power wasn’t the right word but the car feels slower with it off. What do you suggest I do? Should I try to flash the file again?
05-23-2018, 04:24 PM | #37 |
3975
Rep 7,215
no, that won't change anything (if the flash fails it wouldn't start).
Have you reset adaptations (with the engine off)? Don't do this if you need to smog your car in the near future. But it might help. Also, you may have to clear codes and restart the car after resetting throttle adaptations. |
05-23-2018, 04:44 PM | #38 | |
20
Rep 52
08-01-2019, 11:14 PM | #41 |
Rep 15
DME/DDE - MSV80 2FA3 Codierung fehlt my bmw E90 2010. Did you solve this problem?
it does not work... 1. Load NCSExpert. 2. Load Profile and select Expertmode 3. F1 (VIN/ZCS/FA) 4. F3 (ZCS/FA f .ECU) 5. Choose E89 (for the E9X) 6. Select CAS 7. F6 (BACK) 8. F4 (Process ECU) 9. Select the Module I want to Revert back to Stock. 10. F2->Choose "SG_Codieren->ok 11. F3->to start coding the ecu with factory settings according to the vehicle VO. Last edited by enriqxxx; 08-01-2019 at 11:39 PM.. |
08-01-2019, 11:29 PM | #42 |
3975
Rep 7,215
2FA3 is not really a problem. You can either ignore it (because it does and means literally nothing), or you can default code the DME using NCS expert, which makes the (pointless) error code go away.
08-02-2019, 12:48 AM | #44 | |
Rep 15
I could already with this annoying error 2FA3. Last edited by enriqxxx; 08-06-2019 at 05:43 PM.. |
