05-07-2024, 08:47 PM | #23871 | |
11593
Rep 12,738
my wife is probably going to get the new GX. once she does, i'll consider selling the f250... kinda depends. if the gx feels overwhelmed, i'll just keep the truck. although i don't use it much, i really like it when i do.
Instagram; @roastbeefmike
omgzirra_exe1543.50 |
05-09-2024, 02:30 PM | #23873 | |
1544
Rep 1,748
GLWS man.. i didnt realize it was 20K freaking miles
05-09-2024, 02:42 PM | #23874 |
326
Rep 507
Drives: M4 GTS
05-10-2024, 04:07 PM | #23875 |
11593
Rep 12,738
I don’t know why this thought hasn’t occurred to me yet, but is there any hope for taking out the rear quarter glass and rear window without breaking it?
If it’s just gunna break I might as well bash it with a hammer to remove it.
05-10-2024, 04:16 PM | #23876 | |
1544
Rep 1,748
once you get the trim off you can literally take a razer and scrape the glue off the back of the rear window and take it off. rear glass, remove trim. use razor blade to scrap underneath the glass to loosen glue, take a pry tool and lift the window up, and make your own little tool by 2 cylindered pieces of wood (what ever gives you a good grip) and a loooooooooooooooooong fishing line, probably something like 15lb test line.. and insert it thru the gap between the rear glass and chassis, and on inside of the car, you just have to have someone help you "saw" thru the glue.. this should help remove it with out breaking the glass.
05-10-2024, 04:21 PM | #23877 |
97
Rep 130
05-10-2024, 04:23 PM | #23878 |
14
Rep 71
I just want to be clear that I'm not fast enough (or hard enough on the car) to need these, but based on what I've seen them go for, I couldn't pass these up. A guy here in town was parting a few cars out and I noticed them in one of the pictures, got the full front/rear set for $3500.
There's some light corrosion on a few of the bolt heads and some areas where the finish slightly rubbed off on the edges of the calipers, so if anybody has pointers on addressing that stuff before installation, that'd be appreciated. |
CamasM3e933224.00 1FastSicilian505.00 |
05-10-2024, 04:30 PM | #23879 | |
1544
Rep 1,748
someone will probably correct pricing, but for my alcon kit its $1400 for new rotor rings with hardware. i'm guessing the other $600 is rebuild kit for the caliper(s)
05-10-2024, 04:47 PM | #23880 | |
14
Rep 71
I haven't seen anything about them that would tell me that they would need replacement (and the rotor rings actually look pretty decent up close) |
05-10-2024, 04:57 PM | #23881 | |
1544
Rep 1,748
just get them checked by a shop that knows AP stuff. should be fine to use right away.
Northbay13.50 |
05-11-2024, 03:50 AM | #23882 | |
11593
Rep 12,738
05-11-2024, 08:36 AM | #23883 |
34
Rep 103
Just picked up some v730’s (275/35/18) and headed to my first day with them today. Any recommendations on cold/hot pressure targets? Looks like it’s going to be ~92 degrees at Buttonwillow today. Car is around stock weight, I run intermediate group, and care more about longevity than absolute lap times. They’re replacing some RS4’s.
05-11-2024, 08:53 AM | #23884 | |
1256
Rep 1,504
2011.5 E90 M3 DCT ZCP Slicktop
05-11-2024, 09:52 AM | #23885 |
34
Rep 103
05-11-2024, 07:10 PM | #23887 |
1544
Rep 1,748
you probably wont like them the first track day.. they really need a proper heat cycle to wake up.
i set most of my 200Tw tires to 28-30psi cold.. and target like 33-35psi hot. full weight car also i've also tried running it really cold at 23psi aiming for 30psi hot and i liked it also lol alignment dependent of course..
rhyary1573.00 |
05-11-2024, 11:51 PM | #23888 | |
34
Rep 103
kolosy1557.50 |
05-12-2024, 10:42 PM | #23889 | |
1558
Rep 2,084
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
rhyary1573.00 |
05-17-2024, 03:17 PM | #23891 |
1558
Rep 2,084
so i'm going to try out carbotech pads once my current set of ferodos goes bye bye. do you guys sand down your rotors when swapping compounds, or is that overkill? i've seen it recommended by various mfgs.
05-17-2024, 04:18 PM | #23892 | |
1544
Rep 1,748
i use dish soap and water to clean my rotors when i swap pads lol gotta get a DEEP Clean on those.
