FIXED :) water in battery well caused corrosion... [see post #19]
03-03-2014, 11:44 AM | #23 | |
BMW Fan
17
Rep 178
03-03-2014, 04:52 PM | #24 | |
103
Rep 1,184
i'll be there taking photos...
PAST: 2007 E93 335i 6MT NOW: 2012 F10 M5 Facebook: Achu Ckr|Twitter: AchuCkr|Instagram: AchuCKR|Flickr: AchuCKR|G+: achu.ckr THE BUILD THREAD|COMPILATION OF PHOTOS |
03-04-2014, 02:40 AM | #25 |
171
Rep 3,828
Drives: AzuriteBlack 335i E92
Wow that is terrible!
So this was a leak through the boot? Not the LCI Lights? Was this due to the CSL Boot? Or do you think it was happening with the stock boot? Your car must be faster now it isn't carrying around 6L of water But glad you sorted this mate. I may check mine on the weekend |
03-04-2014, 02:52 AM | #26 | |
103
Rep 1,184
it's actually a common problem, google it, coupes estates and saloons get it! definitely worth a check...
03-04-2014, 03:12 AM | #27 | |
171
Rep 3,828
03-04-2014, 01:02 PM | #28 |
103
Rep 1,184
i doubt i'll be able to take one this week! but i will post it up when i do
03-05-2014, 02:33 AM | #30 |
103
Rep 1,184
nope nothing at all inside the cabin... but the tray under the cover on top of the battery would get moist and only when i saw that, I realised water has been leaking in....
03-06-2014, 12:08 PM | #33 |
Rep 68
Same damn thing happened to me yesterday car wouldn't start, jumped started fine, got it to garage to replace battery only to find its sat in 3" of water!
Main cable underneath completely corroded away. BMW wanted £100 new cable, garage ended up striping cable back and soldering on new connector. BMW mechanic advised to drill a couple of holes through battery tray for water to drain away. Bloody car has only just turned 30k miles so can't believe this has happened. Last edited by Alfamale; 03-06-2014 at 04:12 PM.. |
03-06-2014, 01:03 PM | #34 | |
103
Rep 1,184
first check your drainage points under the mudflaps... if they are clear, something else is making water go to that area, lie in the boot in a foetal position (yes it sounds stupid but trust me) and ask someone to hose the car down and look for the leak with a torch... and then fix that!
03-06-2014, 03:28 PM | #35 | ||
Rep 68
03-07-2014, 03:37 AM | #36 |
171
Rep 3,828
03-07-2014, 03:41 AM | #37 |
Rep 68
LOL garage said its a tiny leak that been building up for sometime so couple of days won't hurt. Plus they drilled the drain holes as per the BMW recommendation.
03-08-2014, 10:53 AM | #38 |
BMW Fan
17
Rep 178
Seems this is a common thing now after a long season of rain!!!
01-14-2020, 01:45 PM | #39 |
Rep 1
Water in battery well, need help on what should it cost to repair.
335i_cab
I have a BMW 335i convertible, and the same thing happened to me.. the car wouldn't start after heavy rains, got it towed to BMW dealer, they found water in battery well, +ve terminal rusted (see picture), and they refused to repair, and asked me to take it to a body shop. They are saying it will require the battery well tray to be replaced, cut out and welded, etc, Any help on what it should cost to repair, and how you resolved your issue, would be greatly appreciated. |
01-22-2021, 01:20 AM | #40 |
13
Rep 92
Just fixed mine, but did create other issues with the cables, but ended up sealing the entry point of the positive cables.
Mine looked horrible, but cleaned up decently. Still trying to diagnose the no-start. I doubt your pan is rusted enough for a pan replacement. https://www.e90post.com/forums/showt...1#post27145947 |
05-13-2022, 02:45 AM | #41 |
Rep 23
This post has to revived. This is not a complete repair.
You have to jack the car up,remove the rear passenger tire, clean and repair the other 2 terminals ON THE OUTSIDE OF THE CAR. Or have a car audio shop crimp and solder 0guage wiring and discard your BMW conectors and run new holes through the rear panel with groomets. |
01-23-2024, 10:25 AM | #42 |
Rep 1
Can anyone tell me how easy it is to change the positive battery terminal to the bulk head near wheel arch. I’ve had the water issue but was 10-12 inches high covered 2/3 of the battery. After investigating? And a new battery later still not working so as everyone states it starts okay on the jump + in engine bay. Found cable totally rusted through. Any pics on how they secure to the bulkhead or advice please. Thanks in advance
Hi |
