09-23-2014, 09:51 AM | #23 | |
Rep 5
How stiff is the M3/4?
I have exactly the same, I live in the Netherlands and here the government has set out to make life as miserable as possible for people who likes cars......they have literally speed bumps everywhere. I get this crackling noise going over the speed bumps and in particular when I turn into a speed bump with one wheel first. My only conclusion is that the chassis is twisting and there are probably some friction between the windows and the rubber. It could also come from the CF roof but not sure. For me the problem is not the noise itself but what I would like to understand is how stiff is this car actually if this can happen? There is a video on youtube with one of the M designers bragging that the car is so stiff it needs 40000 NM/degree. Now if the car is so stiff you would not expect crackling noises going over bumps on the road. The car simply feels cheap!!!! |
09-23-2014, 06:52 PM | #26 | |
225
Rep 490
2020 M2C.
09-23-2014, 07:04 PM | #27 |
235
Rep 576
+100000. I've tried to spreading the word but I feel ignored. Perfect going two weeks. I wish I had this stuff for my nsx's top many years ago.
I'm doing the felt tape on the trim which will probably give me the old E36 noise free experience. Can't wait . |
09-24-2014, 07:53 AM | #29 | |
Rep 5
Sorry I can't take squeaking, rattling and crackling noises as a sign of stiffness. To create the noise parts have to move against each other and that can only come from twisting of the chassis. Yesterday I did the test of lowering the windows and the noise disappears. I can only conclude that when turning into a speed bump the body twists so that the doors move slightly, rubbing the windows against the rubber seal. But maybe I am wrong......... |
09-24-2014, 08:13 AM | #30 |
15
Rep 55
I am glad to hear you confirmed the results of my "roll down the windows test"!
As far as the stiffness of the car, I think the logic here is that the car's chassis is so stiff that the "bolt on" parts like windows move a lot in comparison to the extremely stiff chassis. Hence the creaking noises. Given the greater stiffness of the M3/M4 I would expect more creaking noises in these M cars vs the regular 3 and 4 series cars. Make sense?
My BMW history: 1977 320i, 1993 325is, 1995 E36 M3, 1999 740i Sport, 2004 E46 M3, 2005 E46 M3 ZCP,
2008 E60 M5, 2011 E93 M3 convertible, 2011 335 Xdrive, 2008 X5 3.0 (current), 2015 M3 Mineral White/Sakhir Orange (current). |
09-25-2014, 02:41 AM | #31 | |
Rep 5
Not sure it makes sense........if the chassis is not moving, bolt on parts should not move either.........drove my friends GT3 over the bumps and there is no crackling, squeaking noise what so ever........I guess there is no fix for this one just going to have to live with it....... |
09-25-2014, 12:56 PM | #32 |
Rep 150
My car is currently in for service specifically to replace the rear drivers side window seals due to the creaking noise (and an alignment). I'll be sure to let everyone know how I fare.
09-26-2014, 02:01 AM | #33 |
Rep 5
09-28-2014, 05:44 PM | #34 | |
Rep 26
Remember Newton's laws… an object in motion will tend to stay in motion. So when you go over a bump in the road, the upward motion of the wheel will be transferred to the body. Since the chassis is so stiff, it does not 'absorb' any of the kinetic energy of the bump. Instead, that energy is passed on to the interior parts like the plastic trim. I'm not saying it's OK, but I understand why there are more creaks and rattles than a regular 3 series. I had a Lotus Elise SC, which has an insanely stiff chassis. Well, it rattled like a tin can over bumps. |
09-29-2014, 12:02 AM | #35 |
211
Rep 3,288
Drives: anything given a chance
Teflon tape around the door where the rubber seal connects fixed this problem for my F30. You don't need to reapply anything over time and it's practically invisible.
09-29-2014, 10:07 PM | #36 | |
235
Rep 576
I believe most noise is from the A/C and carbon trim meet. Just push on your A/C vent and trim area and you can hear it. I did go to the dealer and tried it on a few other F30's and they all did the same creak. With bumpy semi truck lanes you can hear the noise when the radio is off. |
10-07-2014, 10:28 PM | #38 |
1033
Rep 1,997
haha love your avatar as well ... i'm sure the reason they didn't do this from the factory is due to weight savings on all the tape?
i'll probably end up doing this at some point although my wife probably won't be happy seeing me pull things apart ... it makes her nervous and rightly so, but i should cause minimal damage using your well laid out instructions. thanks! matt |
10-08-2014, 12:00 PM | #39 |
Resident Engineer
135
Rep 748
Anyone have door panel rattles? My passenger one has been getting ridiculous
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD 2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air European Delivery Journal & F8X Door Rattle Fix Machine Shop Directory - www.mfgcenter.com |
10-08-2014, 01:38 PM | #41 |
264
Rep 1,238
Drives: 2020 X6M Competition DG
Any suggestions as to where I can find gummi pfledge other than online?
I've already checked Home Depot and no luck.
2020 X6M Competition // Donington Grey // Executive Package// Bower and Wilkins Sound System // Driver Assistance Package // CF Trim
10-08-2014, 02:37 PM | #42 |
Resident Engineer
135
Rep 748
Online is your best bet. Amazon has Prime eligible ones
10-08-2014, 04:18 PM | #43 | |
573
Rep 1,990
Sound almost disappears when I lower the window little bit. |
10-08-2014, 04:29 PM | #44 |
32
Rep 87
I get a loud rattle coming from the door lock cylinder button thing. If the doors are unlocked (lock cylinder up), 80% of the sound goes away. I can make the sound go on and off by locking and unlocking the door while driving.
