DFFF -- Dont Fear the Fuel Filter
02-01-2013, 08:58 PM | #1 |
149
Rep 2,383
With all the concern about injectors and intake carbonization, I think it is even more important that we make sure our fuel filters are changed. So here you go:
Credit where credit is due: Great info on changing fuel filter in a 330d in this UK thread: http://www.e90post.com/forums/showthread.php?t=387120 Now, here is more info: For parts you will need: 1. 13-32-7-793-672 Fuel Filter Cartridge (I got this from Tischer for $41.47) 2. Small hose clamp (I had to run off to get some of these in the middle of the job) Besides a jack and ramps, For tools, you will need: 1. 8mm socket driver for removing the car bottom cover, 2. socket ratchet with small extension for bracket bolt (I forget size of bolt head), 3. small torx driver for filter clamping bolt, 4. big screwdriver or pliers to remove clip from rear of filter 5. cutters/hacksaw/dremel to remove band securing fuel hose to nipple of filter. 6. MOST IMPORTANT: EYE PROTECTION!!! Lots of crap falls down when you are under a car, and if you choose the dremel removal technique you dont want metal splinters in your eyeballs 1. I drove my front wheels up on ramps (I have to put some 1/2 inch pine boards in front of the ramps so the front overhang is clear, and I backed the ramps with the rock salt bags to stop the ramps from being pushed forward) and jacked up a bit from the rear driver's side (U.S. Left Drive Car) jack point. I did not jack the rear wheel off the ground, just gave myself more breathing room under that side of the car. Make sure el tranny is in park and your parking brake is on and I added bags of rock salt behind a two wheels to inhibit rolling (my driveway is slightly slanted). I also added a second jack under the body next to the main jack as a backup. 2. Slide under the driver's side and remove the bolts holding the cover on the left side of the car (there are around eight or nine). Rotate the entire cover horizontally until the slot on the passenger side of the cover aligns with the two lugs and the cover will come down and you can push it aside. 3. You will now see your enemy: the old filter. Remove the brack bolt with a ratchet and extension (not sure the size, probably around 14mm). Now a weird device with wires will drop free and you can push that out of the way. The filter will also be held only by the rear clip and the front fuel hose and crimp on type clamp. 4. You can remove the front fuel hose clamp now with a pair of cutters/hacksaw or dremel (be careful with the dremel as if it goes flying there are some other things around that it could damage such as a braided hose nearby). 5. At this point, I removed the rear clip with a screw driver (twisting) and worked the base (pump?) out of the rear of the filter and allowed fuel to drain into the catch pan. I then pulled the filter out of the front fuel hose. 6. After removing the torx bolt (T15?) holding the filter ot the bracket, I moved the bracket to the new filter, and installed the filter by twisting it onto the base, reinserting the rear clip, placing a new hose clamp on the front fuel hose, inserting the front nipple of the fuel filter into the front fuel hose, tightening down the front hose clamp, positioning the bracket so the hole aligns with the bracket bolt, tightening the torx bolt, and then installing the bracket bolt with the wierd mechanical/electrical device in its original position. 7. The linked post describes holding down the start button without touching the pedals for ten seconds and the car is supposed to remove the air from the fuel system. I tried this twice, but I am not sure how well it worked. So I would do it but YMMV. After this, I tried to crank it and it cranked for about 20 seconds and didnt start. Then on my next try it started. I checked for fuel leaks, found none and then buttoned up the bottom cover. Good Luck and Happy Fueling!!!
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
02-02-2013, 07:10 AM | #3 |
96
Rep 1,592
Drives: 2011 335d, M-Sport
Thanks for posting this, bud! Its good to see the pics for the next time I'm due for a FF change.
Two things... -what was the piece you had to hack off & why? I wouldn't have suspected there would be anything that would have to be removed like this. -I think it would be wise to purchase a BT tool if anyone is doing their own FF changes in order to properly purge the air from the line before attempting to start. Would uou aggree (just in case the hold-the-on-button purge doesnt work)? Running the FP dry for 20 seconds is going to cause more wear than thousands of miles of normal driving. Just a thought.
02-02-2013, 07:27 AM | #4 | |
489
Rep 1,614
Thank you for sharing this Quasimodem, great stuff!
02-02-2013, 10:54 AM | #5 | |
149
Rep 2,383
Yes, I would agree that there should be a better way to purge the air out of the system, and verify that it has been done. I couldnt hear the system do much of all in the way of air purging when I held the On/Off button for ten seconds and then waited a minute as per the instructions in the linked article.
