Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > xDrive Suspension Compatibility List
      05-13-2016, 11:33 AM   #221
NiNeTyOne
Touring cars rock
Drives: e91 330xi / 997 GT3 Cup
Add to the list Koni FSD kit 2100-4123 (Xdrive Wagon) together with OE springs or Eibach Pro Kit (Europe PN) E10-20-014-10-22.
I ordered the Eibach parts from Germany and ended up paying about the same as the US price, shipping included. These are appropriately paired with the FSD's and I've swapped the frond bump stops out for the E36 M3 front bump stops (OE PN 31332225377) which allow for approx 20mm more travel before the front bump stops are engaged.
      06-01-2016, 08:42 PM   #222
Maniac0908
Maniac0908's Avatar
Drives: Alpine White 07 335xi Sedan
Catuned has coilovers. Check them out. Might give them a shot
      06-06-2016, 12:27 AM   #223
unrulyteach
unrulyteach's Avatar
Drives: 2011 335i
2011 BMW 335i  [0.00]
Would rwd H&R sport springs work on awd
      10-31-2017, 08:50 AM   #224
lwgrenier
Drives: 2011 e92 335i XDrive
I'm looking to get Bilstein B4 front struts for my 2011 e92 non-sport 335i xDrive. Would those work?
      03-06-2018, 01:34 PM   #225
jimmychanga
Drives: 2011 e92 335i xDrive
Anybody able to recommend springs for LCI e92 335i xdrive and maybe some pictures to give me an idea of how the fitment looks?
      03-07-2018, 02:36 PM   #226
Julian2485
110
Drives: Black lci e90 335 xdrive
Add to the list ycw coilovers
      04-01-2018, 12:25 PM   #227
Ander335xi
Ander335xi's Avatar
Drives: Bmw e91 335xi n54
Are the m3 e92 original struts compatible with a 335xi e91? Both cars are from 2007
      04-05-2018, 09:18 AM   #228
m135iswede
Drives: m135i xdrive
Looking for coilovers for an e91 lci 335i xdrive. Any recommendations?
Thanks!
      04-05-2018, 10:09 AM   #229
Supermoon
Supermoon's Avatar
South Korea
166
Drives: 2011 e92 335xi
Thanks!
Bilstein will be releasing B14 PSS coilovers for your car.
Model # is 47-269095.
Maybe they're already available in Europe so check it out and let us know if you're interested.
2011 E92 335i xDrive
Pure Stage 1 | DV+ & Inlet | Injen Intake | M3 Cowl | ETS 5" FMIC & CP | Aquamist HFS4 Direct Port | CSF Radiator | Wagner Catted DP | BMW PE | Apex FL-5 | Michelin PS4S | 335is Engine mount | SDW Monoball thrust arms | UUC Swaybars & SS Brake lines | Bilstein B8 | Dinan Springs & Shock mounts | Whiteline RSFB | M3 Rear Control arms | Manzo Toe arms | Wavetrac LSD
      04-05-2018, 10:26 PM   #230
Julian2485
110
Thanks!
finally coming out with something for the xi
      04-06-2018, 03:38 AM   #231
m135iswede
Thanks, I'll check them out.
How much, or what differs the e90/e92 335xi suspension from the e91 335xi suspension?
Tried to google it, but can't find. Is the KW1 available for e91 335xi?
Thanks!
      04-06-2018, 03:42 AM   #232
Supermoon
Supermoon's Avatar
South Korea
166
Thanks!
No difference among e90/91/92.
All interchangeable.
Not sure about e93.
      04-06-2018, 04:16 AM   #233
m135iswede
Not sure about e93.
Thank you supermoon for taking your time and reply
So all suspension that's specified for e90/e92 (335i xdrive) also works on the e91 (335i xdrive)?
That mean I could go for the KW V1?
      04-06-2018, 04:21 AM   #234
Supermoon
Supermoon's Avatar
South Korea
166
Not sure about e93.
Yes you can.
See for yourself.
E91:
http://www.realoem.com/bmw/enUS/show...diagId=31_0742
E92:
      04-06-2018, 04:27 AM   #235
m135iswede
Yes you can.
It's up to your need and taste.
Priority is comfort, after that handling. Don't want it to be crashy, as a baby will be riding in it from time to time.
      04-06-2018, 04:30 AM   #236
Supermoon
Supermoon's Avatar
South Korea
166
Yes you can.
Then consider Koni FSD paired with eibach xi pro-kit springs.
      04-06-2018, 04:36 AM   #237
m135iswede
Rear seems to differ tho
E91: http://www.realoem.com/bmw/enUS/show...diagId=33_1283
E292: http://www.realoem.com/bmw/enUS/show...diagId=33_1353
      04-06-2018, 04:38 AM   #238
Supermoon
Supermoon's Avatar
South Korea
166
Sorry didn't know that. Glad you caught it.
      04-06-2018, 06:13 AM   #239
Supermoon
Supermoon's Avatar
South Korea
166
But the PSS is compatible. Check bilstein's catalog.
      04-06-2018, 05:09 PM   #240
animerickover
Drives: 2003 Subaru Legacy L 5M
planning on getting a 335i xdrive to replaced my "totaled" subaru.
for the best blend of comfort and actual performance, all ive read on here seem to point to either the eibach pro kit or H/R sport springs with the koni yellows. would this be an acceptable compromise for pac NW roads?
thanks in advance
      06-04-2019, 08:40 PM   #241
Bmw2009
Bmw2009's Avatar
Drives: 2009 bmw 328i xdrive
Does eibach sportline springs work on a 2009 bmw 328i xdrive sedan even if it's from i ?
      06-09-2019, 02:02 PM   #242
4 Doors
4 Doors's Avatar
1169
Drives: 2008 BMW 335xi (E90)
2008 BMW 335xi  [10.00]
As the two above have mentioned, looking into KONI Yellows (front/rear) with Eibach springs (from RWD correct?)
Question is about the bump stops. For xDrive, are we using Z4 bump stops for the rear and E36 M3 bump stops for the front?
Also, any suggestions on mount kits? (Just go OEM?)
If so, can someone provide us the part numbers and can we update the main post on compatibility?
Instagram: @4doors
Current: 2011 E91 328i M-Sport Touring
Past: 2008 E90 335xi
1996 E36 328i Sport
