04-25-2024, 04:49 PM | #23783 |
1548
Rep 1,750
yeeesh snap oversteer?
04-25-2024, 04:54 PM | #23785 |
1558
Rep 2,084
he thinks he dropped a wheel and then yeah.. hard to tell though.
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
04-25-2024, 04:55 PM | #23786 | |
Rep 16
However people forget; cheap to buy in. Expensive to stay in Cup cars aren't necessarily cheap to maintain as everything times out I did some SSM this past weekend and I understand the vibe. 40 car field. Cheap thrills. Slow as fuck. But it was a party Hate the amount of contact however..... |
CamasM3e933224.00 mikerunt326.00 |
04-25-2024, 06:31 PM | #23787 |
97
Rep 130
Oof, he's lucky to be uninjured (I bet he's sore AF though). I run a 4-point harness and HANS, but watching this makes me want to put in a half cage, bucket, and 6-point. I like to tell myself I don't push hard enough to need more than what I have at the moment, but this is a reminder that I'm likely lying to myself...
04-25-2024, 06:41 PM | #23788 | |
1558
Rep 2,084
omgzirra_exe1548.00 |
04-25-2024, 06:49 PM | #23789 | |
97
Rep 130
My initial plan was to install a Slon panel between the rear seat and trunk, along with a harness bar. I wanted a clean look without adding back in weight that I would be removing with rear seat removal. That said, even if a half cage isn't NASA/SCCA spec, I'd imagine that to be a safer alternative? |
CamasM3e933224.00 |
04-25-2024, 10:31 PM | #23790 | |
1966
Rep 1,925
Drives: E92 M3
I like that some of them come ready to go with fresh rebuilds, several sets of wheels, and sometimes spares. The drawback is that you still have to deal with issues and part failures where it's not easy to find spares or troubleshooting information.
04-26-2024, 09:32 AM | #23792 |
128
Rep 90
Do you guys track on summer tires or track tires. I am on Pilot supersports right now...
Is there anything else then sport cup 2's that I can use around town and track ? and will not send my wife into fences in rain ?
2009 E92 M3 6sp manual - stock
2008 335xi sports package 6sp manual ; Helix stepped intercooler, M3 steering wheel, ZCP M3 shifter, Eibach sport springs, Bilstein B8 shocks; Rob Beck stage 2 turbochargers; MHD stage 2. |
04-26-2024, 09:55 AM | #23793 | |
424
Rep 304
Track tires are track tires, I watched a lot of spins on cars in the wet at VIR for folks than only brought 200tw track sets. |
TheMechanic127.50 |
04-26-2024, 10:46 AM | #23794 | |
1548
Rep 1,750
For 18-inch wheels, I go for 275/35/18. For staggered OEM ZCP, I opt for 275/35/19 and 305/30/19. The V730s tires run narrow, so don't worry too much about the widths. They'll be closer to 265/35/19, 295/30/19, or 265/35/18 if using the 18-inch option. Another great option that won't break the bank and serves as an excellent semi-track day / daily tire is Conti ECS 02 (340TW). Priced under $1600, depending on sizing, I use them in 285/30/18 for my daily and canyon driving. Yes, it's overkill to go square in this size, but it's more for the stance—lol. The same concept applies to tracking a PS4S: higher cold PSI, max hot 40psi, and don't drive the tires to their limit if you want them to last. They also have great water evacuation. Personally, I think they perform better in the rain than the PS4S. They also offer a wide range in 19-inch sizes. You can opt for 265/35/18 with 295/30/19 if you want to be precise on sizing.. I've had good experiences with the Supercar 3 (220TW) as mentioned by Cmassey3 , which come in the same aforementioned sizes as above for 19s, but limited to 275/35/18..if you have 18s. these are usually around $1300 as well. ECS 02 (340TW)- https://www.tirerack.com/tires/conti...ntact-sport-02 V730 (200TW) - https://www.tirerack.com/tires/kumho-ecsta-v730 Supercar 3 (220TW) - https://www.tirerack.com/tires/goody...-f1-supercar-3
TheMechanic127.50 jmeenach97.00 |
04-26-2024, 11:08 AM | #23795 |
128
Rep 90
Thank you all; I have 2 sets of wheels, both stock 19" bmw, and I keep one with winter tires. I had bad experience with the Goodyears on my previous 2013 Shelby GT500... almost crashed it twice on cold tires.
