03-13-2024, 11:18 AM | #23651 | |
1542
Rep 1,746
Even before I upgraded to the F8X rear BBK, I ran the OEM rear brakes with matching brake compound, and it didn't disturb the car at all. I used Carbotech XP12 Front Pads and XP10 Rear Pads, as well as XP10s for the fronts. The XP12 and street driving really ate up my rotor though, in roughly under 20k miles. Personally, I think the Alcon kit is underrated and offers great value for the performance gain. I had Alcon on my Evo and my S2000 for many years before getting an E92, and once I found this kit, it was a must-have. What I enjoy about my Alcon kit is its easy communication with Pro-Sytem brakes, which produces the kit for BimmerWorld. Replacement rotor/hats/kits are made locally in the US, with fast shipping, etc. I think the caliper is also like 1 or 2 lbs heavier than the AP9668, though, so that's one downside. If you can sell your ST40 kit and it covers a good chunk of the CR6420 kit, absolutely go for it. But it's not really needed, although with how hard it is to get Stoptech parts, it might be an even better reason to move on, assuming they are still having troubles with inventory. For what it's worth, BC produces the majority of the parts for other "Taiwanese" based coilovers, from internals to shock bodies, etc. They aren't the best, but they're not great either. However, they certainly get the job done and are relatively cheap to replace since you can buy just the shocks if something goes wrong.
1FastSicilian505.00 |
03-14-2024, 09:30 AM | #23652 | |
Driver
2692
Rep 2,714
E90M 6MT Slicktop Single Humper in need of a diet
tsk941526.00 |
03-14-2024, 10:25 AM | #23653 | |
-Frank
505
Rep 697
also, knockback sucks... and I figured upgrading to a better brake kit will give me more confidence on track
2005 M3 - SilverGrey/MT - SOLD
2013 E92 M3 ZCP AW/IR-BLK 2022 Ram 1500 Laramie Night Edition - leveled/34s IG: @_frank_stone_ |
03-14-2024, 12:05 PM | #23654 | |
Driver
2692
Rep 2,714
As for knockback, yea that sucks, and I wouldn’t settle for a brake setup which doesn’t prevent that…There are anti-knockback springs for the stoptech, but then you are essentially removing the whole braking system anyways, so if the cost delta to alcon kit isn’t insanely huge (after selling stoptech), I would probably also make the switch too. I splurged on a PFC full bbk on my E90 because brakes on this pig are quite a heavily used item. Never regretted it.
03-14-2024, 12:40 PM | #23655 |
1526
Rep 1,597
I never experienced any negatives with the full Alcon kit myself. They simply worked. Consistent brake pedal, zero fade, good modulation, even pad wear, no knockback, etc.
I guess it depends on how much it would cost you. I'd be tempted to throw in some knock back springs and a better pad and I bet that would be a massive improvement right there. |
omgzirra_exe1542.00 |
03-14-2024, 03:21 PM | #23656 |
1573
Rep 2,871
I have imortant question to ask and since the answer has to be something I can count on, please offer information you know, or link to information I can read about this myself. But refraine from opinions and advise on how to fill oil correctly. Most of us experienced the low oil reading after an oil change and the need to wait for a day or two to get a good resding when all is working as it should.
The issue: I have a carbahn engine with the optional oil pan baffel. It looks like the baffel interfere with the sensor that reads the oil level. Because it tends to flactuate, it may ask me to add oil, and then report later “oil overfill” In my case, if it reports overfill, I know it is only by a little bit. My question is this: What is the harm in “oil over fill” what actually happpens? Will it just spew out the extra oil? create a mess no harm? or will it actual damage somthing? Thanks in advance. |
03-14-2024, 03:38 PM | #23657 |
1627
Rep 1,138
Drives: 2009 E92 M3 Dakar Yellow II
You can get excess oil through the pcv system and lots of smoke/fouled O2 sensors. If overfilled enough, you can get the crank to sweep through the oil and beat air into it. Aerated oil will seize an engine. A google search can list other problems.
