11-13-2019, 06:42 PM | #23 |
288
Rep 386
The latest: The regional engineer recommended replacing all the lifters. They have removed the cams, but still need to diagnose if any other damage has been done to the internals. Hopefully there isn't any and we caught this before it became anything worse...
I'll post a final update once I have the car back.
'01 M Roadster, '24 BSM M2
stillplayswithcarss1595.00 |
11-16-2019, 04:04 PM | #26 |
434
Rep 533
11-18-2019, 05:11 AM | #27 |
1546
Rep 8,972
My first thought was a defective / sticky hydraulic valve clearance adjuster. Had a few of those in my time and they were always bad from cold then settled as they warmed.
It's definitely cam related as the sounds is too slow for crank at idle. (Cams run at half crank speed). The S55 adjusters are shared with most of the BMW range, very common cheap part https://www.realoem.com/bmw/enUS/par...&q=11337548690 Good luck, keep us informed |
LAGWAGN287.50 stillplayswithcarss1595.00 |
11-19-2019, 02:02 PM | #28 |
Rep 1
11-20-2019, 02:32 AM | #29 | |
1546
Rep 8,972
But it does share them with several Rolls Royce models.. https://www.realoem.com/bmw/enUS/par...&q=11338679835 |
11-24-2019, 01:22 PM | #30 |
288
Rep 386
Final update. doughboy Was spot on. Replacement of the alignment and decoupling elements resolving the ticking noise. I'm ultimately happy that the dealership went through all of the motions to make sure it was resolved (TSARA case opened). Sewell Grapevine BMW in Dallas did the repair, for those in the area. Really happy with their service and the knowledge of the service writer.
Getting back into the car after 3.5 weeks of an X4 was mind blowing. How these two cars come from the same company is hard to believe. Question to the group: How comfortable would you be taking a car back that has had the top-end dismantled and put back together? I take some comfort that all moving parts looked good, e.g. no scoring on the bearings, but am a little unnerved that the engine has seen this level of maintenance at < 9k miles.
11-24-2019, 06:43 PM | #31 | |
434
Rep 533
11-25-2019, 02:14 AM | #32 |
1546
Rep 8,972
I've not heard anything, and as the part in question is very common across the BMW range it would affect more than just the S55.
Just normal part failure rates I would think. |
11-25-2019, 04:52 AM | #33 | |
518
Rep 744
AX 1.1 --> AX GTI --> NA Roadster 1.8 --> E39 528i --> Xsara VTS --> Volvo 940 LPT --> Focus RS MK3 --> M2C + NA Miata 1.8
LAGWAGN287.50 |
11-27-2019, 12:05 PM | #34 | |
589
Rep 897
11-27-2019, 04:51 PM | #35 |
288
Rep 386
What's the best way to determine build date?
12-01-2019, 06:21 PM | #38 |
288
Rep 386
That's in the back, right!?
Production was 7-16-18.
12-02-2019, 05:43 AM | #40 |
4455
Rep 7,594
Drives: '19 M2C
I have a 7-31-2018 build and it's fine. Don't forget that the M2C build date is irrelevant since the S55 is used in the M3/M4. They didn't just start building these engines.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
12-02-2019, 10:22 AM | #41 | |
288
Rep 386
Here is a link to a similar issue with an S55 from an M4. I don't think this is necessarily a far flung issue that most owners need to be concerned about and it was relatively minor in what needed to be replaced. There was no damage or premature wear to internals as a result.
12-06-2019, 05:23 AM | #42 |
1546
Rep 8,972
3-4 weeks? I assume that's waiting for parts?
I wouldn't think it's value is diminished. For a start who will know except you? It's just a minor mechanical repair, I wouldn't be concerned at all as long as the oil is confirmed clear. Underneath all the modern electronics and auxiliary gubbins and plastic covers, IC engines are the same old lump of metal as they've been for years and suffer from the same mechanical probelms from time to time. |
12-07-2019, 05:13 PM | #43 | |
288
Rep 386
While the work to correct is fairly intensive, the repair itself is minor. I look at it as I got a free comprehensive inspection with new seals. |
12-16-2019, 03:42 PM | #44 | |
60
Rep 121
