The Basics of Tuning and Timing
02-24-2011, 07:33 AM | #23 |
40
Rep 462
why do you think its so easy to make 300 hp no matter where you are in the world because the the 335i automatically tunes to achieve this goal i pretty sure when you take a subie into the mountains it loses some power. and in the end its up to the user do want to control everything in the engine or do you want to let the ecu you some of the work i rather take full control when your running 7psi more then factory intended
02-24-2011, 07:33 AM | #24 | |
105
Rep 3,460
02-24-2011, 07:58 AM | #25 |
SOFLO CODING
199
Rep 3,587
Excellent write up. I give you props for handling this topic very maturely and professionally with out any sort of sarcastic/arrogant tones. Unfortunately, not many people are capable of this.
When you refer to degrees, is this the angle in which how far the piston is from peak stroke, or actual temperature of the cylinder? |
02-24-2011, 08:09 AM | #27 | |
21
Rep 551
Harry |
02-24-2011, 09:04 AM | #28 |
40
Rep 462
Air fuel and ignition control how can you tune with out a car taking care of all three and if im correct thats what some tunes are missing ignition control
dont flame just learning as much as possible on the platform |
02-24-2011, 09:28 AM | #29 |
5507
Rep 8,835
Great write up and easy to understand. If you don't then you got other issues
I see no bashing in his post. If posting facts about how 99% of tuning works is bashing then so be it.
02-24-2011, 09:40 AM | #30 | ||
56
Rep 219
Subaru's actually do have compensation tables for temperature, barometric pressure (helps with elevation), knock, ect. Technically, they have what is referred to a IAM (Ignition Advance Multiplier), which is a fairly simple algorithm that when knock is sensed at XX rpm under XX load, it lowers timing (initial value of 1, shows fractional/decimal value when unable to reach peak/base timing value), and as you go through cycles, it will slowly attempt to ramp timing timing back up to base initial value. Basically, it keeps track of historic knock at various load sites, and attempts to advance timing slowly... it's remarkably similar to the autotuning feature (except with timing only, vs. boost) this community is used to, except stock. It's kind of funny, years ago, Shiv found a way to "trick" their ECU's into raising the IAM value to its maximum in a matter of seconds haha: http://forums.nasioc.com/forums/showthread.php?t=302047 Either way, in certain aspects I would agree with you, this ECU/DME is faster, able to react more quickly to knock and fueling is fully closed loop (awesome!), but when it comes to timing, I respectfully disagree, as Subaru's & EVO's employ learning curves (again, similar to autotuning in regards to timing) that keep track of historic knock and calculate accordingly.
2008 Honda S2000 (weekend/former autoX) - 1996 Acura Integra GS-R (occasional autoX) - 2008 BMW 128i 6MT (track/time attack) - 2008 Nissan Xterra (winter beater)
02-24-2011, 09:48 AM | #31 | |
70
Rep 1,566
This maybe true. The difference is, JB relies entirely on "riding" the knock sensor and the stock DME to adjust for anything that gets thrown at it. Whereas, GIAC/Cobb, any other flash tuner, re-writes those ignition timing tables to take into account proactively, the additional boost/load demand, all tested on the dyno...to avoid relying on bouncing on the knock sensor and DME to "REACT". There is a huge difference between using the knock sensor as a fail-safe/last ditch security mechanism, and RIDING it all the time and relying on it to adjust timing. This is 101 FI tuning fundamentals. You need to control timing to avoid detonation at all costs...or engine goes boom....that simple. But I agree, it is more a tribute to how well BMW designed/developed the stock knock system and DME logic to save its ass over and over with some tunes....
2020 M340i: Dravit Grey Mettalic. Loaded.
02-24-2011, 09:49 AM | #32 |
56
Rep 219
Yeah, I'm a member of dozens of forums, even moderated a couple local Mazda boards for a while....even though I'm just trying to share my experiences without bias, I knew the flaming was coming haha! [puts_on_flame_suit]
02-24-2011, 09:51 AM | #33 |
188
Rep 5,417
excellent write-up! Thank you very much for sharing your experience and info. I always love to hear all sides of this conversation. Mad props for taking the bull by the horns!
02-24-2011, 09:51 AM | #34 | |
70
Rep 1,566
It should be a failsafe...not the ONLY WAY of controlling and relying on timing/knock/detonation. This is what people need to understand completely, RULE #1. It is fundamental and essential 101 FI tuning best practices by anyone who knows what they are doing.
02-24-2011, 10:14 AM | #35 |
Some say...
