04-06-2024, 04:46 AM | #2641 |
Rep 12
Anyone got a suggestion for an app that uses youtube music credentials but you can actually see some things on the screen? The YT music app just goes full screen and you can't see skip/back/pause, next playing etc.
04-06-2024, 06:46 AM | #2642 | |
1052
Rep 2,371
Drives: E63 645Ci
04-06-2024, 01:19 PM | #2644 | |
40
Rep 224
04-06-2024, 04:46 PM | #2645 | |
Rep 5
External USB controller for the HU
I am planning to create Macros for different app combinations in split screen. One option to trigger the Macros would be to use "floating buttons" from MacroDroid as shortcuts (= buttons that overlay the current apps and can be moved by gestures). However, a better idea has come to my mind: Has anybody ever used an external USB controller for the HU? In my Mercedes C class, the controller could be placed in the ash tray. The tool Key Mapper (or KSW toolkit) could be used to remap the buttons. This would allow for a large amount of shortcuts. I think I'm going to try this using a device like this. |
04-06-2024, 07:03 PM | #2646 |
Rep 15
KSW Toolkit 2 lets you skip/back/pause/next with physical buttons, I use it everyday.
04-08-2024, 10:45 AM | #2647 | |
40
Rep 224
04-10-2024, 11:24 PM | #2648 | |
16
Rep 33
Hands down one of the best YTMusic apps.
2016 BMW X5 M Exec (F85) Donnington Gray on Black
2002 BMW 530i > M5 Conversion w/ LS Swap (E39) Msport Silver on Black (work in progress) |
04-11-2024, 10:46 AM | #2649 |
40
Rep 224
Has anyone noticed that when you press on the OEM steering wheel button to go to the previous track, sometimes your music MUTES simultaneously with going to the previous track? Noticed this today...
Going to the next track never does this. I do use KSWtoolkit and I have swaped the forward command with the back command there because as some have also noticed they were reversed. I checked MCU listener and pressing the next & previous buttons results in a single entry blahblah-161 Shamanix have you seen something like this? |
04-11-2024, 03:58 PM | #2650 |
Rep 14
Hi all,
I'm getting overly confused... I have an F23... NBT EVO ID4... I ordered a HU for NBT... Head Unit as such seems to work but no iDrive control, no switch from a system to the other... Shall I get a proper EVO HU ? Or any chance to make it work ? Thanks |
04-11-2024, 11:22 PM | #2651 |
138
Rep 294
Hi! I don't force my HU much Therefore, everything works for me as originally intended by the Chinese. I didn't notice that. But I note that different music applications can manifest themselves in different ways. As well as the settings and options of the KSW-Toolkit, they can manifest themselves differently on different versions of the MCU. As well as not all options are compatible and will work. I mostly listen to Apple Music and use Carplay/Autokit. I also use the KSW-Toolkit. For a long time using the set of programs I am familiar with, I did not notice any changes. No one complained on the Russian forum either
Try to re-download your version of the MCU Last edited by Shamanix; 04-11-2024 at 11:29 PM.. |
conandrum40.00 |
04-13-2024, 09:27 AM | #2652 |
Rep 2
And knowing Chinese they won't bring additional features. It's the same https://modilimitado.io/en/games thing as jump from PX6 to SD625, faster, smoother, newer... but still the same as the last 3 generations.
04-13-2024, 01:06 PM | #2653 |
138
Rep 294
Considering how the guys from the forum tried and brought their software to perfection, as well as Chinese firmware since sd625 have reached the level of almost release, I would argue Previously, the possibilities were more modest
04-15-2024, 10:35 PM | #2654 |
110
Rep 109
XTRON Android 13 on 2014 F30 320i
I tried searching for a solution so please forgive me if this has been answered a million times. I appreciate all positive and helpful responses!
I purchased an XTRONS 12.3 Inch Android 13 Car Stereo for my son's 2014 BMW F30... he totaled his car so I bought him an F30 320i. https://www.amazon.com/dp/B0CQM4VBPH...t_details&th=1 I used to be a professional car audio installer and I'm currently an Electronics Engineer. Installation went smoothly, I moved the fiber connection from old harness to new harness, ran the aux cable to the center console, the display works, just no audio. I can make a phone and receive phone calls. I have no factory idrive control and can't confirm I'm using Aux input on the factory stereo because my iDrive won't display properly: I tried adjusting these values: "Full screen display of the original car", tried checking the box but then the screen was entirely black... I tried every resolution, the automatic adjustment didn't do anything either, I tried both LVDS types but neither worked: I tried changing the audio switch option but both Manual Switch and Menu Interface with IDriver Switching seemed to pull up the first screen when long pressing the menu button on the idrive control. Any suggestions? I just emailed XTRONS tech support but there seems to be more knowledge here.
2023 BMW M-2 Auto, BG, Carbon Roof/Interior, HUD, 50 year emblems, lighting package
Me: https://apexwheels.com/gallery/bmw/m2/g87 |
04-15-2024, 10:57 PM | #2655 |
138
Rep 294
Please attach a screen about the system from the launcher. Your HU is different from the ones discussed here. I studied the advertisement, the seller was too shy to specify the processor of your HU.
04-15-2024, 11:50 PM | #2656 |
110
Rep 109
Ok, I will have to try to figure that out...
04-16-2024, 01:19 AM | #2657 |
Rep 10
MTK_9109 Android Headunit
Hello, guys.
I recently bought from Aliexpress a headunit for my F34GT. The producer is MEKEDE. It looks like it has some MTK CPU inside, here are the specs: ANDROID: 2312141138 MCU: ML0-mtk C01_wgz01a-zZzzWY_WY-CC568091-8A_20230926-08:46 BOARD: ZQ MTK 9109 APP: ZQ9109_C01_GA6_OSU-BBA-13-EN-D_2023-12-14-1137 While the specs look good, please be aware that this unit cannot support weather widgets, for instance, which for me is a major drawback. |
04-16-2024, 01:44 AM | #2658 |
1052
Rep 2,371
Drives: E63 645Ci
04-16-2024, 08:47 AM | #2659 | |
110
Rep 109
VIN Lookup shows these options: Multimedia S645 BMW US Radio S676 HiFi speaker system S693 Preparation BMW satellite radio S697 Area-Code 1 for DVD S6AC Intelligent emergency call S6AE Teleservices S6NH Hands-free system with USB interface S6VB Control Infotainment
04-16-2024, 09:05 AM | #2660 | |
1052
Rep 2,371
Drives: E63 645Ci
04-16-2024, 12:28 PM | #2661 | |
110
Rep 109
04-17-2024, 02:29 AM | #2662 | |
1052
Rep 2,371
Drives: E63 645Ci
