05-20-2023, 05:05 PM | #221 | |
10543
Rep 41,215
Drives: 2018 Alpina B6 650ix GC
Not sure what is question here. As written, can work with E-Sys or standalone.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
05-26-2023, 02:32 AM | #222 |
Rep 31
Hi Guys,
Shawn than you for your supprot. I've bought the Bimmer Utility app, installed. Shawn explain me that now there is no need to use e sys. I've opened app, connected, some info about vehicle showed. I went to FDL editor view CAFD files, did some changes in modules but... there is no save button (it was visible before I've view CAFD) I can't save my changes, as I understand I should save it and then go to HOME and Write NCD ? What about retrofit coding, for example I would like to change headlights or add heated seats ect. does BU cod such stuff ? I've rote to support team BU but maybe someone already play with it and know answers for my question... |
05-26-2023, 09:58 AM | #223 | |
10543
Rep 41,215
05-28-2023, 04:36 PM | #226 |
Rep 1
ISTA-P
I downloaded the ISTA version 4.36.40 from MEGA. I cannot seem to find the ISTA-D KG.exe file or the keygen folder. I also do not have the ISTA_DAPI.dll file. I therefore cannot go past the register key installation aspect. Can somone please assist?
05-28-2023, 04:45 PM | #227 |
10543
Rep 41,215
I already PM you about this on Bimmerfest.
06-01-2023, 06:23 AM | #229 |
10543
Rep 41,215
No. I have never seen one offered.
06-02-2023, 10:20 AM | #232 |
10543
Rep 41,215
ENET WiFi or ENET cable.
MHD universal is also supported as its ENET also.
06-03-2023, 11:31 AM | #234 | |
10543
Rep 41,215
Read 2nd car HU ECU, save Coding data .ncd file as Car2_HU.ncd. Compare by loading both files in BU "NCD Compare" module.
06-03-2023, 12:42 PM | #235 |
35
Rep 43
Thanks, I'm able to do this on the iOS version, my problem is on the PC app, after I select and load both files, nothing happens... If I try to print the file, it says nothing is selected...
06-03-2023, 12:46 PM | #236 |
10543
Rep 41,215
Contact their tech Support via Website.
06-03-2023, 02:41 PM | #238 |
10543
Rep 41,215
If using an ENET cable and PC with no LAN port, then yes.
06-03-2023, 03:46 PM | #239 |
Rep 52
06-03-2023, 03:57 PM | #240 |
10543
Rep 41,215
bestb2.00 |
06-13-2023, 12:57 AM | #241 |
Rep 5
Good morning everyone.
I'm a little confused, I have previously used EsysX with Esys for FDL coding. I have now bought Bimmerutility, do I have to use it along with Esys for FDL coding? or will it work on its own without Esys for FDL coding? |
06-13-2023, 04:38 AM | #242 | |
373
Rep 464
On a Windows platform, BU is used to edit CAFD/FA files (as well as comparing CAFD files and analyzing CAFD changes with VO changes) and Esys (w/o a Launcher) is used to NCD/VO code. On an IOS/Android platform, BU does not use Esys and operates similarly to other IOS/Android FDL/VO coding solutions.
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