02-02-2013, 12:20 PM | #6 |
TL/DR
57
Rep 234
Drives: 2009 335d Sport
I wonder why they decided on a bottom mount instead of engine bay mount set up? The fact of access and cleanliness alone would warrant the placement in my mind :thumb down
Either way, thanks for the post! Now I can sharpie the old filter to verify in the future they change it! |
02-02-2013, 04:20 PM | #7 |
614
Rep 2,408
Thanks for posting the pics!
When I changed the filter, and also when installing the 2um Stanadyne Fuel Manager final filter setup, I had to use the BT tool to energize the low pressure fuel pump to flush/prime the system. The Start/Stop button did not work for me. I'd highly suggest you prime the system to get fuel (the lubrication) to the HPFP before trying to start the car, for the long term health of your HPFP. How to use the BT to initiate the low pressure fuel pump: http://www.bimmerfest.com/forums/sho...3&postcount=27 "However, if you were to, say, use a BT (www.bavariantechnic.com/) then you could go under the Fuel Pump menu to the Activation sub menu and turn on/off the in tank lift pump. The fact that he wrote “may take a few cranks ” to start his engine makes me believe he wasn’t, in fact, initiating the lift pump like he thought. I think this because for, some reason, I know that if you cycle the lift pump with the BT then the engine will fire up as fast as normal. " |
cincy_335d4.50 |
02-02-2013, 05:25 PM | #8 |
353
Rep 1,005
Drives: GMC Sierra
This is key info! Cut that oil filter in two and let see the media, water, gunk and whatever else is in there.
We grow food to feed the animals so we can eat the animals
02-04-2013, 05:31 AM | #9 |
229
Rep 3,488
Drives: Montego Blue 335d
Great job amigo
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
02-04-2013, 01:15 PM | #11 |
489
Rep 1,614
I think the bags o' salt were to prevent rolling away - or the ramps from sliding in this case. You can also see from his pics and description that he was on ramps - the jack(s) were just there for a little extra clearance.
02-04-2013, 01:18 PM | #12 |
uʍop ǝpısdn
Rep 63
Drives: '11 335d, SG/Saddle, ZSP, ZPP
02-04-2013, 10:15 PM | #14 |
149
Rep 2,383
Yeah, I might do that, but I wish they were clear like a lot of fuel filters.
02-11-2013, 05:50 PM | #15 |
411
Rep 3,051
Drives: 2009 BMW 335d
Hmmm. The fuel filter cartridge on my my car shows WK 5001. Yours shows a WK 519.
I see we both have 2009 models and that the fuel filter changed at some point in 2010 models. Are you sure 100% that the one you got is correct? Anyone else? Here is a link: Link Last edited by GreekboyD; 02-11-2013 at 05:56 PM.. |
02-12-2013, 10:30 AM | #16 | |
149
Rep 2,383
Edit: Fuel Filter purchase date from tischer was 12/28/11. Okay, take a look at this: http://seekpart24.com/mann/fuel-filt...00253&at=21367 It seems to indicate that the 5001 does replace the 519. It appears that I put an older filter on my car. I am sure the new one is better.
02-12-2013, 02:04 PM | #17 |
411
Rep 3,051
My buddy ordered the "WK 5001" one and asked them about the production date possibility. This was the reply that he got:
"Glad to hear you received the part and all went well. And Yes, that is the exact reason why I needed your VIN, as we are all about making sure you get the correct part required. In fact as per BMW application restrictions, this Fuel Filter is only good for a 335d from 2009 to 2010 Year Model and "Through 01/2010" Production Year... - So in other words; this is good for 05/2008 Up To 01/2010 Production Date. |
02-12-2013, 09:02 PM | #18 | |
149
Rep 2,383
When I do a search for that P/N on Tischer it brings up a fuel filter, but it says that it cant confirm that it fits my car. And after inputing my year and model into Tischer, and I do a search under the fuel system on tischer, it doesnt show any fuel filter that I can find. Doing a search for WK5001, I come up a lot with "Mann" WK5001, so I think that is the Mann code for the same fuel filter. It is confusing because they both use "WK" so it makes it seem like it is the same code system, but I think it is something like the Fram system which is different. I think a Mann WK5001 = a BMW WK519, but the Mann appears cheaper.
02-12-2013, 09:09 PM | #19 |
411
Rep 3,051
P/N is the exact same as yours above. Would be good if someone emailed BMW for an explanation...lol
02-12-2013, 11:17 PM | #20 | |
149
Rep 2,383
P.S. It's called a "fuel strainer" which may explain why I can never find it looking for "filter" or "fuel filter".
02-18-2013, 10:45 PM | #22 |
149
Rep 2,383
see attached photo.