239
Rep 4,296
Drives: Fresh
This
I have exhaust and an intake... |
02-24-2011, 10:22 AM | #36 | |||
56
Rep 219
IMO, the knock sensor is meant to be a failsafe, and under the wrong circumstances it is a crucial tool in saving your motor. However, rather than relying on it as a means to altering timing, the base timing values should be set as a maximum, which should be under the knock threshold. Ultimately, the goal when tuning should be be set timing values (as well as AFR & boost of course) to a value that allows WOT operation without knock under most normal conditions. Quote:
^^^ Apparently you beat me to it +1 While you and I see to have different styles of communication, on a technical level, we seem to have a similar mindset. I've seen numerous OTS maps for multiple cars... I'm not a big fan, as they typically leave much to be desired. Hell, I'm not even a big fan of many supposedly conservative factory tunes (I've seen some pretty atrocious logs on stock cars of various makes over the years!! We're talking LTFT's around ~15%, AFR's deep into the 9:1 range under WOT, knock/timing correction all over, cars that won't hit peak targeted boost, you name it). Ultimately, these maps are made/tuned by someone else in another part of the country, and like humans, among cars there will always be variances. Manufacturers try to be overly conservative and make maps that will be safe in a variety of conditions, but there are so many variables from car to car that this is rarely optimum. I've seen cars with the same mods, running the same OTS maps, under the same conditions (elevation, fuel grade ect) make WOT pulls, and the logs/torque curves are vastly different. Personally, I would rather tune my own car, for my own conditions (fuel grade, elevation, variances specific to my vehicle, ect, preferably under harsh conditions..) to ensure that my car is knock free while pushing peak boost/timing/under full load. I'm a big fan of optimum performance, consistency and safety when at all possible That's just my $.02 though, YMMV.
02-24-2011, 10:42 AM | #37 | |
661
Rep 10,587
EXACTLY If your riding the knock sensors 24/7 this simply isnt possible. I had my car custom dyno tuned last summer (which didnt work at all thanks to a clogged cat that I only discovered a few weeks ago ). A few other car geeks were there and all were bummed that it was close to 110f in the shop since we wouldnt see huge #'s being thrown down. I on the other hand was happy with the heat, it meant that my custom tune would have the ability to be safe even in the worst conditions the car will ever see. I want a safe and reliable tune that is not tuned to max power at all times, if you run an engine at 99.9% all the time and let the knock sensors pull timing back everytime you floor it, you ARE causing undue stress on your engine. There is no arguing that fact.
02-24-2011, 10:47 AM | #38 | |
105
Rep 3,460
You and I def show the same understanding of how tuning should be applied. The difference that I have a low tolerance for ignorant spiteful members who know they are wrong but continue to post because they feel the need to justify their incorrect logic.
02-24-2011, 11:05 AM | #40 |
12
Rep 859
+1000
2007 335i SG Coupe
2009 128i AW |
02-24-2011, 11:28 AM | #41 |
84
Rep 949
It is really nice to see a few more individuals that are coming out and posting on e90 that actually understand tuning and even some who tune their own cars and help others tune as well.
Its funny because we all post the same facts and information and get opposed with illogical and uninformed opinions. Some of us do it nicely and others are just fed up with the ignorance that some people bring in. It just simply astonishes me that people can rationalize an arguement that relying on a safety feature because it is so advanced is sufficient compared to actually tuning the car and leaving that safety feature as just that - a safety feature - back up for those conditions out of your control where knock occurs. Different platforms require different tuning styles - STYLES. That means that each platform has different timing curves. Some heads flow better than others. Some cars can run leaner than others. That much is true (and more examples but you get the point). The one thing that every platform has in common is that safe engine tuning practices consist of tuning boost, afr, and timing and monitoring many parameters to ensure they are done properly, safely, and make power with the first characteristics in mind. Eliminating knock and monitoring EGTs, AFRs, Oil temps, etc. can really tell you alot. Monitoring for knock is crucial (and all of the above temps and values can tell you why you knocked). No tuner would let a car they are tuning leave with the customer that knocks, knocks a lot, or knocks occassionally. If they did they wouldn't get customers. It happens all the time. I can name multiple shops and tuners that went out of business because of poor timing maps and cars knocking more then once in a blue moon. |
02-24-2011, 11:37 AM | #42 |
105
Rep 3,460
I feel like the n54 is probably the worst platform to start understanding how tuning works. All the guys who preach correct tuning have experience with other platforms that were not as near forgiving. The slightest mistake with a decent power output and bam you are out 7k rebuilding the motor. My last car was a Nazi Fuck when it came to tuning. Many of the people posting on here have witnessed me tuning my car on a weekly basis. People blew motors with intakes while I lasted 40k and set various records and eventually put the biggest turbo on the car available at the time. Am I the norm? No because I am beyond belief anal when it comes to tunning. And quite frankly if Cobb wasn't releasing atr for this car. The tuning systems available for this platform currently are a joke...
02-24-2011, 11:44 AM | #43 | |
84
Rep 949
02-24-2011, 11:45 AM | #44 |
3442
Rep 79,211
As usual the fanbois are on defense like their said tune is being called out.
People confuse the knock sensor as being a tuning device, when in reality its the last resort to saving your motor. Even still it has its limitations and is not bullet proof in design. I'm curious how a thread would progress without a fanboi in it. Edit- If you read a few peoples post in this thread you will also notice that sleeping on the knock sensor isnt necessarily the most efficient power. More ignition isnt always more power. There is a certain point where you increase ignition, and make no more power. That is where you want to place your ignition, if not a degree or 2 less. Last edited by Jeff@TopGearSolutions; 02-24-2011 at 11:53 AM.. |