Those tires could not stick on 3rd gear until warmed up, but that was a 670HP monster EDIT: I remember they were the earlier version of supercar 2 or something, definitely not V3. I think the kumhos look good and are a good option; how do they behave on street when cold and wet (not winter cold, just not warmed up) ?
04-26-2024, 11:25 AM | #23796 | |
97
Rep 130
There will be a tradeoff somewhere. Your current PSS will get torn apart if you track regularly or if you are putting down decent lap times. BUT they will give you far better wet traction when needed. Just need to find the balance that makes you happy. |
TheMechanic127.50 omgzirra_exe1548.00 |
04-26-2024, 11:34 AM | #23797 | |
128
Rep 90
04-26-2024, 12:06 PM | #23798 | |
1548
Rep 1,750
For what it's worth, the E92 GTS used 255/35/19 and 285/30/19. I should note that going past 285, you should be prepared to make some adjustments for fitment, such as alignment and removal of rear spacers if you have them, as the tire could make contact with the edge of the fender. I think roastbeef ran 305/30/19 PSS on the rear of his ZCP wheels. So, regarding your question about cold temperatures, it's not the best. The V730 LOVES to get heat into them; they perform great once that happens. Personally, if I were a better driver, I probably could do 15-20 minute hard sessions, and the tire wouldn't drop off until the last lap, most likely. It's not the fastest tire. This is considered an enduro 200TW. Because it runs a bit narrow, the steering response is great up front due to the slight stretch, and it has great tire roll-over characteristics as well. But mainly, this tire is great on heavy cars like ours since we can get heat into the V730s easily. It kind of sucks if they are not heat cycled, though, but that gets fixed after a few events and just from daily driving. I also drove them in the SoCal rainstorms from OC to Santa Barbara recently. It just required more focus than normal, and my tires were balding at the time—lmao. I can't be bothered to change my alignment when I'm street driving. Alignment: Camber: -3.3°F -2.5°R Toe Front: 0° Toe Rear: 0.17 total Toe-In And to be honest, I ran too much camber for a 275/35/18 V730. I needed to back it down to like -2.5°F and -2.0°R because at -3.3°F, I was basically on the edge of the sidewall, so the tire itself could've worn better over time. As by the time I replaced them at 13K miles, they corded on the edge as expected. So with that knowledge, you could get away with less camber if needed. see image of my heavily worn and used V730s at 13k-ish miles.. and yes I'm really bad at remembering to rotate my tires. Also, if the V720 ACR is good enough to be a Factory Viper ACR tire, it's good enough for me. Because the word on the street is, the V730 is just a relabeled V720 ACR.
TheMechanic127.50 |
04-26-2024, 01:34 PM | #23799 | |
1558
Rep 2,084
this is what the underside looks like with the plates. not sure there's anything else i can do short of going to a different wing with a chassis mount...
04-26-2024, 02:35 PM | #23800 | |
97
Rep 130
Another option (maybe) would be to swap to a carbon trunk. Not sure if it would crack over time with holes being drilled through the carbon weave, though. |
04-26-2024, 03:42 PM | #23801 | |
1548
Rep 1,750
i think i have the drawing for this cylindrical tube thingy.. some where. once i find it i'll share it i think there was a p/n for it also but i dont remember. but the idea is you support the top skin of the trunk, with the additional metal piece welded to the actual skeleton of the trunk to support it more. I wonder if kolosy can resolve this by just adding a washer. On top of the bracket he has to spread the load a bit more? since its such a wide piece of metal lol.
jmeenach97.00 |
04-26-2024, 04:59 PM | #23802 | |
1558
Rep 2,084
04-26-2024, 05:40 PM | #23803 | |
326
Rep 507
Drives: M4 GTS
04-26-2024, 10:51 PM | #23804 | |
1966
Rep 1,925
Drives: E92 M3
I have a street set of tires on the ZCP wheels I drive to the track that can deal with rain. I wouldn't bother with Cup 2s unless you have no other option as they're overpriced for the performance.
