08-18-2022, 09:41 PM | #1 |
24
Rep 132
Oil Leak?
Can anyone identify this black part in photo? Car was on lift last week getting tires changed and noticed some oil on outside of black plastic. Car was at dealer for oil change and service earlier this month.
08-19-2022, 11:54 AM | #2 |
5293
Rep 10,686
That is your oil filter housing cap. Since it is upside down, a mess is often made when changing the oil—the cap is full of oil. Oil also drips out of the housing when the cap is off. It often gets onto the aluminum plate and then drips on the ground later. You can take the time to clean up (I do) but many mechanics would rather move onto the next money making job.
Good news is that very recently BMW came out with a cap that has a drain plug on it. You could buy one and ask your dealer to install it next oil change. If the mechanic will take the time to pull the cap drain plug and drain the filter housing while draining the oil pan, your car should be cleaner afterwards. But the mechanic might not care to spend that extra time. |