Bimmer Barney1254.00 |
03-14-2024, 04:05 PM | #23658 | |
-Frank
505
Rep 697
Did you reach out to Carbahn about it?
amg6975504.50 |
03-14-2024, 04:05 PM | #23659 | |
1542
Rep 1,746
I've experienced overfilling by about .25 quart before, and driving with a few WOT pulls to and from over several days of going to work helped burn off the excess. During my recent oil change, I added 9Q, but it still showed +1 quart on the cluster. After driving around for about 1200 miles over three weeks, the oil level remained with add +1, I just recently added 1q and i'm back to "ok". If you knowingly overfilled by a full quart, it might be advisable to drain some out to prevent issues with crank pressure, as too much oil can cause aeration and foaming. note: I also willingly add .25 to .5 quarts on track days and had no issues. also isn't the whole point of the oil baffle to keep oil were the pick up tube is and not slosh around? so it showing overfilled could just be that.
03-14-2024, 05:24 PM | #23660 |
1573
Rep 2,871
I know I am starting with 9L oil.
I have to see what the display will settle on. Main issue would be bunch of 3-day events at WGI. I will have to add oil proactivly, but how much is hard to know without a physical deep stick. Last year I was able to add a bit every day and it seemed to be correct. I got home and it said “overfill” when I shut off the engine after it was fine driving 3 hours back home. Grrrrrr. :-( |
03-14-2024, 05:45 PM | #23661 |
1526
Rep 1,597
Is it too late to add on one of those physical dipsticks Bimmerworld, and others, offer..?
That would eliminate all of this 2nd guessing. I generally would fill my car, let it idle on level ground for 15-20 minutes and reaccess. I would often need to add a small amount, but I never had to do anything again after that point. |
03-15-2024, 08:55 AM | #23662 |
1619
Rep 1,590
Selling my KW Clubsports if anyone here is interested
https://www.m3post.com/forums/showth...7#post30987957
2012 E92 M3
Instagram Turbo__Joe |
03-15-2024, 12:43 PM | #23663 | |
23
Rep 45
Are you adding a full quart when it asks you to? I usually add 0.25... up to 0.5 at a time. I've had instances where it asked me to fill a quart, and it really only needed a half to get to the right spot. non-Carbahn motor, FWIW, but I think the logic still holds. |
03-15-2024, 02:23 PM | #23664 |
1627
Rep 1,138
Asked me for a quart, I tried 250 mL just in case. Gave me an overfill warning. FML I want to meet the person that decided to 86 the dip sticks on these cars and fire them into the sun
03-15-2024, 03:11 PM | #23665 |
1542
Rep 1,746
also to add, i had a friend who has a 4.6L stroker now and his oil level sensor will never read full, turns out it was the Voltage Regulator in the actuator that caused the problem lol which i think also resolved an issue with another forum member.
tsk941526.00 |
03-18-2024, 11:23 AM | #23666 |
1556
Rep 2,084
does anyone know if m-world is still around? i ordered an AiM ECU cable from them ... 3 weeks ago? And nothing. Phone goes straight to google VM, no response to my email. I paid through paypal, so no money lost but still odd.
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
03-18-2024, 02:08 PM | #23667 | |
1526
Rep 1,597
I had the ECU cable on my last car and the kit worked great, and I was going to buy another one now... |
03-18-2024, 06:45 PM | #23668 |
424
Rep 304
I'm really impressed with the longevity of my PFC08s. I think I have 4 track weekends and just passed tech for the 5 with them. Granted, I'm not doing maximum attack laps and that factors in a lot. As a casual track day pad, these are great.
When I got to drive a G87 M2 at the Performance Center, the first thing I noticed was the soft modulation characteristics of the street pads and how much I missed the bite of the 08s haha. |
omgzirra_exe1542.00 amg6975504.50 |
03-18-2024, 09:10 PM | #23669 |
2467
Rep 5,929
I’d say the chances are slim to none that they are still in business.. I can’t even tell the last time the owner has logged into m3post.
03-19-2024, 08:36 AM | #23670 |
1556
Rep 2,084
last post in 2016, but someone's still paying for the website
03-19-2024, 09:20 AM | #23671 |
2467
Rep 5,929
Interesting. Good point about someone keeping the lights on. When I looked at his profile page, it looked like it was sanitized after something bad had happened there! Unless he changed his username? I bought a set a Swift springs from him over a decade ago.
03-19-2024, 11:10 AM | #23672 |
1542
Rep 1,746
i would say get your money back, it's a lost cause most likely.
