12-26-2022, 02:17 PM | #215 |
Supreme Allied Commander
3890
Rep 54,577
Drives: F80 M3
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins.
A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over! 2-year limited warranty on all of our products - worldwide. General Features *DFV (Dual Flow Valve) *Rebuildable *Corrosion salt spray tested (ISO 9227) *2 year Limited Warranty Front McPherson Strut *Single bleed adjuster *Spring preload adjuster (approx. 20 mm lower than standard) *Coil Springs (rate 60N/mm) *Height adjustable bottom mount to prevent preloading or unloading of the spring *Dustcovers *Use with original top mounts or camber plates Rear Conventional Shock Absorber *Single bleed adjuster *Separate spring preload adjuster (approx. 20 mm lower than standard) *Coil Springs (rate 110N/mm) *Dustcovers *Use with original top mounts BMZ MN01S1 |
03-08-2023, 08:05 PM | #219 |
3890
Rep 54,577
Drives: F80 M3
Very very special pricing on Ohlins Road and Track for all applications. Order must be submitted by the end of the business day on March 12th.
PM for a quote! |
03-10-2023, 11:37 AM | #220 |
3890
Rep 54,577
Drives: F80 M3
PM for a quote! |
