10-16-2022, 08:55 PM | #265 |
1411
Rep 531
One of them has a filter but the original picture does show alot of variations! Thank you!!
10-16-2022, 08:59 PM | #266 | |
4162
Rep 3,706
Drives: 2022 M5C
Not a BMW guy...but certainly an M5 guy.
Camarejh1410.50 |
10-23-2022, 07:50 PM | #269 |
5293
Rep 10,686
I have DG and run Titan7 TS5 in satin titanium (think gunmetal). Any of the usual colors work with DG — silver, gunmetal, black.
TheCookieMonster298.50 |
11-05-2022, 04:40 PM | #270 |
Porn Star
1316
Rep 3,350
Specs on these Titans please?? Love the look. Can you do these in gold?
11-15-2022, 03:16 PM | #271 |
125
Rep 149
Heres My imola red f90 sitting on HRE SC101SC's
Current: ?22 F90 M5 Comp Individual Imola Red
2018 c63s coupe sold |
11-15-2022, 10:44 PM | #272 |
151
Rep 142
11-15-2022, 11:00 PM | #273 | ||
383
Rep 161
916_M5366.50 |
11-16-2022, 08:50 AM | #274 |
665
Rep 364
Drives: 2019 F90 M5 Comp
Specs :
BCForged HCS21S - Gloss Brushed Grey with Black Hardware 21x10 +19 21x11 +24 Tires: MPS4s 285/30/21 - 295/30/21 Suspension: KW HAS Kit - (F) max low (R) Middle
19" BMW F90 M5 Comp
Utku Noa 93 Tune: 700hp/680tq Check out my Socials: https://solo.to/whatsyourforte |
11-16-2022, 10:29 AM | #276 |
4098
Rep 5,240
NCG80M3664.50 |
11-16-2022, 01:39 PM | #277 | |
1186
Rep 1,658
He can contact us as well. Auto Talent ordered the wheels through us and we submitted the order to HRE and spoke with their engineers about the fitment to make sure everything was perfect.
www.WheelsBoutique.com || David@WheelsBoutique.com || 786 249 0127 ext. 2109 YouTube Channel: https://www.youtube.com/user/WheelsBoutique |
11-16-2022, 01:40 PM | #278 |
1186
Rep 1,658
Client F90 M5 CS on 21"x10" || 21"x11" HRE S101SC's. More photos at - https://wheelsboutique.com/gallery/b...-on-hre-s101sc
11-17-2022, 07:56 AM | #280 |
665
Rep 364
19" BMW F90 M5 Comp
11-17-2022, 09:08 AM | #281 |
Be Present
269
Rep 74
11-17-2022, 09:12 AM | #282 |
125
Rep 149
its argon brown extended
11-23-2022, 05:26 PM | #285 |
5293
Rep 10,686
The offset is different at 22 front versus 28 stock and 30 rear versus 28 stock for 20” wheels and the wheels are 1/2” wider. Together that may be enough. Half of the extra 12.7mm width will be on the outside. So front, the 6mm or 1/4 inch less offset pushes the wheel out and you have another 6mm wheel width on the outside. That is like a 12mm or 1/2” front spacer on a stock 20” wheel. Rear, you have more offset so the wheel would be 2mm further in but the extra 6mm wheel width on the outside counters that for a net gain to the outside of 4mm or about 3/16”.
Fronts should be ideal or very close. Rear you may want a small spacer but a hub extender should be used for anything more than a few mm (spacers need to be 10-12mm to support an integrated hub extender). Add wider tires and half the width will also be on the outside. I am not using spacers and don’t plan to. I have them and ran them on stock wheels and snow wheels. Once I go to wider tires, I think the TS5 will fit nicely. |
11-23-2022, 07:12 PM | #286 | |
Be Present
269
Rep 74
